أسئلة في (gsm)أرجو المساعدة وبسرعة
النتائج 11 إلى 20 من 25
    m_m_foad
    m_m_foad غير متواجد حالياً
    المهندس الفاتح
    بصراحة عجبني الموضوع بس كان لي استسفار بسيط الاسئلة دي من اي شركة اتصالات في مصر بمعني في اي شركة اتسال الاسئلة
    وجزاك الله كل خير
    laith1
    laith1 غير متواجد حالياً
    السلام عليكم ... في البدايه اود شكر الاخ الحسام على دعوتي وتنبيهي للأجابه على هذه الاسئله ... وسأجيب بأختصار عليها وارجو ان تكون الاجابه وافيه ان شاء الله ولي بحث مقدم الى شركتي من قبل سنتين او اكثر عنوانه " اسرع طريق لفهم الاتصالات المتنقله وبأقصر وقت " سأرفقه ان شاء الله ليعم الفائده
    وبسم الله نبدأ
    What is the name of the interface between MS&BTS?
    the interface between Mobile Station (MS) & Base Transceiver Substation called RTF (Radio Transceiver Frequency ) and it's consist of 8 Time Slots (TS)
    4),, ,, ,, ,, ,, BTS&BSC?
    the interface between Base Transceiver Substation & Base Controller Substation called E1's ( Microwave link ) it's consist from 32 TS and each size for it 64 bayt
    5) What is the interface between TDM&TDMA system?
    6) How many subscribers can use the same GSM frequency simultaneously?
    As each RTF have 8 TS so each TS can handle one call
    7) What is the E1 frame (structure& rate)?
    As we said that each E1 have 32 TS and each TS for E1's size equal to 64 Bayt so the rate for E1 equal to = 32 * 64 = 2.048 Mbayt
    8) What is the traffic delivered between the BTS & BSC?
    E1 traffic rate (2 Mbayt )
    9) What is the difference between the GSM antenna and the transmission antenna?
    GSM Antenna it's Radio antenna called matrix antenna , either Transmissions antenna it's Microwave type antenna dish type
    10) What is meant by the antenna alignment & draw the beam pattern?
    I will bring the define of it from some handbook
    11) What is the difference between MSC&GMSC?
    Mobile Switching Centre it used SS7 protocol , Gateway MSC used IP's
    12) What are the basic modules in the BTS?
    The Basic module for BTS you can see it in city as GSM tower consist of Radio section and Matrix antenna ( each street have one so you can focus on it )
    13) Is the received power is the same for the same TX power with different antenna sizes?
    NO , it's difference, depends on Antenna Gain
    laith1
    الاخوة الاعزاء لقد حاولت ان ارفع البحوث الى المنتدى وللأسف لم اتمكن بسبب ان المشاركات لم تصل الى 100 ! , على اي احاول ساحاول ارسالها الى الاخ الحسام عالخاص وهو بدوره ان شاء الله سيرفعها الى الموقع
    الحسام
    الحسام غير متواجد حالياً
    شكرا جزيلا لك أخي المهندس ليث على هذه الإجابات الموفقة و الإفادات الرائعة
    جزاك الله خيرا
    بالنسبة لملف بحثك أرجو ارساله لي او رفعه عبر مواقع التحميل و هي كثيرة جدا
    أكرر شكري لك
    laith1
    السلام عليكم ..
    اخي البحث ستجدونه على الرابط ادناه وبالتوفيق ان شاء الله لكم جميعا
    http://www.4shared.com/file/69834499...operation.html
    m_mahmoud
    m_mahmoud غير متواجد حالياً
    شكرا لكم سلام
    Ahmed Adel
    Ahmed Adel غير متواجد حالياً
    جزاكم الله خيرا كثيرا .. وبالتوفيق ان شاء الله ..
    ehab-syria
    ehab-syria غير متواجد حالياً
    شكرا جزيلا وجعله في ميزان حسناتك
    م. فايز عيسى
    م. فايز عيسى غير متواجد حالياً
    الصورة الرمزية م. فايز عيسى
    Received: 13
    معظم الاسئلة موجود جوابها في كتاب gsm system survy اللي طرحته انا وموجود وبامكانك تحمله من المرفقات.
    عندما تكون فلسطينياً.....
    لن تستطيع ان تتمادى بابتسامتك
    فخيالات الأقصى الأسير.. تحاصرك
    ودم صلاح الدين الذي ينبض في شرايينك
    ويذكرك في كل مرة تحاول أن تبتسم بها
    بأن ابتسامتك خيانة.. سيعاقبك عليها التاريخ.
    لن تستطيع أن تنفرد بأحلامك.. فهناك من يشاركك بها
    بل يتربع على عرشها
    فإن كانت أحلام الآخرين
    مالٌ وسلطانٌ وزوجةٌ وأطفال
    فأحلامك.. قيلولة تحت شجرة البرتقال في حيفا
    وفنجان قهوة على ضفاف طبريا
    وصلاة ركعتين ودعاءٌ.. يعرج إلى السماء متتبعاً خطى الحبيب في معراجه من هناك.
    prprange
    prprange غير متواجد حالياً
    اخي العزيز انصحك بدخول الموقع
    www.gsmworld.com
