;control theory; مبادئ علم السيطرة ((نظرية))
النتائج 1 إلى 10 من 22
    الصورة الرمزية حسن هادي
    حسن هادي
    حسن هادي غير متواجد حالياً
    الاخوة الاعزاء /تحية طيبة نقدم لكم موضوعا في علم السيطرة والتحكم وذلك بعد مواضيع التوربينات ومحطات القدرة الحرارية والنووية اذ اننا نلاحظ ان عملية التحكم تعتبر عمليةجوهرية وتدخل في تشعبات الاختصاصات الهندسية كون علم السيطرة يعد من المواضيع المشركة لمختلف الاقسام الهندسية كل ينظر له من زاويته الخاصة *هذا وتقبلوا تحياتي اخوكم حسن *
    حسن هادي
    For control theory in psychology and sociology, see control theory (sociology).
    Control theory is an interdisciplinary branch of engineering and mathematics, that deals with the behavior of dynamical systems. The desired output of a system is called the reference. When one or more output variables of a system need to follow a certain reference over time, a controller manipulates the inputs to a system to obtain the desired effect on the output of the system.
    الروابط فعالة مع التقدير*
    حسن هادي
    Overview
    Control theory is
    An example
    Consider an automobile's cruise control, which is a device designed to maintain a constant vehicle speed. The output variable of the system is vehicle speed. The input variable is the engine's throttle position which influences engine torque output.
    A simple way to implement cruise control is to lock the throttle position when the driver engages cruise control. However, on hilly terrain, the vehicle will slow down going uphill and accelerate going downhill. This type of controller is called an open-loop controller because there is no direct connection between the output of the system and its input.
    In a closed-loop control system, a feedback controller monitors the vehicle's speed and adjusts the throttle as necessary to maintain the desired speed. This feedback compensates for disturbances to the system, such as changes in slope of the ground or wind speed.
    [History
    Although control systems of various types date back to antiquity, a more formal analysis of the field began with a dynamics analysis of the centrifugal governor, conducted by the physicist James Clerk Maxwell in 1868 entitled On Governors[1]. This described and analyzed the phenomenon of "hunting," in which lags in the system can lead to overcompensation and unstable behavior. This generated a flurry of interest in the topic, during which Maxwell's classmate Edward John Routh generalized the results of Maxwell for the general class of linear systems. Independently, Adolf Hurwitz analyzed system stability using differential equations in 1877. This result is called the Routh-Hurwitz Criterion.
    A notable application of dynamic control was in the area of manned flight. The Wright Brothers made their first successful test flights on December 17, 1903 and were distinguished by their ability to control their flights for substantial periods (more so than the ability to produce lift from an airfoil, which was known). Control of the airplane was necessary for safe flight.
    By World War II, control theory was an important part of fire-control systems, guidance systems, and electronics. The Space Race also depended on accurate spacecraft control. However, control theory also saw an increasing use in fields such as economics and sociology.
    حسن هادي
    من خلال موسوعة الويكيبيديا نقدم هذا الموضوع بروابطه واليكم الروابط ذات المواضيع الممتعة تاريخيا ً*
    People in systems and control
    Main article: People in systems and control
    A lot of active and historical figures made significant contribution to control theory, for example:
    حسن هادي
    Classical control theory: the closed-loop controller
    To avoid the problems of the open-loop controller, control theory introduces feedback. A closed-loop controller uses feedback to control states or outputs of a dynamical system. Its name comes from the information path in the system: process inputs (e.g. voltage applied to an electric motor) have an effect on the process outputs (e.g. velocity or torque of the motor), which is measured with sensors and processed by the controller; the result (the control signal) is used as input to the process, closing the loop.
    Closed-loop controllers have the following advantages over open-loop controllers:
    • disturbance rejection (such as unmeasured friction in a motor)
    • guaranteed performance even with model uncertainties, when the model structure does not match perfectly the real process and the model parameters are not exact
    • unstable processes can be stabilized
    • reduced sensitivity to parameter variations
    • improved reference tracking performance
    In some systems, closed-loop and open-loop control are used simultaneously. In such systems, the open-loop control is termed feedforward and serves to further improve reference tracking performance.
    A common closed-loop controller architecture is the PID controller.
    The output of the system y(t) is fed back to the reference value r(t), through a sensor measurement. The controller C then takes the error e (difference) between the reference and the output to change the inputs u to the system under control P. This is shown in the figure. This kind of controller is a closed-loop controller or feedback controller.
    This is called a single-input-single-output (SISO) control system; MIMO (i.e. Multi-Input-Multi-Output) systems, with more than one input/output, are common. In such cases variables are represented through vectors instead of simple scalar values. For some distributed parameter systems the vectors may be infinite-dimensional (typically functions).
    If we assume the controller C and the plant P are linear and time-invariant (i.e.: elements of their transfer function C(s) and P(s) do not depend on time), the systems above can be analysed using the Laplace transform on the variables. This gives the following relations:
    Solving for Y(s) in terms of R(s) gives:
    The term is referred to as the transfer function of the system. The numerator is the forward gain from r to y, and the denominator is one plus the loop gain of the feedback loop. If , i.e. it has a large norm with each value of s, then Y(s) is approximately equal to R(s). This means simply setting the reference controls the output.
