People living Juda - Japan
النتائج 1 إلى 4 من 4
    الصورة الرمزية معمارية من بغداد
    معمارية من بغداد
    معمارية من بغداد غير متواجد حالياً
    Japan Warns of 4,000 meters of millions of people living Juda
    Core Presentation : Japan in Tokyo idea is the construction of the "X-Seed4000" Juda skyscraper-a 4,000-meter-high, with 800 floors, one million will be living in the building super. Juda this skyscraper construction modeled on the shape of Mount Fuji, but also higher than Mount Fuji 213 meters.Designed primarily to the residents living in 2,000 meters below the floor, and the higher air temperatures likely will be built ski resort facilities.
    Ferris Juda simulation map
    Internal envisaged map
    Farris Juda chart
    Chongqing Morning News on August 27, according to American media reports on the 26th, Japan Da construction company in Tokyo idea is the construction of the "X-Seed4000" Juda skyscraper-a 4,000-meter-high, with 800 floors, one million will be living in the building super. Juda this skyscraper construction modeled on the shape of Mount Fuji, but also higher than Mount Fuji 213 meters.
    The Empire State Building will be nine times higher
    It was reported that according Da construction company's design blueprint, "X-Seed4000" will become Tokyo's city within a city, once completed, "X-Seed4000" Ferris Juda will be the height of the Empire State Building in New York at least nine times, the base will have an area of six square kilometers, is the most major construction -- Boeing Aircraft Company in Washington State's Everett plant six times.
    "X-Seed4000" Ferris Juda will have 800 floors, they can live one million residents. However, Juda penetrated the clouds, the designer must consider the bottom and the top between the temperature and pressure are poor thorny issues. Fortunately, the pyramid-like structure, and can help resist the tallest height of Juda strong winds.
    Large elevators can sit 200 people
       Under the blueprint, "X-Seed4000" Ferris Juda will be a self-supporting eco-city AI, it will hustle and perfect combination of the natural environment, the main structure is steel, and the outside w
    all using solar panels, using solar energy to provide the main energy Juda. Juda house as natural lighting and weather changes under external lighting automatically adjust brightness, the building also has artificial parks and other "natural scenery," Ferris Juda water will be used 100% of the circulating water.
    It is reported that the "X-Seed4000" Ferris Juda will be used to accommodate 200 people while the large magnetic ride elevators, the passengers sit at the top floor from the ground floor, will need to spend 35 minutes. Although it was designed primarily to the residents living in 2,000 meters below the floor, and the higher air temperatures likely will be built ski resort facilities.
    Cost up to 900 billion US dollars
    "X-Seed4000" Ferris Juda cost of about 300 billion US dollars to 900 billion US dollars between its cost than is contained human landing on Mars mission is even higher. 据专家称,建造"X-Seed4000"According to experts, the construction of the "X-Seed4000" Ferris Juda creativity back in the 1980
    s alone, and construction technology already exists, only the astronomical figure of Cost is the main barrier.
    Currently, the construction blueprint has been the subject of lively discussion. Some experts said that such a massive construction, if the frequency of earthquakes in Japan built a stable, preferably on the sea, and not on land."X-Seed4000" Ferris Juda building project can be achieved, it has also attracted many people's doubts.
    أبن الفيحاء-حسن
    أبن الفيحاء-حسن غير متواجد حالياً
    thanks mam
    very good job
    good luck
    med-dz
    med-dz غير متواجد حالياً
    the competition never ends .....
    Very interesting work ....
    thanx a lot for this
    Regards ,
    "Its the Same Old-story ... Well They Just didn't REALIZE"
    معمارية من بغداد
    مشكورين للمرور ...
