ممكن سؤال عن احد البرامج
النتائج 1 إلى 6 من 6
    الصورة الرمزية فائزة احمد
    فائزة احمد
    فائزة احمد غير متواجد حالياً
    رمضان كريم وكل عام وانتم بخير
    هل يوجد برنامج اسمه روتر كاد وهو شبيه بالاوتوكاد ومن لديةاي معلومات يجيبني عنه او الحصول على نسخة من هذا البرنامج
    شكرا على المساعدة يا احلى مهندسين
    benjamin
    benjamin غير متواجد حالياً
    زائر
    هلو فائزة شونج؟
    روتر كاد يتعامل مع الاعمال و الرسومات النجارية ..و تخطيطهن و طبعا فيه ادوات تعطيك نكهة نجارية مثل المنشار و اعرف ايش
    و لمزيد من المعلومات اقري الجوة
    RouterCad is an excellent way to produce all kinds of parts to send to Enroute Wood for automatic toolpath and nesting. It allows easy to understand methods to produce your products accurately and quickly. Call to set up a demonstration. You have to see this process in action. It works on cabinet parts as well as most other type assemblies.
    RouterCAD - 3D CAD Drawing Program. RouterCAD is designed for the professional woodworker. PanelCAD is a standard feature of RouterCAD with AutoShaping Tools for part creation. RouterCAD creates DXF/DWG files with associated TXT/CSV files for data mapping to CAM software.
    Not limited to just cabinet applications.
    RouterCAD
    3D CAD program designed for professional woodworkers. RouterCAD products include DovetailCad, ProjectCAD, MDFDoorCAD, CountertopCAD, PanelCAD and much more in an open design environment. It then exports DXF/DWG/CSV/TXT files for Automatic Tool Paths.
    RouterCAD Control Center - Creates Parametric CNC Operations for a wide range of panel
    parts and cabinets. RCC contains an Order Entry System that creates fully parametric cabinet
    and subassemblies.
    Cabinet Builder is a fully Parametric Order Entry System. Cabinet Builder is a fast and efficient way to produce machine ready parts for a wide range of cabinets and projects. All parts are created in a 3D DXF Layered file format with associated CSV/TXT files. Cabinet Builder is one of the most advanced order entry systems on the market today!
    CountertopCAD - Creates layered DXF/DWG Countertops for the professional countertop
    manufacturer. CountertopCAD exports DXF/DWG files with CSV/TXT files for mapping to
    popular CAM packages.
    CountertopCAD is the best countertop software for the professional countertop manufacturer. CountertopCAD has all the built in features to create 3D custom countertops. Including back splashes, built-up edges ,sink cutouts, and fastener bolts. Special shaping tools that create bull noses, clipped and radius corners. The bid manger is a standard feature in CountertopCAD which exports the bids to Excel.
    Works with solid surface, stone and laminates.
    Machine Bolts can be automatically added to countertop joints. A CNC router can machine all of the bolt notches while the top is nested with other parts on the router table.
    MDFDoorCAD - Creates parametric layered DXF/DWG MDF Doors for use with CNC Routers.
    MDFDoorCAD comes standard with an Order Entry System.
    Call today for more information on this exciting CNC router enhancing software.
    تحياتي
    فائزة احمد
    شكرا جزيلا اخي benjamin على هذي المعلومات الجميلة وعلى الرد السريع
    رمضانك مبارك وينعاد عليك بالصحة والسلامة
    فائزة العراقية
    popzelda
    popzelda غير متواجد حالياً
    بان جمان مرات................ و مرات...............
    grace
    grace غير متواجد حالياً
    بالله عليكم من عنده البرنامج هدا ارسله لى advanced design system software ضرورى جدا ردوا على باقرب فرصة
    شيروووو
    شيروووو غير متواجد حالياً
    سوف تجد advanced design system software في الموقع المرفق http://http://www.download.com/3001-...255.html?idl=n وبالتوفيق .
