New building design
النتائج 1 إلى 9 من 9
    الافضل المبتكرين
    الافضل المبتكرين غير متواجد حالياً
    New building design
    URBAN PROJECTS
    57 Bond Street
    New York, NY
    Completion Date: 2007
    Planning and design of a new 5-story, apartment building comprising approximately 32,000 square feet. This new building, located on Bond and Bowery Streets, will feature two apartments per floor for a total of 10 units with a ground-floor retail or commercial space. The apartments feature loft like space with a 12-foot floor-to-floor height. The building’s corner lot allows for each apartment to have two window walls that will allow a maximum of air and light into each unit. Each apartment will also feature a balcony or roof terrace on the building’s distinctive bays and setbacks. The building’s curved exterior, executed in stone and glass, was developed as a way to gently move the structure around the corner from Bond to Bowery . Street
    منظور خارجي
    تفصيل للبناية الجديدة
    تصميم الداخلي للبناية
    مخطط الطابق الاول
    مخطط الطابق الثاني
    مخطط المتكرر للبناية
    الافضل المبتكرين
    مبنى شقق متعدد الطوابق
    The Paradigm
    146 West 22nd Street
    New York, NY
    Completion Date: 2004
    Planning and design of a new 13-story, apartment building comprising approximately 35,000 square feet. Twelve floors will feature one apartment per floor and 10-foot floor-to-floor heights, making this building the first new loft construction in New York in several decades. The ground floor will feature retail space
    منظور للمبنى ككل
    مخطط الطابق الاول
    مخطط الطابق المتكرر
    مخطط الطايق العاشر
    الافضل المبتكرين
    مبنى شقق متعددة الطوابق
    The Enclave - 224 East 52nd Street
    New York, NY
    Completion Date 1999
    The Enclave is a “sliver” building that breaks the stereotype. It solved a central concern: how to minimize the intrusiveness of a tall, thin structure amid low-rise buildings. The Enclave is a 16-story apartment building, 40 feet wide and 70 feet deep, on a block of largely three-story town houses (faced with brown stone, stucco and limestone) and four- to five-story apartment buildings. The primary goal was to fit the building into the block by minimizing the perception of its height as seen from street level. A second goal was to design a building that echoed the scale and texture of the environment.
    We gave the building the quality of a brick sculpture, thereby distinguishing it as more than just a tall building. The earthtone brick façade of The Enclave is set back at the eighth and tenth floors, and a pink stucco wall appears to float in front of the façade up the seventh floor. The pink stucco material softens the building’s visual mass and covers the façade most visible from the street. This gesture reflects the texture and scale of the townhouse neighborhood. Fenestration and semicircular balconies further lighten the building’s mass. Railings on open balconies visually recall the fire escapes of adjacent apartment buildings.
    Number of stories: 16
    Number of units: 15
    واجهة منظورية للمبنى
    واجهة اخرى
    منظور من اسفل البناية
    منظور داخلي
    الطابق المتكرر للشقة
    الطابق العلوي للشقة
    محمدالعبادي
    محمدالعبادي غير متواجد حالياً
    جزاك الله خيرا
    يا زمن
    يا زمن غير متواجد حالياً
    الصورة الرمزية يا زمن
    صراحة Waw إبداع
    alaanabil
    alaanabil غير متواجد حالياً
    الصورة الرمزية alaanabil
    جميل ما شاء الله عليك
    يا رب ديما كده
    معماري شاطر
    معماري شاطر غير متواجد حالياً
    الله يعطيك العافيه ومشكور
    جزاك الله خير
    romeo201020
    romeo201020 غير متواجد حالياً
    very beautiful..thanks
    الشفق الابيض
    الشفق الابيض غير متواجد حالياً
    الصور غيز ظاهرة
