اخر قطع الإلكترونية التي تم صنعها نوفمبر 2007 من كل الشركات
النتائج 1 إلى 5 من 5
    الصورة الرمزية كونترول
    كونترول
    كونترول غير متواجد حالياً
    السلام عليكم أقدم لكم هذه العناصر
    Traitement de signal analogique et mixte
    WJA1005: +5V Active-Bias InGaP HBT Gain Block...
    WJA1010: +5V Active-Bias InGaP HBT Gain Block...
    AD8216: High Bandwidth, Bidirectional 65 V Difference Amplifier...
    AD8390A: Low Power, High Output Current Differential Amplifier...
    AD8273: Dual-Channel Audio Difference Amplifier...
    HMC-C048: LOW NOISE AMPLIFIER...
    HMC392LH5: GaAs MMIC LOW NOISE...
    AD8394: Low Power, High Output Current, Quad Op Amp, Dual-Channel ADSL/ADSL2+
    ADR821: 2.5V Low Power, Precision Reference And Op Amp...
    AD8638: 16 V Auto-Zero, Rail-to-Rail Output Operational Amplifier...
    AD8669: Low Noise, Precision, 16 V, CMOS, Rail-to-Rail Operational Amplifier..
    AD8506: 20 ?A Maximum, Rail-to-Rail I/O, Zero Input Crossover Distortion Ampli
    LTC6406: 3GHz, Low Noise, Rail-to-Rail Input Differential Amplifier/Driver...
    LTC6082: Precision Quad CMOS Rail-to-Rail Input/Output Amplifier...
    LTC6088: Quad 14MHz, Rail-to-Rail CMOS Amplifiers...
    ISL28476: Quad Precision Micropower Single Supply Rail-to-Rail Input And Output
    VCA824: Wideband 420MHz, >40dB Gain Adjust Range, Linear In V/V Variable Gain
    AD8372: 41 DB Range, 1 DB Step Size, Programmable Dual VGA...
    LTC6702: Tiny Micropower, Low Voltage Dual Comparators...
    STG4158: Switch (NEATSwitch)...
    » Communication
    MSP7160: Multi-service Processor...
    ZL60209: Video IP Surveillance 10/100 Mbps Control Room UTP-to-Fiber...
    ZL60214: Video IP Surveillance 10/100 Mbps Control Room 14-Port UTP-to-Fiber Co
    ZL60209: Video IP Surveillance 10/100 Mbps Control Room UTP-to-Fiber Converter.
    WJA1035: +5V Active-Bias InGaP HBT Gain Block...
    SPBT2563C1: Wireless Communication & Connectivity ICs And Modules...
    Conversion de Données
    AD9627-11: 11-Bit, 105/150 MSPS, 1.8 V Dual Analog-to-Digital Converter...
    AD9627: 12-Bit, 80 MSPS/105 MSPS/125 MSPS/150 MSPS, 1.8 V Dual Analog-to-Digit
    AD9626: 12-Bit, 170 MSPS/210 MSPS/250 MSPS, 1.8 V Analog-to-Digital Converter.
    AD9601: 10-Bit, 200 MSPS/250 MSPS 1.8 V Analog-to-Digital Converter...
    AD7983: 16-Bit, 1.33 MSPS PulSAR ADC In MSOP/QFN...
    ADS62P15: Dual Channel 11-Bits, 125 MSPS ADC With Parallel CMOS/DDR LVDS Outputs
    ADC08D1020: Low Power, Dual 8-Bit, 1.0 GSPS A/D Converter From The PowerWise...
    AD7984: 18-Bit, 1.33 MSPS PulSAR 10.5 MW ADC In MSOP/QFN...
    LTC2209: 16-Bit, 160Msps ADC...
    ADS1281: High Resolution 24-Bit Analog-to Digital Converter...
    AD9600: 10-Bit, 105 MSPS/125 MSPS/150 MSPS, 1.8 V Dual Analog-to-Digital Converter
    LTC2308: Low Noise, 500ksps, 8-Channel, 12-Bit ADC...
    MCP4725: 12-Bit Digital-to-Analog Converter With EEPROM Memory In SOT-23-6...
    AD5360: 16-Channel, 16-Bit, Serial Input, Voltage-Output DAC...
    DAC8565: 16-Bit, Quad Channel, Ultra-Low Glitch, Voltage Output DAC
    Composants discrets
    STTH10R04: Ultrafast Rectifiers...
