Gust Loading Factors for Tension Leg Platforms
النتائج 1 إلى 6 من 6
    الصورة الرمزية Eng-Maher
    Eng-Maher
    Eng-Maher غير متواجد حالياً
    مشرف قسم الهندسة البحرية.
    Received: 103
    Given: 408
    Introduction
    The increasing demand on the performance of wind sensitive
    structures has placed a growing importance on the
    problem of wind effects on constructed facilities. As depth
    increases, the construction and maintenance of conventional
    jacket type oil platforms become less cost efficient.
    The tension leg platform (TLP) is a promising concept for
    deep water drilling. A TLP is a buoyant platform that is
    vertically moored to the seabed by pretensioned tethers. It
    is compliant in the horizontal plane and its motions have
    time periods that fall in the energy spectrum corresponding
    to wind excitation frequency range. The importance of
    dynamic wind effects is therefore more significant on compliant
    structures than on conventional offshore platforms,
    where structural frequencies exceed the range of the wind
    الرابط
    http://www.ce.ufl.edu/~kgurl/Papers/gust.pdf
    Eng-Maher
    Received: 103
    Given: 408
    up up up up
    الحمد لله
    Eng-Maher
    Received: 103
    Given: 408
    يرفع للافاده ***********
    الحمد لله
    hussein74
    hussein74 غير متواجد حالياً
    مشكور لهذا جاري التحميل والتقييم
    hussein74
    thank you sir very much
    Eng-Maher
    Received: 103
    Given: 408
    شكرا اخى حسين ... نورت الملتقى
    الحمد لله
