أخر إنتاج لقطع الإلكترونيك أكتوبر 2007 من كل شركات
النتائج 1 إلى 7 من 7
    الصورة الرمزية كونترول
    كونترول
    كونترول غير متواجد حالياً
    أقدم لكم ماتما إنتاجه من قطع إلكترونية لشهر أكتوبر 2007
    تفضلو
    كود PHP:
    Traitement de signal analogique et mixte
    LMH6552: 1.5 GHz Fully Differential Amplifier from the PowerWise® Family...
    ADA4937-2: Dual Ultralow Distortion, Differential ADC Driver...
    MAX4208: Ultra-Low Offset/Drift, Precision Instrumentation Amplifiers with REF
    5962-0721302QXC: 500MHz Rail-to-Rail Amplifiers...
    ADR821: Low Power, Precision Reference and Op Amplifier...
    AD8647: 24 MHz Rail-to-Rail Amplifier with Shutdown Option (Dual with Low Powe
    OPA2369: 1.8V, 1uA max, Zero-Crossover Rail-to-Rail I/O Operational Amplifier..
    OPA2376: Precision, Low Noise, Low Quiescent Current Operational Amplifier...
    VCA822: Wideband, >40dB Gain Adjust Range, Linear in V/V Variable Gain Amplifi
    TL972: Output Rail-to-Rail Very-Low-Noise Operational Amplifier...
    LMH6515: 600 MHz, Digital Controlled, Variable Gain Amplifier from the PowerWis
    EMIF02-1003M6: EMI Filtering & Signal Conditioning...
    EMIF03-SIM02M8: EMI Filtering & Signal Conditioning...
    TS3A24157: 0.65 Ohm Dual SPDT Analog Switch Dual-Channel 2:1 Multiplexer/Demultiplexer
    TS3A24159: 0.3 Ohm Dual SPDT Analog Switch Dual-Channel 2:1 Multiplexer/Demultiplexer
    MAX4888: High-Speed PCI Express Passive Switches Enable Gen I Switching...
    كود PHP:
    Automobile
    MAX15008: Automotive 300mA LDO Voltage Regulators with Tracker Output...
    ATA6823: H-bridge Motor Driver...
    ATA6623: LIN Bus Transceiver with 3.3V Voltage Regulator...
    كود PHP:
    Communication
    SPZB250: Wireless Communication & Connectivity ICs and Modules...
    كود PHP:
    Conversion de Données
    ADC14DS105: Dual 14-Bit, 105 MSPS A/D Converter with Serial LVDS Outputs
    ADS6122: Low Power 12-bit 65MSPS ADC with selectable parallel CMOS or LVDS output
    ADS6124: Low Power 12-bit 65MSPS ADC with selectable parallel CMOS or LVDS output
    ADS6125: Low Power 12-bit 65MSPS ADC with selectable parallel CMOS or LVDS output
    ADS6144: Low Power 14-bit 105MSPS ADC with selectable parallel CMOS or LVDS output
    ADS6225: Dual 12-bit 125MSPS ADC with serialized LVDS output...
    LTC2453: Easy-to-Use, Ultra-Tiny, Differential, 16-Bit Delta Sigma ADC With I2C
    MAX5881: 12-Bit, 4.3Gsps Cable Downstream Direct RF Synthesis DAC...
    ADS8317: 16-Bit, Pseudo Bipolar, Fully Differentia, 200kSPS Serial Out
    DAC8881: Single Channel 16-Bit, Low Noise, Voltage Output Digital-to-Analog...
    كود PHP:
    Composants discrets
    FFP04S60S: 4A, 600V STEALTH II Rectifier...
    FFP15S60S: 15A, 600V STEALTH II Rectifier...
    BAP55LX: Silicon PIN diode...
    STPS10120C: Schottky Barrier...
    STH13009: Transistors, Power Bipolar...
    STL128DN: Transistors, Power Bipolar...
    TR136D: Transistors, Power Bipolar...
    TR236: Transistors, Power Bipolar...
    2ST2121: Transistors, Power Bipolar...
    2STC5242: Transistors, Power Bipolar...
    2STW4466: Transistors, Power Bipolar...
    TIP30C: Transistors, Power Bipolar...
    STP03D200: Transistors, Power Bipolar...
    BUK7Y13-40B: N-channel TrenchMOS standard level FET...
    STB13005: Transistors, Power Bipolar...
    STV270N4F3: Power MOSFETs...
    STB16NM50N: Power MOSFETs...
    STD60N10: Power MOSFETs...
    ESD9: Low Capacitance ESD Protection; unidirectional...
    NUP5150: Penta Array in 1.2 x 1.0 UDFN...
    NUP8011: 8 Channel Ultra Low Prifile ESD Array...
    RClamp2504P: RailClamp® 2.5V TVS Array...
