logic gate
النتائج 1 إلى 8 من 8
    mido_bigshow
    mido_bigshow غير متواجد حالياً
    logic gate
    Logic Gate
    AND | OR | XOR | NOT | NAND | NOR | XNOR
    A logic gate is an elementary building block of a digital circuit. Most logic gates have two inputs and one output. At any given moment, every terminal is in one of the two binary conditions low (0) or high (1), represented by different voltage levels. The logic state of a terminal can, and generally does, change often, as the circuit processes data. In most logic gates, the low state is approximately zero volts (0 V), while the high state is approximately five volts positive (+5 V).
    There are seven basic logic gates: AND, OR, XOR, NOT, NAND, NOR, and XNOR.
    The AND gate is so named because, if 0 is called "false" and 1 is called "true," the gate acts in the same way as the logical "and" operator. The following illustration and table show the circuit symbol and logic combinations for an AND gate. (In the symbol, the input terminals are at left and the output terminal is at right.) The output is "true" when both inputs are "true." Otherwise, the output is "false."
    AND gate
    Input 1Input 2Output000010100
    111The OR gate gets its name from the fact that it behaves after the fashion of the logical inclusive "or." The output is "true" if either or both of the inputs are "true." If both inputs are "false," then the output is "false."
    OR gate
    Input 1Input 2Output000011101111
    The XOR (exclusive-OR) gate acts in the same way as the logical "either/or." The output is "true" if either, but not both, of the inputs are "true." The output is "false" if both inputs are "false" or if both inputs are "true." Another way of looking at this circuit is to observe that the output is 1 if the inputs are different, but 0 if the inputs are the same.
    XOR gate
    Input 1Input 2Output000011101110A logical inverter, sometimes called a NOT gate to differentiate it from other types of electronic inverter devices, has only one input. It reverses the logic state.
    Inverter or NOT gate
    InputOutput10
    01The NAND gate operates as an AND gate followed by a NOT gate. It acts in the manner of the logical operation "and" followed by negation. The output is "false" if both inputs are "true." Otherwise, the output is "true."
    NAND gate
    Input 1Input 2Output001011101110The NOR gate is a combination OR gate followed by an inverter. Its output is "true" if both inputs are "false." Otherwise, the output is "false."
    NOR gate
    Input 1Input 2Output001010100110The XNOR (exclusive-NOR) gate is a combination XOR gate followedby an inverter. Its output is "true" if the inputs are the same, and"false" if the inputs are different.
    XNOR gate
    Input 1Input 2Output001010100111
    Using combinations of logic gates, complex operations can be performed. In theory, there is no limit to the number of gates that can be arrayed together in a single device. But in practice, there is a limit to the number of gates that can be packed into a given physical space. Arrays of logic gates are found in digital integrated circuits (ICs). As IC technology advances, the required physical volume for each individual logic gate decreases and digital devices of the same or smaller size become capable of performing ever-more-complicated operations at ever-increasing speeds.
    منقول
    م.محمد الكسواني
    م.محمد الكسواني غير متواجد حالياً
    Received: 16
    Thank you very much...
    geniusse01
    geniusse01 غير متواجد حالياً
    مشكووووووور على الموضوع يا باشا.
    محمد آل عيسى
    محمد آل عيسى غير متواجد حالياً
    شكرا جزيلا
    e_faisal83
    e_faisal83 غير متواجد حالياً
    مشكووووووووووووووور
    عمان16
    عمان16 غير متواجد حالياً
    موضوع رائع...
    kalcol
    kalcol غير متواجد حالياً
    مشكورر على الجهد المبذول
    وجاء هذا الدرس في وقته
    مشكوووووووووور
    SKR
    SKR غير متواجد حالياً
    مشكوووووووووور مجهود رائع
