ماذا تعرف عن Clean Diesel Fuel
النتائج 1 إلى 7 من 7
    الصورة الرمزية طارق بويرق
    طارق بويرق
    طارق بويرق غير متواجد حالياً
    عزيزي
    Clean Diesel Fuel Overview
    For many American consumers, the word "diesel" conjures images of smoke-belching semis and clattery, smelly passenger vehicles. Those negative perceptions are true to a degree: Despite their superior fuel efficiency, diesel engines have a few practical disadvantages. Recent engine technology advancements have made great strides in minimizing the noise and vibration traditionally associated with diesels, but one major demerit remains: subpar emissions quality.
    Clean Diesel Fuel Alliance
    Ultra low sulphur diesel fuel stickers are madated by the EPA
    to appear on diesel pumps at gas stations.
    The exhaust fumes from a typical diesel engine are much "dirtier" than a comparable gasoline engine's. Not only is diesel smoke unpleasant, studies have shown it to be unhealthy for humans and the environment. The government is currently taking steps to make diesel vehicles much cleaner: the U.S. Environmental Protection Agency has recently implemented new laws that mandate the use of a new, cleaner-burning type of diesel fuel named ultra-low sulphur diesel, or ULSD. The EPA's new standards will have significant effects on the petroleum industry, automakers, and consumers.
    We'll explore just what ULSD is and the impact it will have on the industry and consumers in the following sections:
    Understanding Ultra Low Sulphur Diesel Fuel
    ULSD is a cleaner, more refined fuel than the previous standard for diesel. We'll examine what makes it different, and explain the recently enacted government regulations that will govern the changeover to ULSD. You'll also learn about particulate filters, the next-generation emissions control system that works in concert with ULSD fuel. These advanced filters clean diesel exhaust fumes before they exit the vehicle's exhaust system. We'll also explain why the "old" diesel fuel should not be used with this new technology.
    How Does Ultra Low Sulphur Diesel Fuel Affect You?
    ULSD is spurring significant changes in the diesel vehicle marketplace. Mercedes-Benz is the first auto manufacturer to introduce passenger vehicles that are designed to run on ULSD, but more are sure to follow. We'll look at Mercedes' current crop of ULSD vehicles for 2007, and what the manufacturer has on deck for 2008. We'll also preview new products on the horizon from other manufacturers, and examine how Mercedes' new diesel models stack up against comparable gas/electric hybrid models on sticker price and fuel economy.
    Ultra-Low Sulphur Diesel Fuel Explained
    What is Ultra Low Sulphur Diesel (ULSD) fuel? In a nutshell, it's cleaner diesel. Ultra low sulphur diesel fuel has been refined so that its sulphur ******* is 15 parts per million (ppm) or less. This is 97 percent cleaner than the standard highway-use diesel fuel sold in the US, which contains an average of 500 ppm of sulphur. Sulphur, a natural part of the crude oil from which diesel fuel is derived, is one of the key causes of particulates or soot in diesel. Soot is the main culprit of diesel engines' noxious black exhaust fumes, and is among the prime contributors to air pollution. The move toward ULSD is aimed at lowering diesel engines' harmful exhaust emissions and improving air quality.
    ULSD fuel has been the standard in Europe for several years. In the U.S., the changeover process began in June 2006, when the EPA enacted a mandate requiring 80 percent of the highway diesel fuel produced or imported to meet the 15 ppm standard. The new ULSD fuel went on sale at most stations nationwide in mid-October 2006. Both diesel fuels will be on sale for the next few years, with the goal being a gradual phaseout of 500 ppm diesel. By December 2010, all highway-use diesel fuel offered for sale in the U.S. must be ULSD fuel. (ULSD is not to be confused with biodiesel, which is diesel derived from biological ingredients such as plant oil or animal fat and usually blended with standard diesel fuel.)
    ULSD fuel will work in concert with a new generation of diesel engines that will begin arriving for the 2007 model year. Ideally, ULSD will enable the new generation of diesel vehicles to meet the same strict emission standards as gasoline-powered vehicles. The new engines will utilize an emissions-reducing device called a particulate filter. The process is similar to a self-cleaning oven's cycle: a filter traps the tiny particles of soot in the exhaust fumes. The filter uses a sensor that measures back pressure, or the force required to push the exhaust gases out of the engine and through to the tailpipes.
    The particulate filter traps the particles of soot in the exhaust.
    As the soot particles in the particulate filter accumulate, the back pressure in the exhaust system increases. When the pressure builds to a certain point, the sensor tells the engine management computer to inject more fuel into the engine. This causes heat to build up in the front of the filter, which burns up the accumulated soot particles. The entire cycle occurs within a few minutes and is undetectable by the vehicle's driver.
    With appropriate vehicle maintenance, ULSD fuel is expected to be fully compatible with 2006 and earlier diesel engines and perform as well as previous diesel fuels in normal operating conditions. Diesel engines manufactured for the 2007 model year and later will utilize some type of particulate filter and will be designed to run solely on ULSD fuel. The use of non-ULSD fuel in these engines is illegal, as the higher sulphur ******* will prevent the particulate filter and other emissions controls from working properly. And, since non-ULSD fuel will damage the engine over time, its use will likely void the vehicle's warranty.