    كود PHP:
    Interfaces et Interconnexions
    TCA6408: Low-Voltage 8-Bit I2C and SMBus I/O Expander With Interrupt Output
    MAX13181E: +5.0V, ±15kV ESD-Protected, Half-Duplex/Full-Duplex, RS-485 Transceiver
    ISL3285E: ±16.5kV ESD Protected, +125°C, 3.0V to 5.5V, SOT-23/TDFN Packaged
    كود PHP:
    Logique
    74LVC1G10: Single 3-input NAND gate...
    كود PHP:
    Mémoires
    M29W128GL: Flash NOR, Embedded Applications...
    M36P0R8070E0: Flash NOR, Mobile Terminal...
    M30L0R8000T2: Flash NOR, Mobile Terminal...
    كود PHP:
    Microcontrolleurs
    LPC2378: Single-chip 16-bit/32-bit microcontroller; 512 kB flash with ISP/IAP,
    HT47R10A-1: R-F Type 8-Bit MCU...
    ATmega3290: AVR 8-Bit RISC ...
    PIC18F8493: LCD PIC18F Microcontroller ...
    PIC18F8723: PIC18F8723 Family...
    HT1647: 4-Level Gray Scale 64x16 LCD Controller for I/O MCU...
    HT1647A: 4-Level Gray Scale 64x16 LCD Controller for I/O MCU...
    HT46R343: A/D Type 8-Bit OTP MCU with OPA and 8x8 LED Driver...
    ST72321BAR6-Auto: Microcontrollers for Automotive...
    ST7LCRE4U1: 8-bit Microcontrollers...
    كود PHP:
    Microprocesseurs
    AT91SAM9261S: AT91SAM 32-bit ARM-based Microcontrollers ...
    كود PHP:
    Multimédia
    MAX9729: Stereo Headphone Amplifier with BassMax, Volume Control, and Input Mux
    ADD8733: Integrated TFT Panel Power Supply with Gate Modulation and VCOM...
    TFA9810:Stereo full-bridge audio amplifier 2 x 12 W...
    TDA7850A: Car Entertainment ICs...
    TDA7854: Car Entertainment ICs...
    ZL38004: Enhanced Voice Processor with Dual Wideband Codecs ...
    ZL38015: Voice Processor ...
    يتبع
    كونترول
    » Gestion d'alimentation
    IRS21271PBF: 600V Current Sensing Single Channel Driver with Gate Drive Range of 9V
    TPD1048F: Intelligent Power Device...
    FAN7371: High Current High Side Only Gate Driver...
    SPAC265-3W: Power Supply Modules...
    TPS65161A: Bias Power Supply for TV and Monitor TFT LCD Panels...
    LTC4001-1: 2A Synchronous Buck Li-Ion Charger...
    NCP347: Overvoltage Protection Device...
    BQ27500: System-Side Impedance Track(TM) Fuel Gauge...
    LTC4078: Dual Input Li-Ion Battery Charger with Overvoltage Protection...
    LM3102: Synchronous 1MHz 2.5A Step-Down Voltage Regulator from the PowerWise®
    LM3103: Synchronous 1MHz 0.75A Step-Down Voltage Regulator from the PowerWise®
    ADP1828: Synchronous Buck PWM, Step-Down, DC-to-DC Controller...
    LTM8020: 200mA, 36V DC/DC µModule...
    A5970D: DC-DC Conversion...
    A5973AD: DC-DC Conversion...
    A5973D: DC-DC Conversion...
    AAT2158: 1.5A Low Noise Step-Down Converter...
    SPDC400-7W: Power Supply Modules...
    TPS62355: Adjustable, 800mA, 3MHz Buck Converter with I2C Interface in Chip...
    MAX5957: Triple PCI Express, Hot-Plug Controllers...
    MAX5959: Triple PCI Express, Hot-Plug Controllers...
    MAX8830: LED Light Management IC in 2.5mm x 2.5mm UCSP...
    MAX8784: Step-Up Regulator, Internal Charge Pumps, Switch Control, and Operatio
    MAX4990E: High-Voltage, ±15kV ESD-Protected Electroluminescent Lamp Driver...
    LM3404: 1.0A Constant Current Buck Regulator for High Power LED Drivers
    LM3405A: 1.6MHz, 1A Constant Current Buck LED Driver with Internal Compensation
    LP5521: Programmable Three Channel LED Driver from the PowerWise® Family ...
    LP5522: Programmable Three Channel LED Driver from the PowerWise® Family ...
    HT1632: 32x8 & 24x16 LED Driver ...
    CAT4016: 16-Channel Constant Current LED Driver...
    LT3590: 48V Buck Mode LED Driver in SC70 and 2mm x 2mm DFN...
    AAT1270: 1A Step-Up Current Regulator for Flash LEDs...
    STD60N3LH5: Power MOSFETs...
    MCP1631: MCP1631/MCP1631V, High-Speed, Pulse Width Modulator ...
    AP7165: 600mA Low Dropout Regulator...
    CAT6221: 300mA CMOS Dual LDO Regulator...
