أرجوا المساعده مع Ansys 11 حيث لم يعمل
النتائج 1 إلى 4 من 4
    َqat1972
    َqat1972 غير متواجد حالياً
    أرجوا ممن لديه الخبره المساعده
    حيث لم يشتغل البرنامج معي
    LICENSE log GIVES THE FOLLOWING ERROR
    4:22:30 (ansyslmd) License server system started on MA
    4:22:30 (ansyslmd) No features to serve, exiting
    4:22:30 (ansyslmd) EXITING DUE TO SIGNAL 27
    4:22:35 ((lmgrd)) Loop info: MT:0 VD_HB:0 reset:0clients:0fd's:0
    4:22:35 (lmgrd) ansyslmd exited with status 27 (No features to serve)
    4:22:35 (lmgrd) ansyslmd daemon found no features. Please correct
    4:22:35 (lmgrd) license file and re-start daemons.
    4:22:35 (lmgrd)
    4:22:35 (lmgrd) This may be due to the fact that you are using
    4:22:35 (lmgrd) a different license file from the one you expect.
    4:22:35 (lmgrd) Check to make sure that:
    4:22:35 (lmgrd) C:\Program Files\ANSYS Inc\Shared Files\Licensing\license.dat
    4:22:35 (lmgrd) is the license file you want to use.
    4:22:35 (lmgrd)
    َqat1972
    EHSAN020
    EHSAN020 غير متواجد حالياً
    DOWNLOAD VERSION 11 BY TORRENT(2.97GB
    THEN INSTALL IT
    THEN GENRATE LICENCE USING MY FILE
    a11calc.exe
    THEN GO TO LicenseSetup FOLDER
    INSTALL SERVER
    WHEN ASKING FOR LICENSE
    GO TO THE GENERATED ONE
    mody4ever
    mody4ever غير متواجد حالياً
    i try to do it
    but
    answer
    not licenses file
    what can i do ?
