Dc أم Ac الجواب الشافي في أيهما أخطر
صفحة 2 من 28 الأولىالأولى 1 23 4 5 6 12 ... الأخيرةالأخيرة
النتائج 11 إلى 20 من 272
    أبو شيرين
    أبو شيرين غير متواجد حالياً
    أخي الكريم - هذه الإجابة حول الفأر الضوئي أو الليزري
    Optical Mice
    Developed by Agilent Technologies and introduced to the world in late 1999, the optical mouse actually uses a tiny camera to take thousands of pictures every second.
    Able to work on almost any surface without a mouse pad, most optical mice use a small, red Light Emmiting Diode (LED) that bounces light off that surface onto a (CMOS) sensor. In addition to LEDs, a recent innovation are laser-based optical mice that detect more surface details compared to LED technology. This results in the ability to use a laser-based optical mouse on even more surfaces than an LED mouse.
    Here's how the sensor and other parts of an optical mouse work together:
    • The CMOS sensor sends each image to a digital signal processor (DSP) for analysis.
    • The DSP detects patterns in the images and examines how the patterns have moved since the previous image.
    • Based on the change in patterns over a sequence of images, the DSP determines how far the mouse has moved and sends the corresponding coordinates to the computer.
    • The computer moves the cursor on the screen based on the coordinates received from the mouse. This happens hundreds of times each second, making the cursor appear to move very smoothly.
    In this photo, you can see the sensor on the bottom of the mouse.
    Optical mice have several benefits over track-ball mice:
    • No moving parts means less wear and a lower chance of failure.
    • There's no way for dirt to get inside the mouse and interfere with the tracking sensors.
    • Increased tracking resolution means a smoother response.
    • They don't require a special surface, such as a mouse pad.
    Apple has transformed its optical mouse into a modern work of art.
    _____________
    كن كالمطر كلما وقع نفع
    ابراهيم ك
    ابراهيم ك غير متواجد حالياً
    الصورة الرمزية ابراهيم ك
    شكرا جزيلا
    اشكرك اخ ابو شيرين على هذا الجواب الشافي و اتمنى ان يستفيد كل الاعضاء من معلوماتك الجميله
    DESKTOP
    DESKTOP غير متواجد حالياً
    الصورة الرمزية DESKTOP
    شكراً أيها الأخ الكريم, الموضوع رائع جدا
    أبو شيرين
    أخي الكريم
    لا أعرف بالضبط ماذا تقصد ب 100 ، 250 ، 400 ، ولكن من المعروف أن خطوط الضغط العالي والمتوسط هي 11 كيلو فولت ، و 33 كيلو فولت ، و 22 كيلو فولت ، أما الفولتية النهائية الشائعة الإستخدام فهي 380 فولت ، 400 فولت ، 416 و 440 فولت ، هذا لل 3 فاز ، أما ل 1 فاز فكما ذكرت فهي وصل أي فاز مع خط نتر ، أي تكون الفولتية مقسومة على جذر 3 ، مثلا من الفولتية 380 ممكن أن نأخذ فولتية 220 فولت (380 مقسومة على جذر 3 ) ، لذلك فللمحولات الخافضة من 11 كيلو فولت إلى 416 فولت يقال:
    Rated Primary Voltage : 11KV
    Secondary Voltage : 416/240V
    ولو كانت 33kv إلى 11kv :
    Rated Primary Voltage : 33KV
    Secondary Voltage : 11KV
    إذا ما يصف المحول هو ثلاث قيم
    1- الفولتية الإبتدائية
    2- الفولتية الثانوية
    3- قدرة المحول
    وعندما نتكلم عن القدرة فإننا نتكلم عن المعامل (كيلو فولت أمبير) (KVA)
    وممكن أن يتم القياس أيضا بالأمبير فالقدرة تقاس بالأمبير أو الكيلو فولت أمبير أو الكيلو واط إذا عرف معامل القدرة.
    وقدرات المحولات متراوحة ما بين 5 كيلو فولت أمبير إلى 20 ميجا فولت أمبير،
    أما ما ذكرته حول أقطار الكيبلات فهو طبيعي فكلما زادت القدرة كلما زاد التيار وبالتالي تحتم أن تكون أقطار الكيبلات أكبر، ولكن عليك أن تنتبه أنه لا يوجد أي رابط بين الفولتية والتيار، فممكن أن يكون التحويل من 11 إلى 440 فولت وتكون القدرة 2 ميجا فولت أمبير ، وممكن أن يكون التحويل 33 إلى 380 وتكون القدرة 5 كيلو فولت أمبير ، (عندما نتكلم عن القدرة فبإمكانك تحويلها الى تيار فورا).
