Site construction techniques
A P RIMOLDI
The bonding of plates to civil engineering structures has been recognised
as useful since the end of the 1970s. The work is usually carried out in order
to enhance the load-bearing capacity of the structure, either because the
designed loading is likely to be exceeded or because modification or
deterioration of the structure demands it. This chapter describes the techniques
and problems associated with plate bonding in real commercial
situations on construction sites.
THE PDF PAPER TO LEARN
http://www.zshare.net/download/3733923e129954
