Papers
صفحة 8 من 8 الأولىالأولى ... 4 5 6 7 8
النتائج 71 إلى 76 من 76
  1. [71]
    عامر الناصري
    عامر الناصري غير متواجد حالياً
    ارجو تزويدي بال papers التالية
    Ethylmercaptan oxidation over supported cobalt(II)phthalocyanines
    Autoxidation of mercaptans promoted by a bifunctional catalyst prepared by polymer attachment of cobalt- phthalocyanine
    Catalytic electro-oxidation of 2-mercaptoethanol using cobalt phthalocyanine + poly(2-chloroaniline) modified electrodes
    Autooxidation of alkyl mercaptans catalysed by cobalt(II)phthalocyanine tetrasodium sulphonate in reverse micelles
    Phthalocyanine modified TiO2 or WO3-catalysts for photooxidation of sulfide and thiosulfate ions upon irradiation with visible light
    The promoting role of polycations in the cobalt(ii) phthalocyanine tetrasodium sulfonate catalysed oxidation of thiols
    Catalytic activity of iron and cobalt phthalocyanines wrapped in poly(peptide) for autoxidation of thiol
    Autoxidation of thiols with cobalt(II) phthalocyanine tetrasodium sulfonate attached to poly(vinylamine) : II. Kinetic measurements
    Novel aqueous soluble cobalt phthalocyanine: synthesis and catalytic activity on oxidation of 2-mercaptoethanol
    Thiol oxidation at 2-mercaptopyrimidine-appended cobalt phthalocyanine modified glassy carbon electrodes
    Oxidation of mercaptans in light oil sweetening by cobalt(II) phthalocyanine–hydrotalcite catalysts
    Catalytic oxidation of 2-mercaptoethanol by cobalt(II)-phthalocyanine complexes intercalated in layered double hydroxides
    Preparation and characterization of NiO/MgO/Al2O3 supported CoPcS catalyst and its application to mercaptan oxidation
    Influence of substituents and ligands of various cobalt (II) porphyrin derivatives coordinately bonded to silica on the oxidation of mercaptan
    · Dispersion and mercaptan oxidation efficiency of cobalt(II)-tetraphenoxyphthalocyanine on additive-impregnated charcoal
  2. [72]
    حميد محمد النجدي
    حميد محمد النجدي غير متواجد حالياً
    اخي الكريم اذا امكن تزويدي بالمقالات التاليه وكلها على موقع SCIENCE DIRECT
    واكون شاكر فضلك
    1- Conversion inference for ETBE reactive distillation
    Separation and Purification Technology, Volume 19
    2- Dynamic simulation for reactive distillation with ETBE synthesis
    Separation and Purification Technology, Volume 31, Issue 3, 1 June 2003,
    3- Multiplicity and Pseudo-Multiplicity in MTBE and ETBE Reactive Distillation
    Chemical Engineering Research and Design, Volume 76, Issue 4, May 1998
    4- Synthesis of ETBE: Residue curve maps for the heterogeneously catalysed reactive distillation process
    Chemical Engineering Journal, Volume 66, Issue 3, March 1997
    5- Modelling reactive distillation
    Chemical Engineering Science, Volume 55, Issue 22, November 2000
    6- Dynamic rate-based and equilibrium models for a packed reactive distillation column
    Chemical Engineering Science, Volume 58, Issue 12, June 2003
    7- Optimization of the ETBE (ethyl tert-butyl ether) production process
    Fuel Processing Technology, Volume 89, Issue 11, November 2008,
    8- Modelling of reactive separation processes: reactive absorption and reactive distillation
    Chemical Engineering and Processing, Volume 42, Issue 3, March 2003,
    9- Addition of an azeotropic ETBE/ethanol mixture in eurosuper-type gasolines
    Fuel, Volume 85, Issues 17-18, December 2006
    10- Comparison of equilibrium stage and nonequilibrium stage models for reactive distillation
    Chemical Engineering Journal, Volume 76, Issue 1, January 2000
    11- Dynamic tracer study of column packings for catalytic distillation
    Chemical Engineering and Processing, Volume 44, Issue 6, June 2005
  3. [73]
    عبدالرحمن البكوش
    عبدالرحمن البكوش غير متواجد حالياً
    يا اخى اذا ممكن paper حول thermoplastic (polyprpylene&polyethlene&acetal&pvc)
    الله الموفق
  4. [74]
    م باسل وردان
    م باسل وردان غير متواجد حالياً
    الصورة الرمزية م باسل وردان
    Received: 8
    بارك الله فيك
  5. [75]
    عبدالرحمن البكوش
    ياخي العزير بارك الله فيك
    اوراق بحث creep curve pvc
  6. [76]
    أبو حمزه الشامي
    أبو حمزه الشامي غير متواجد حالياً
    الصورة الرمزية أبو حمزه الشامي
    شكرا لكم
    ومن يتــق الله يجعــل لـه مخرجــا
    ويرزقـــــه من حــيث لا يحتســـب
    ....... مشوار الألف ميل يبدأ بخطوة .......