    CAT6217: 150mA CMOS LDO Regulator...
    CAT6218: 300mA CMOS LDO Regulator...
    STCS05: Linear Regulators...
    STCS2: Linear Regulators...
    TPS71719: 150mA RF Linear Regulator with Ultra-High PSRR...
    TPS73725: Cap-Free, 1A Low-Dropout Regulator with Reverse Current Protection...
    TPS73733: Cap-Free, 1A Low-Dropout Regulator with Reverse Current Protection...
    LT3500: Monolithic 2A Step-Down Regulator Plus Linear Regulator/Controller...
    CAT823: System Supervisory Voltage Reset with Watchdog and Manual Reset...
    NJM2825: Precision Micropower Shunt Voltage Reference IC...
    REF3312: 30ppm/C Drift, 3.9uA, SOT23-3, SC70-3 Voltage Refrence...
    » RF & Micro-Ondes
    CC1111F16: Sub-1GHz System-on-Chip with MCU, 16kB Flash memory and USB 2.0...
    CC1111F32: Sub-1GHz System-on-Chip with MCU, 32kB Flash memory and USB 2.0...
    CC1111F8: Sub-1GHz System-on-Chip with MCU, 8kB Flash memory and USB 2.0...
    HMC-ALH482: GaAs HEMT MMIC Modulator Driver Amplifier, DC - 43 GHz...
    HMC-AUH232: GaAs HEMT MMIC MODULATOR DRIVER AMPLIFIER, DC - 43 GHz...
    HMC-ALH364: 24 - 32 GHz, 21 dB Gain, 2 dB NF, +7 dBm P1dB ...
    HMC-ALH444: 12 GHz, 17 dB Gain, 1.5 dB NF, +19 dBm P1dB ...
    HMC-ALH102: 20 GHz, 10 dB Gain, <3.5 dB NF, +10 dBm P1dB ...
    HMC-ALH482: 22 GHz, 16 dB Gain, 2.2 dB NF, +14 dBm P1dB ...
    HMC-ALH476: 27 GHz, 20 dB Gain, 2 dB NF, +14 dBm P1dB ...
    HMC-ALH459: GaAs HEMT Low Noise Amplifier, 71 - 86 GHz...
    HMC-APH596: GaAs HEMT MMIC Medium Power Amplifier...
    HMC-APH196: GaAs HEMT MMIC Medium Power Amplifier...
    HMC-APH462: GaAs HEMT MMIC Medium Power Amplifier...
    HMC-APH478: GaAs HEMT MMIC Medium Power Amplifier...
    HMC-APH473: GaAs HEMT MMIC Medium Power Amplifier...
    HMC174MS8E: GaAs MMIC I/Q Mixer Module 20 - 31 GHz ...
    HMC-C047: GaAs MMIC I/Q MIXER MODULE 20 - 31 GHz ...
    HMC-MDB218: GaAs MMIC Sub-Harmonic IRM Mixer...
    HMC-MDB169: GaAs MMIC Sub-Harmonic IRM Mixer...
    HMC-MDB277: GaAs MMIC Sub-Harmonic IRM Mixer...
    HMC-MDB172: GaAs MMIC Sub-Harmonic IRM Mixer...
    HMC-MDB171: GaAs MMIC Sub-Harmonic IRM Mixer...
    HMC-MDB207: GaAs MMIC Sub-Harmonic IRM Mixer...
    ADL5387: 50 MHz to 2 GHz Quadrature Demodulator...
    HMC174MS8: GaAs MMIC T/R SWITCH DC - 3 GHz...
    » Capteurs
    ADuC7034: Integrated Precision Battery Sensor ...
    A3340: Chopper-Stabilized, Precision Hall-Effect Switch...
    TMP422: /-1 degreeC Remote/Local TEMPERATURE SENSOR w/N-Factor
    ADIS16209: High Accuracy, Dual-Axis Digital Inclinometer & Accelerometer...
    » Circuits de Synchronisation
    MAX3625: Low-Jitter, Precision Clock Generator with Three Outputs...
    AD9912: GSPS Direct Digital Synthesizer with 14-Bit DAC...
    AD9518-2: 6-Output Clock Generator with Integrated 2.2 GHz VCO...
    AD9518-3: 6-Output Clock Generator with Integrated 2.0 GHz VCO...
    م.الـحـربي
    م.الـحـربي غير متواجد حالياً
    جزاكم الله خير اخي الكريم على هذه المعلومات القيمة ..
    الداخلية
    الداخلية غير متواجد حالياً
    الصورة الرمزية الداخلية
    معلومة ماتتفوت
    كونترول
    شكرا لكم وبارك الله فيكم
    احمد الزهيرى
    احمد الزهيرى غير متواجد حالياً
    الله ينورعليك ويبارك فيك
    إلكترونيكس
    إلكترونيكس غير متواجد حالياً
    مجهود كبير ورائع حقا
    تسلم يداك :)