    إذا كان هنالك اي استضاحات فلا تتردد
    _____________
    المهندس
    المهندس غير متواجد حالياً
    ،، المشرف العام ،،
    الصورة الرمزية المهندس
    Received: 273
    Given: 428
    الله يعطيك العافية على هذا الموضوع الرائع ..
    و سيتم إنهاء الموضوع السابق حتى تكون المناقشة الجادة هنا ..
    بارك الله فيك على جهودك ..
    ابراهيم ك
    الى الاخ ابو شيرين المحترم
    من خلال معلوماتك التي تفضلت بها اضافة الى معلوماتي . حصلت على الاستنتاجات التاليه و ارجو الاطلاع عليها.
    سيكون الكلام عن المحولات الخافضه من( 11 kv) الى (380 v ) .
    يتم صنع اسلاك المحوله بكلا الملفات البدائيه و الثانويه من خلال اسلاك ذات قطر واحد حيث يتم تخفيض الفولتيه من ( 11 kv) الى ( 380 v ) للفاز الواحد مع ثبات القدره في المحوله بكلا الملفات الابتدائيه و الثانويه التي بدورها تعتمد على قطر الاسلاك المستخدمه . اذ توجد محولات ذات 400 KW و 250 kW و غير ذلك حيث يكون التيار الناتج للفاز الواحد :
    I =P / V
    تقريبا i = 400KW / 380V =1052 A
    هذا في حالة المحولات ذات 400KW اما في المحولات ذات ال kw 250 فيكون التيار الناتج للفاز الواحد :
    تقريبا i = 250KW / 380 V = 657 A
    نستنتج من ذلك ان القدره تعتمد على التيار المار في الاسلاك الذي بدوره يعتمد على قطر السلك المستخدم. حيث تقوم قدرة المحوله بتحديد عدد المستهلكين .
    ارجو الرد مع التقدير.........
    أبو شيرين
    عزيزي إبراهيم
    أرجو أن تنتبه الى بعض الامور:
    - قطر الأسلاك في الملفات الإبتدائية يختلف عن قطرها في الملفات الثانوية، وهو عادة يعتمد على التيار، فإذا كان محول خافض كما في مثالك فإن قطر الاسلاك في الملفات الابتدائية أصغر بكثير من الملفات الثانوية، إنما يكون عدد اللفات أكبر، مسألة القدرة للمحول هي مسألة تصميم، وأول عامل في التصميم هو إختيار قطر اسلاك الملفات بناءا على التيار الذي هو بدوره محسوب من قدرة المحول.
    تذكر دائما في المحولات المعادلة التالية:
    u2/u1 = n2/n1 = I1/I2
    ففي حالة مثال المحول الذي أعطيته 11KV إلى 380v فإذا كان التيار جهة 380 فولت هي 760 فستكون جهة 11kv حوالي 26 أمبير
    - الخطأ الثاني الذي وقعت به هو طريقة حساب تيار المحول من معرفة القدرة بالكيلو واط وإليك الحل الصحيح:
    P(KW)=I(Amp) X U(Volt) X COS(p) X Sqrt(3) / 1000
    400= I x 380 x 0.8 x 1.73 / 1000
    I= 400000 / 380x0.8x1.73 = 760 Amp
    لقد افترضنا هنا ان معامل القدرة هو 0.8 وهو الشائع، لكن ممكن ان يختلف.
    بنفس الطريقة احسبها للمحول 250 كيلو واط،
    لكن انتبه انه وبسبب عدم وضوح معامل القدرة فإن القياس يعطى دائما بالكيلو فولت وليس كيلو واط، بالتالي فإن محول قدرته 400 كيلو واط ، له قدرة 500 كيلو فولت عند معامل قدرة 0.8
    لكن لي رجاء أن تقوم بطرح هذه الأسئلة في مشاركات أخرى، وذلك لأن الموضوع هنا متخصص في مسألة خطورة التيار
    مع تحياتي
    _____________
    EHV
    EHV غير متواجد حالياً
    أبو شيرين
    كفيت و وفيت
    جزاك الله خيرا
    Nothing is as easy as it looks
    معروف خليفة
    معروف خليفة غير متواجد حالياً
    أظنها معلومات قيمة للأخوة مهندسى مدنى وعمارة ويمكن ميكانيكا , لكن لمهندسى كهرباء , دى تبقى كارثة
    rafidalashor
    rafidalashor غير متواجد حالياً
    جزاك الله خيرا
