الامان في الكهرباء ((ما تعليقك))
النتائج 1 إلى 8 من 8
    yasser512
    yasser512 غير متواجد حالياً
    Received: 72
    Electrical Safety
    Electricity can be dangerous and care should be taken in its use. Even if you are handy around the house, do not take risks with electricity.
    Doing your own electrical work is not only dangerous, it is illegal. Have all your electrical work carried out by a licensed electrical contractor. Steven Murphy Electrical Contractors are fully licensed.
    Top 10 Electrical Safety Tips from Western Power
    Install a circuit breaker device.
    Read all the instructions for appliances carefully before using them to make sure they are used correctly and safely.
    Make sure that the appliance is switched off before removing the plug from the power point.
    Switch off appliances at the power point, when not in use.
    If your appliance fails to operate, blows a fuse, overheats or sparks heavily, disconnect the appliance and have it checked by a licensed electrical contractor or the Western Power Safety Watchit Van.
    Broken switches and sockets are dangerous. Have them immediately replaced by a licensed electrical contractor.
    Remember that light fittings are usually connected to live wires, even if the light switch is turned off. Light fittings, switches and power points should not be removed for painting.
    Aluminium ladders, metal scaffold and painters' trestles can be a real electrical hazard. When working close to wiring, they should not be used.
    Nailing and fixing metal roofing and tile battens can be dangerous and care should be taken to avoid contact with electrical cables. Electrical equipment should be kept away from pools and spas at all times.
    Never use extension cords near a pool.
    طارق الشعبي-اليمن
    طارق الشعبي-اليمن غير متواجد حالياً
    الصورة الرمزية طارق الشعبي-اليمن
    Received: 8
    القط يحب خناقة
    إبن جبير
    إبن جبير غير متواجد حالياً
    عضو متميز جداً
    الصورة الرمزية إبن جبير
    Received: 19
    قد يكون مشروع جديد ، ولكن الإهمال واضح جداً من قبل المهندس المشرف على المشروع ، وحياة العامل (أقول عامل وليس فني كهرباء) معرضة للخطر
    ياسرعشاوى
    ياسرعشاوى غير متواجد حالياً
    الصورة الرمزية ياسرعشاوى
    اقتباس المشاركة الأصلية كتبت بواسطة إبن جبير مشاهدة المشاركة
    دى مش كهرباء دى سبهللة
    salemop31
    salemop31 غير متواجد حالياً
    الصورة الرمزية salemop31
    لا
    تعجبوا من علو همته وسنه في أوان منشاها
    إن النجوم التي تضيء لنا أ
    صغرها في العلو أعلاها
    مجدى عبد المعطى
    مجدى عبد المعطى غير متواجد حالياً
    ده أسمه بائع عمره ولا يعرف شيء عن الأمن الصناعى
    م/حنا
    م/حنا غير متواجد حالياً
    التوعية للامن والسلامة لابدمنها مع تحياتي
    محمد حمداني
    محمد حمداني غير متواجد حالياً
    السلامة والامن صفر
    عدم استعمال معدات الوقاية الشخصية
    الكفوف --الاحذية الواقية- حزام الامان -short protection - وضعه على الاسلاك غير صحيح .
    المهندس المشرف يتحمل المسؤولية