    حسن هادي
    Topics in control theory
    Stability
    Stability (in control theory) often means that for any bounded input over any amount of time, the output will also be bounded. This is known as BIBO stability (see also Lyapunov stability). If a system is BIBO stable then the output cannot "blow up" (i.e., become infinite) if the input remains finite. Mathematically, this means that for a causal linear continuous-time system to be stable all of the poles of its transfer function must
    OR
    In the two cases, if respectively the pole has a real part strictly smaller than zero or a modulus strictly smaller than one, it is asymptotically stable: the variables of an asymptotically stable control system always decrease from their initial value and do not show permanent oscillations, which are instead present if a pole has a real part exactly equal to zero (or a modulus equal to one). If a simply stable system response neither decays nor grows over time, and has no oscillations, it is marginally stable: in this case it has non-repeated poles along the vertical axis (i.e. their real and complex component is zero). Oscillations are present when poles with real part equal to zero have an imaginary part not equal to zero.
    Differences between the two cases are not a contradiction. The Laplace transform is in Cartesian coordinates and the Z-transform is in circular coordinates, and it can be shown that
    • the negative-real part in the Laplace domain can map onto the interior of the unit circle
    • the positive-real part in the Laplace domain can map onto the exterior of the unit circle
    If the system in question has an impulse response of
    x[n] = 0.5nu[n] and considering the Z-transform (see this example), it yields
    which has a pole in z = 0.5 (zero imaginary part). This system is BIBO (asymptotically) stable since the pole is inside the unit circle.
    However, if the impulse response was
    x[n] = 1.5nu[n] then the Z-transform is
    which has a pole at z = 1.5 and is not BIBO stable since the pole has a modulus strictly greater than one.
    Numerous tools exist for the analysis of the poles of a system. These include graphical systems like the root locus , Bode plots or the Nyquist plots.
    م/محمد لطفي
    م/محمد لطفي غير متواجد حالياً
    الصورة الرمزية م/محمد لطفي
    جزاك الله خيرا
    لمشاهده احدث المواضيع والمشاركات يمكنكم زياره هذا المنتدي
    www.eng2all.com/vb
    حسن هادي
    اقتباس المشاركة الأصلية كتبت بواسطة م/محمد لطفي مشاهدة المشاركة
    جزاك الله خيرا
    بارك الله بك يا م/محمد وتقبل تحياتي
    حسن هادي
    Controllability and observability
    Controllability and observability are main issues in the analysis of a system before deciding the best control strategy to be applied. Controllability is related to the possibility of forcing the system into a particular state by using an appropriate control signal. If a state is not controllable, then no signal will ever be able to stabilize the system. Observability instead is related to the possibility of "observing", through output measurements, the state of a system. If a state is not observable, the controller will never be able to correct the closed-loop behaviour if such a state is not desirable.
    From a geometrical point of view, looking at the states of each variable of the system to be controlled, every "bad" state of these variables must be controllable and observable to ensure a good behaviour in the closed-loop system. That is, if one of the eigenvalues of the system is not both controllable and observable, this part of the dynamics will remain untouched in the closed-loop system. If such an eigenvalue is not stable, the dynamics of this eigenvalue will be present in the closed-loop system which therefore will be unstable. Unobservable poles are not present in the transfer function realization of a state-space representation, which is why sometimes the latter is preferred in dynamical systems analysis.
    Solutions to problems of uncontrollable or unobservable system include adding actuators and sensors.
    [edit] Control specifications
    Several different control strategies have been devised in the past years. These vary from extremely general ones (PID controller), to others devoted to very particular classes of systems (especially robotics or aircraft cruise control).
    A control problem can have several specifications. Stability, of course, is always present: the controller must ensure that the closed-loop system is stable, regardless of the open-loop stability. A poor choice of controller can even worsen the stability of the open-loop system, which must normally be avoided. Sometimes it would be desired to obtain particular dynamics in the closed loop: i.e. that the poles have , where is a fixed value strictly greater than zero, instead of simply ask that Re[λ] < 0.
    Another typical specification is the rejection of a step disturbance; including an integrator in the open-loop chain (i.e. directly before the system under control) easily achieves this. Other classes of disturbances need different types of sub-systems to be included.
    Other "classical" control theory specifications regard the time-response of the closed-loop system: these include the rise time (the time needed by the control system to reach the desired value after a perturbation), peak overshoot (the highest value reached by the response before reaching the desired value) and others (settling time, quarter-decay). Frequency domain specifications are usually related to robustness (see after).
    Modern performance assessments use some variation of integrated tracking error (IAE,ISA,CQI).
    حسن هادي
    [ Model identification and robustness
    Main article: System identification
    A control system must always have some robustness property. A robust controller is such that its properties do not change much if applied to a system slightly different from the mathematical one used for its synthesis. This specification is important: no real physical system truly behaves like the series of differential equations used to represent it mathematically. Typically a simpler mathematical model is chosen in order to simplify calculations, otherwise the true system dynamics can be so complicated that a complete model is impossible.