    In the next section, we'll explore the recent changes in the diesel marketplace, and how auto manufacturers are adapting.
    Ultra-Low Sulphur Diesel Fuel Vehicles
    Concerns about the world's oil supply and ever-rising fuel prices have brought a renewed focus on diesel's superior fuel economy. Because of their unique engine design, diesel engines are typically 20 percent to 40 percent more fuel-efficient than comparable gasoline engines. A 2004 EPA study concluded that if just one-third of light-duty trucks in the U.S. were operated with state-of-the-art diesel engines, the country would save 1.4 million barrels a day -- equal to the amount the USA currently imports from Saudi Arabia. A recent J.D. Power study predicts that diesel sales will trend upward, comprising 11.8 percent of the market in 2015 as opposed to the 3.6 percent they comprise today.
    Mercedes-Benz' Bluetec diesel technology is available in the GL320,
    ML320, and R320 [from left to right].
    The transition to clean diesel will have a definite impact on future consumer choices, as automakers formulate strategies and introduce new passenger vehicles to take advantage of this shifting market. Mercedes-Benz has recently debuted four new 2007 models (one car and three SUVs) that utilize the company's new Bluetec diesel V6 engine. DaimlerChrysler has also announced its Jeep division will offer the new Mercedes-built diesel V6 in the 2007 Jeep Grand Cherokee. These vehicles meet the EPA's BIN 8 emissions requirements, making them legal for sale in 45 states. (California, Maine, Massachusetts, New York, and Vermont adhere to stricter BIN 5 emissions requirements for passenger vehicles.)
    For the 2008 model year, Mercedes plans to equip its diesel engines with a urea-injection system, which it has dubbed AdBlue. The system adds measured quantities of a urea-based solution into the exhaust stream to help reduce nitrogen oxide emissions. The AdBlue system should enable Mercedes' future diesels to reach BIN 5 emissions requirements for 50-state legality.
    More new products are on the horizon. Honda has announced a next-generation diesel engine that it plans to release in the U.S. by 2009. The Honda engine will utilize a dual-stage catalytic converter that converts nitrogen oxide exhaust emissions into ammonia and then into harmless nitrogen gas. Honda claims the new engine will meet BIN 5 requirements and achieve emissions as clean as a gasoline engine's. General Motors and Volkswagen, among other manufacturers, are expected to launch new diesel-powered models within the same 2009 timeframe. Some industry analysts have likened the current ULSD changeover to the mid-1970s changeover from leaded to unleaded gasoline, which was implemented in part to enable the use of emissions-reducing catalytic converters. Proponents of ULSD are hopeful that the switch to clean diesel will have a similar positive impact on the environment.
    Diesel and Hybrid Comparison
    Like previous diesel passenger vehicles, the new generation of ULSD-fueled vehicles will cost more than their non-diesel counterparts. However, the sticker-price hike should be less than the current premium for gas/electric hybrid technology. Mercedes-Benz's 2007 Bluetec diesel models start at $1000 more than their gasoline siblings. Most 2007 hybrid vehicles demand a premium of $2500-$3700 over the comparable non-hybrid versions.
    In the arena of fuel economy, let's look at how the Mercedes diesels stack up against a pair of comparable luxury gas/electric hybrid vehicles. The Mercedes-Benz E320 Bluetec sedan is EPA rated at 26 mpg city/37 mpg highway. The 2007 Lexus GS 450h sedan, while it provides slightly better acceleration, is rated at 25/28 mpg. The Mercedes-Benz ML320 CDI sport-utility vehicle is rated at 21/27 mpg. The 2007 Lexus RX 400h hybrid SUV is rated at 31/27 mpg -- more efficient in city driving, but the same on the highway.
    Judging from these early examples, it appears that the next generation of diesel vehicles will be viable competitors in the automotive marketplace. There are still challenges to overcome, but the potential benefits are clear: ULSD and the new emissions-reducing technology that it facilitates will help make the air cleaner and healthier for everyone.
    شكرى محمد نورى
    Received: 62
    الأخ طارق بويرق .
    تحياتي الطيبة .
    لزيادة الأطلاع والردود والمناقشة والحوار يستحسن الكتابة بالعربي .
    وذلك لكسر حالة الجمود .
    تسلم لنا نثمن جهودك وحضورك الدائم .
    البغدادي
    DrClick
    DrClick غير متواجد حالياً
    عضو تحرير المجلة
    عارفين لية نيوتن كان بيكتب كتبة بالاتيني؟
    مهندس أيمن حسن
    الصورة الرمزية مهندس أيمن حسن
    Received: 96
    Given: 12
    جزاك الله خيرا
    safa aldin
    safa aldin غير متواجد حالياً
    عضو متميز جداً
    Received: 21
    Given: 3
    جزاك الله خيــــــــــــــــــــــــــــــــــــــــــــــــ ــــــــــرا
    Hydra
    Hydra غير متواجد حالياً
    الصورة الرمزية Hydra
    اقتباس المشاركة الأصلية كتبت بواسطة drclick مشاهدة المشاركة
    ليش كان يكتبها بالاتيني يا اخي؟؟
    safa aldin
    عضو متميز جداً
    Received: 21
    Given: 3
    رد: ماذا تعرف عن Clean Diesel Fuel
    جزاك الله خيرا
