ما الفرق بين جهد الخضوع yield stressاثناء التصميم ؟Fy
النتائج 11 إلى 20 من 21
    tarek_abulail
    tarek_abulail غير متواجد حالياً
    الصورة الرمزية tarek_abulail
    Received: 69
    Given: 134
    first we appologize if we provided wrong information and i respect ur opinion regarding the cost at last in the total u will pay more if u provide higher grade and i gurantee it for u. again sorry for the conflection and just i want add another equation for the cracking control side reinforcement in the deep members and it will be to deside the diameter comparing with the Fy and spacing and width of member
    }Dia. = Sqrt{Sxb/Fy
    multiply the spacing in mm by the width in mm and devide by Fy in Mpa then take the quare root u will determine the diameter of the bar at the selected S spacing u want .
    still the maximum S that u cannot exceed even u use higher grade steel is 250mm.
    also for the section that u want to reduce it by the reinforcement and im talking in major building with long spans how u will control the deflection most likely 99% u need drop beams in paticular places if not all to control deflection so dont depend on this always that is theoritically but practically still u can say yes or no.
    and thank you again for any correction
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 447
    so we can say using of high grade steel in designing of high stressed sections(which have high straining actions ) is more economic than using of low grade steel and using of low grade steel in designing of simple sections is more economic than using of high grade steel
    finally we must use the grade type when we find it is important for economy as soon as possible
    وليد الثرواني
    وليد الثرواني غير متواجد حالياً
    معلومات مفيدة بارك الله بكم
    asm123
    asm123 غير متواجد حالياً
    Lightbulb
    يا جماعة بكل بساطة هناك انواع من الحديد مثل:-
    حديد grade 60/42 و اجهاد خضوعة 420 MPa
    حديد grade 52/36 و اجهاد خضوعة 360 MPa
    حديد grade 37/24 و اجهاد خضوعة 240 MPa
    حديد grade 41/28 و اجهاد خضوعة 280 MPa
    ولو اخبرنى احد المصنعين انة ينتج حديد اجهاد خضوعة 386.5 MPa فاننى ساستخدم هذا الاجهاد فى التصميم طبقا لشهادات المصنع.
    civilworks
    civilworks غير متواجد حالياً
    Received: 9
    يا أهل الخير ... نوهت بشيئ ..
    نحن نستولرد حديد عز المستخدم في السوق المصري والذي يتم تصميم معظم المباني السكنية في جمهورية مصر العربية به وfy=360 n/mm2
    في حين اننا نظرا لاننا نستخد الكود الامريكي في التصميم .. فاننا نضع fy=420N/mm2
    هل هذا جائز شرعا ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟ لنفس الحديد
    هل يعقل أن الكود الأمريكي واثق في نفسه لدرجة أنه بينه وبين المصري فرق 60N/mm2
    وهذا سيؤثر على القطاع الخرساني فيما بعد ... وعلى التكلفة الكلية ؟؟؟؟؟؟؟؟
    mohy_y2003
    Received: 350
    Given: 447
    لا طبعا بس تقدر تقول ان الكود المصري هو اللي بيعطي معامل امان كافي من وجهة نظرة وذلك من باب الاحتياط او طبقا لابحاث مصريه علي الخامات وظروف التصنيع . يعني الفرق ده ها يمثل تقريبا 15% من قيمة الاجهاد (يعني الكود المصري بيقلل القيمه القصوي للاجهاد في الحديد بحوالي 15% عن الكود الامريكي ) ودي نسبه مش كبيرة في تقدير معاملات الامان للعناصر المختلفه طبقا لظروف التصنيع في كل بلد
    والله الموفق
    tarek_abulail
    Received: 69
    Given: 134
    civil works every thing u should know the derivation of the formulas so u know how to use the value of Fy what ever this is general case u canot use it instead of 420 .
    بعدين يا حبيبي هاي مش انو واثق من نفسه او لا هاي المصمم بختارها يعني انا بدي اصمم العناصر الانشائية باستخدام حديد Fy=420 او 360 او 999 بس بتحط اللي دارج ببلدك هاي هي السولافة وطبعا شيؤثر على المقطع ازا صممت ب 420 وركبت في الواقه 360 العنصر بكون ضعيف لكن ممكن ازا زدت مساحة التسليح بس ما حدا بشتغل هيك صمم 360 وركب 360 الله يطول عمرك
    mohy_y2003
    Received: 350
    Given: 447
    الاخ المهندسcivilworks السلام عليكم ورحمة الله وبركاته
    المفروض انك بتصمم قطاعاتك علي نوعيه حديد معينه ويجب ذكر ذلك في مستندات المشروع سواء الرسومات الانشائيه او الشرزط العامه والخاصه ومواصفات المشروع وبناءا علي ذلك يجب التنفيذ طبقا لهذة المواصفات
    فاذ تعذر توفير نوعية الحديد المطلوب بالسوق يجب مراجعه المصمم لاتخاذ ما يراه مناسبا للمشروع من الناحيه الانشائيه والاقتصاديه ولو ادي ذلك الي تعديل التصميمات لتتماشي مع المتوفر بالاسواق
    mohy_y2003
    Received: 350
    Given: 447
    اما بالنسبه للكود المصري فهو يستخدم حديد400 ومعني ذلك انه موجود بالاسواق المصريه وممكن طلبه من المنتج وذلك يتم عن طريق المقاول اثناء التنفيذ بالموقع بمعني ان المقاول بيشوف الرسومات والمواصفات بتقول ايه ويجب ان ينفذ علي اساسها ويجب ان تتم دراسه اسعارة بناءا علي تلك المواصفات من نوع حديد او نوع خرسانه الخ ( يعني المفروض المقاول يطلب حديد طبقا للرسومات)
    يعني ما نقدرش نقول ان احنا صممنا علي 420 بس اللي في السوق 360 ينفع ولا لا ؟
    لو صممت علي 420 يبقي يتنفذ 420 لو مش موجود يبقي تعاد التصميمات طبقا للحديد المتوفر بالاسواق
    يعني انت كمصمم اللي بتقود تلك العمليه من الالف الي الياء ومن حقك تاخد عينه من الحديد وتبعتها معمل معتمد وتشوف كل خصائصها قبل ماتنفذ اي حاجه بالموقع وتتاكد انها مطابقه لكل المواصفات الفنيه اللي انت عاوزها
    civilworks
    Received: 9
    Ok..
    put a side the steel Fy= 360N/mm^2
    due table (4-1) in the egyption code ,, which verified in Shaker El-Behery Design manual page 386 v.6/2002
    the factors (c/d)max, Rmax, and C1 :
    related to steek grade :
    thus u see that for steel 400/600 of Fy=400N/mm^2
    c/d max = .42 ..... limaitations for chart C page 401
    Rmax = 0.187
    C1min= 2.83 ....... j= 0.721
    if steel 360/520 of Fy =360N/mm^2
    c/d max = 0.44 ............ limitations for chart C page 401
    Rmax= 0.194
    C1 min = 2.78........... j =0.717
    if the Fy =420 or 460 N/mm^2 ... what shall the above factors would be??? i think the only people who response to answer this question ..
    The Egyption Code Experts .... الذين لهم مراس مع التصميم بالكود المصري