    BYV29-600: Rectifier Diode Ultrafast...
    BYC8X-600: Rectifier Diode Hyperfast...
    STPS61L45C: Schottky Barrier...
    BT169D-L: Thyristor, Logic Level...
    BTA312Y: 12A Three-quadrant Triacs High Commutation Insulated...
    PBSS4350SPN: 50 V, 2.7 A NPN/PNP Low VCEsat (BISS) Transistor...
    PD85035C: Transistors, Radio Frequency...
    2STA1694: Transistors, Power Bipolar...
    2STA2121: Transistors, Power Bipolar...
    2STA2510: Transistors, Power Bipolar...
    2STC5948: Transistors, Power Bipolar...
    BUK7880-55A: N-channel TrenchMOS Standard Level FET...
    BF1214: Dual N-channel Dual Gate MOSFET...
    FDFMJ2P023Z: MOSFET And Schottky Diode...
    FDMJ1023PZ: -20V Dual P-Channel PowerTrench MOSFET...
    STW43NM60N: Power MOSFETs...
    STD90N4F3: Power MOSFET...
    DSPs (Digital Signal Processors)
    TMS320DM6467: Digital Media System-on-Chip...
    Interfaces et Interconnexions
    ADUM3440: Quad Channel, High Speed Digital Isolators...
    LMH0356: 3Gbps HD/SD SDI Reclocker With 4:1 Input Mux And FR4 EQs...
    LMH0001: SMPTE 259M / 344M Serial Digital Cable Driver...
    LMH0074: SMPTE 259M / 344M Adaptive Cable Equalizer...
    AD8191A: 4:1 HDMI/DVI Switch With Equalization...
    AD9387NK: High Performance, Low Power HDMI/DVI Transmitter...
    DS25CP102: 3.125 Gbps 2X2 LVDS Crosspoint Switch With Transmit Pre-Emphasis
    1.5 Gbps 2X2 LVDS Crosspoint Switch from the Power: 1.5 Gbps 2X2 LVDS Crosspoint Switch From The PowerWise Family...
    ISL3259E: ±15kV ESD Protected, 100Mbps, 5V, PROFIBUS, Full Fail-safe, RS-485/R
    HT82J927A: USB Gamepad...
    Logique
    [/code]NBXDBA012: 3.3V, 106.25MHz / 212.5Mhz PureEdge FibreChannel Clock Oscillator
    AD8194: Buffered 2:1 TMDS Switch With Equalization...
    ADA4938-2: Ultralow Distortion Differential ADC Driver...
    Microcontrolleurs
    MPC8548E: PowerQUICC? III...
    MC9S12XEP100RMV1: Device Overview MC9S12XE-Family...
    ST72141K2-Auto: Microcontrollers For Automotive...
    Microprocesseurs
    P89CV51RB2: 8-bit 80C51 5 V Low Power 64 KB Flash Microcontroller With 1 KB RAM
    HT83R074: Q-VoiceTM...
    LPC2141: Single-chip 16-bit/32-bit Microcontrollers; Up To 512 KB Flash
    Multimédia
    TAS5342: 100W Class D Stereo Power Stage...
    TAS5352: 125W Class D Stereo Power Stage...
    MM1779: PD IC For Optical Pickups For DVD Players...
    ADA4304-3: 1:3 Single-Ended, Low Cost, Active RF Splitters...
    ISL59451: Triple 4:1 DC Restored Single Supply Video Multiplexing Amplifier...
    ISL59452: Triple 4:1 Single Supply Video Multiplexing Amplifier...
    كونترول
    » Communication
    » Conversion de Données
    » Composants discrets
    » DSPs (Digital Signal Processors)
    » Interfaces et Interconnexions
    » Logique
    » Microcontrolleurs
    » Microprocesseurs
    » Multimédia
    » Optoélectronique
    LQ035Q7DB05: Power Management...
    LS037V7DW03: Transflective CG-Silicon LCD...
    engzomozafa
    engzomozafa غير متواجد حالياً
    ty
    احمد العزاوي29
    احمد العزاوي29 غير متواجد حالياً
    الصورة الرمزية احمد العزاوي29
    مشكور
    ليس القوي الذي يكسب الحرب دائما
    وانما الضعيف الذي يخسر السلام دائما
    علي_عراق
    علي_عراق غير متواجد حالياً
    يسلموا
