Sap Clarification
النتائج 1 إلى 7 من 7
    الصورة الرمزية tarek_abulail
    tarek_abulail
    tarek_abulail غير متواجد حالياً
    Received: 69
    Given: 134
    Sap Clarification
    What ShoULD WE ASSIGN TO THE
    joint Point Between Column And Slab At The Meeting Point , Or Is It Directly Assumed By Program That The Slab Is Connected To The Column And Delivers The Load To It.please Simple Direct Answer.
    KEF TORBOT EL3AMOD MA3 ELSLABEH:mad:
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 447
    بالظبط يا باشمهندس طارق البرنامج بينقل الحمل من البلاطه الي العمود او الي الكمرة ولازم يكون في عندنقاط الاتصال هذة Joints
    ولكن لو انت عاوز تمنع ان العمود يتحمل عزوم عند نهايته العليا(يعني تعتبرها Hinged Support At Upper End ) بتعلم علي العمود وتدخل في قايمه Assign وتعمل Release للعمودعند نهايته العليا من ان يتحمل عزوم في اتجاه X واتجاة Y
    اللي هي M11 & M22
    tarek_abulail
    Received: 69
    Given: 134
    how u desfine the point between column and slab
    i already draw the column and the slab now at the meeting point what should i do to define this point and u consider the column will take resistance of the moment in both directions.
    mohy_y2003
    Received: 350
    Given: 447
    no need to define it . automatically all joints has 6 unknowns , 3 to prevent the movement on 3 directions axises and 3 to prevent rotation on same directions . then if you need to cancel the resistance of movement of the beam at this joint at any direction just you choose resistancethis beam and make it release at this end in same direction by that this joint has no resistance in this direction you selected
    if the column will take resistance of the moment in both directions just you select this column and choose no release for its upper end and that mean all unknowns at this joint has value and the programe will calculate it and you can obtain from the output graphics and tables
    mohy_y2003
    Received: 350
    Given: 447
    no need to define it . automatically all joints has 6 unknowns , 3 to prevent the movement on 3 directions axises and 3 to prevent rotation on same directions . then if you need to cancel the resistance of movement of the beam at this joint at any direction just you choose this beam and make it release at this end in same direction by that this joint has no resistance in this direction you selected
    tarek_abulail
    Received: 69
    Given: 134
    Thx Man u gave direct answer thanks alot
    mohy_y2003
    Received: 350
    Given: 447
    your welcome engineer tarek
