shear connection
النتائج 1 إلى 3 من 3
    tafatneb_dichar
    tafatneb_dichar غير متواجد حالياً
    shear connection
    The concrete floor slab is continuous
    over the steel I-sections, and is supported by them. It is designed
    to span in the j-direction in the same way as when supported by walls or
    the ribs of reinforced concrete T-beams. When shear connection is provided
    between the steel member and the concrete slab, the two together
    span in the x-direction as a composite beam. The steel member has not
    been described as a 'beam', because its main function at mid-span is to
    resist tension, as does the reinforcement in a T-beam. The compression
    is assumed to be resisted by an 'effective' width of slab,
    the pdf paper to learn
    http://www.zshare.net/download/3555029ef951f2/
    rachid from algeria
    almass
    almass غير متواجد حالياً
    Received: 177
    Given: 474
    مشكوووووووور اخي
    ميتركس العراق
    ميتركس العراق غير متواجد حالياً
    اخي مشكور
    وارجو ان تثريني بهكذا مواضيع مهمة
    وخصوصا حول composite لأنه موضوع مهم جدا
