ماهوالdifference amplifierرجاءتساعدونى
النتائج 1 إلى 4 من 4
    روزاما المراغى
    روزاما المراغى غير متواجد حالياً
    tarek mohammed zak
    tarek mohammed zak غير متواجد حالياً
    differnce amplifer
    differnce amplifer is an amplifier opreates or amplifies the differnce voltage between two inputs i.e if 1 input is 5 and the other is 10 then the differnce voltage is 5v and the amplifer gain for example 10 the the out put voltage will be 5*10 = 50v if the inputs are connected to same source which means that there is no differnce between the two inputs then the amplifier will give no out its only be active when there is differnce between input voltage.
    thats all..........................cya
    رائد غسان
    رائد غسان غير متواجد حالياً
    الصورة الرمزية رائد غسان
    the main object of the differential amplifier is to cancel the dc component from the input and then introduce it to next stage in the op amp
    ماجد عباس محمد
    Received: 151
    اخى
    مشروح هنا
    http://www.arab-eng.org/vb/t30647-4.html