    [edit] System identification
    The process of determining the equations that govern the model's dynamics is called system identification. This can be done off-line: for example, executing a series of measures from which to calculate an approximated mathematical model, typically its transfer function or matrix. Such identification from the output, however, cannot take account of unobservable dynamics. Sometimes the model is built directly starting from known physical equations: for example, in the case of a mass-spring-damper system we know that . Even assuming that a "complete" model is used in designing the controller, all the parameters included in these equations (called "nominal parameters") are never known with absolute precision; the control system will have to behave correctly even when connected to physical system with true parameter values away from nominal.
    Some advanced control techniques include an "on-line" identification process (see later). The parameters of the model are calculated ("identified") while the controller itself is running: in this way, if a drastic variation of the parameters ensues (for example, if the robot's arm releases a weight), the controller will adjust itself consequently in order to ensure the correct performance.
    [edit] Analysis
    Analysis of the robustness of a SISO control system can be performed in the frequency domain, considering the system's transfer function and using Nyquist and Bode diagrams. Topics include phase margin and amplitude margin. For MIMO and, in general, more complicated control systems one must consider the theoretical results devised for each control technique (see next section): i.e., if particular robustness qualities are needed, the engineer must shift his attention to a control technique including them in its properties.
    [edit] Constraints
    A particular robustness issue is the requirement for a control system to perform properly in the presence of input and state constraints. In the physical world every signal is limited. It could happen that a controller will send control signals that cannot be followed by the physical system: for example, trying to rotate a valve at excessive speed. This can produce undesired behavior of the closed-loop system, or even break actuators or other subsystems. Specific control techniques are available to solve the problem: model predictive control (see later), and anti-wind up systems. The latter consists of an additional control block that ensures that the control signal never exceeds a given threshold.
    [edit] Main control strategies
    Every control system must guarantee first the stability of the closed-loop behavior. For linear systems, this can be obtained by directly placing the poles. Non-linear control systems use specific theories (normally based on Aleksandr Lyapunov's Theory) to ensure stability without regard to the inner dynamics of the system. The possibility to fulfill different specifications varies from the model considered and the control strategy chosen. Here a summary list of the main control techniques is shown:
    [edit] PID controllers
    Main article: PID controller
    The PID controller is probably the most-used feedback control design, being the simplest one. "PID" means Proportional-Integral-Derivative, referring to the three terms operating on the error signal to produce a control signal. If u(t) is the control signal sent to the system, y(t) is the measured output and r(t) is the desired output, and tracking error e(t) = r(t) − y(t), a PID controller has the general form
    The desired closed loop dynamics is obtained by adjusting the three parameters KP, KI and KD, often iteratively by "tuning" and without specific knowledge of a plant model. Stability can often be ensured using only the proportional term. The integral term permits the rejection of a step disturbance (often a striking specification in process control). The derivative term is used to provide damping or shaping of the response. PID controllers are the most well established class of control systems: however, they cannot be used in several more complicated cases, especially if MIMO systems are considered.
    [edit] Direct pole placement
    Main article: State space (controls)
    For MIMO systems, pole placement can be performed mathematically using a State space representation of the open-loop system and calculating a feedback matrix assigning poles in the desired positions. In complicated systems this can require computer-assisted calculation capabilities, and cannot always ensure robustness. Furthermore, all system states are not in general measured and so observers must be included and incorporated in pole placement design.
    [edit] Optimal control
    Main article: Optimal control
    Optimal control is a particular control technique in which the control signal optimizes a certain "cost index": for example, in the case of a satellite, the jet thrusts needed to bring it to desired trajectory that consume the least amount of fuel. Two optimal control design methods have been widely used in industrial applications, as it has been shown they can guarantee closed-loop stability. These are Model Predictive Control (MPC) and Linear-Quadratic-Gaussian control (LQG). The first can more explicitly take into account constraints on the signals in the system, which is an important feature in many industrial processes. However, the "optimal control" structure in MPC is only a means to achieve such a result, as it does not optimize a true performance index of the closed-loop control system. Together with PID controllers, MPC systems are the most widely used control technique in process control.
    [edit] Adaptive control
    Main article: Adaptive control
    Adaptive control uses on-line identification of the process parameters, or modification of controller gains, thereby obtaining strong robustness properties. Adaptive controls were applied for the first time in the aerospace industry in the 1950s, and have found particular success in that field.
    [edit] Intelligent control
    Main article: Intelligent control
    Intelligent control use various AI computing approaches like neural networks, Bayesian probability, fuzzy logic, machine learning, evolutionary computation and genetic algorithms to control a dynamic system
    [edit] Non-linear control systems
    Main article: Non-linear control
    Processes in industries like robotics and the aerospace industry typically have strong non-linear dynamics. In control theory it is sometimes possible to linearize such classes of systems and apply linear techniques: but in many cases it can be necessary to devise from scratch theories permitting control of non-linear systems. These normally take advantage of results based on Lyapunov's theory. Differential geometry has been widely used as a tool for generalizing well-known linear control concepts to the non-linear case, as well as showing the subtleties that make it a more challenging problem.
