Strength Evaluation of Existing Concrete Buildings
النتائج 1 إلى 4 من 4
    tafatneb_dichar
    tafatneb_dichar غير متواجد حالياً
    The strength of existing concrete buildings and structures can be evaluated
    analytically or in conjunction with a load test. The recommendations in
    this report indicate when such an evaluation may be needed, establish
    criteria for selecting the evaluation method, and indicate the data and
    background information necessary for an evaluation. Methods of determining
    material properties used in the analytical and load tests investigation are
    described in detail. Analytical investigations should follow the principles of
    strength design outlined in ACI 318. Working stress analysis can supplement
    the analytical investigations by relating the actual state of stress in structural
    components to the observed conditions. Procedures for conducting
    static load tests and criteria indicated for deflection under load and
    recovery are recommended.
    *******S
    Chapter 1—Introduction, p. 437R-2
    1.1—Scope
    1.2—Applications
    1.3—Exceptions
    1.4—Categories of evaluation
    1.5—Procedure for a structural evaluation
    1.6—Commentary
    1.7—Organization of the report
    Chapter 2—Preliminary investigation, p. 437R-3
    2.1—Review of existing information
    2.2—Condition survey of the building
    Chapter 3—Methods for material evaluation,
    p. 437R-9
    3.1—Concrete
    3.2—Reinforcing steel
    Chapter 4—Assessment of loading conditions and
    selection of evaluation method, p. 437R-14
    4.1—Assessment of loading and environmental conditions
    4.2—Selecting the proper method of evaluation
    Reported by ACI Committee 437
    the pdf paper to learn
    http://www.zshare.net/download/3372511e0535b4/
    rachid from algeria
    عصام رزق محمد
    عصام رزق محمد غير متواجد حالياً
    Received: 13
    ACI 437R-03
    هذا الملف خاص بالكود الامريكي وهذا للتوضيح وشكرا.
    من لا يشكر الناس.......................لا يشكر الله
    tafatneb_dichar
    اقتباس المشاركة الأصلية كتبت بواسطة عصام رزق محمد مشاهدة المشاركة
    ACI 437R-03
    c'est mentionné que c'est le code américain , américan concrete institute , ou est le problème ?
    MERCI
    tafatneb_dichar
    ACI 437R-03
    YOU NEED THE FRENCH CODE ,?
