Continuous beams and slabs,and beams in frames
النتائج 1 إلى 6 من 6
    tafatneb_dichar
    tafatneb_dichar غير متواجد حالياً
    A continuous beam in a building may be interrupted by its supporting
    internal columns; and these members are usually part of a framed structure.
    The type of beam-to-column joints used influences the global analysis of
    all the members in their vicinity. The terminology and definitions for
    joints used in EN 1994-1-1 follow those given in EN 1993-1-8, Design of
    joints [10], which are now summarised.
    • Connection: location at which two members are interconnected, and
    assembly of connection elements and - in the case of a major axis
    joint - the load introduction into the column web panel.
    • Joint: assembly of basic components that enables members to be
    connected together in such a way that the relevant internal forces and
    moments can be transferred between them.
    the pdf paper to learn
    http://www.zshare.net/download/35026952641eb5/
    bilal_izaddin
    bilal_izaddin غير متواجد حالياً
    الصورة الرمزية bilal_izaddin
    thx a lot Dear
    tafatneb_dichar
    اقتباس المشاركة الأصلية كتبت بواسطة bilal_izaddin مشاهدة المشاركة
    thx a lot Dear
    thank you my brother
    dodyrewishmoot
    dodyrewishmoot غير متواجد حالياً
    thanx alot..for ur efforts
    tafatneb_dichar
    اقتباس المشاركة الأصلية كتبت بواسطة dodyrewishmoot مشاهدة المشاركة
    thank you :) y
    zmry1965
    zmry1965 غير متواجد حالياً
    جزاك الله خيراً
