موقع علمي لا استطيع وصفه
صفحة 1 من 6 12 3 4 5 ... الأخيرةالأخيرة
النتائج 1 إلى 10 من 56
    الصورة الرمزية يحي الحربي
    يحي الحربي
    يحي الحربي غير متواجد حالياً
    عضو فائق التميز
    Received: 16
    في هذا الموقع تجد معلومات وعلاقات رياضية لمواضيع علمية متعددة مثل
    Tables of Physical Data
    Mechanical Electrical Thermodynamic
    Optics Astronomy Acoustics
    Modern physics Solids Acoustics
    Nuclear Physics Chemical Geophysical
    Biological and biochemical
    Data for Electricity and Magnetism
    Resistivity Conductivity of elements
    Ferromagnet Curie temperatures
    Electical wire gauges
    Superconducting transition
    temperatures
    Wiedemann-Franz Ratio
    Dielectric Constants
    Magnetic Susceptibilities
    Magnetic Properties
    ASCII Code
    Data for Heat and Thermodynamics
    Specific heats Water vapor pressure Thermal conductivity
    Molar heat capacity, gases Thermal expansion coefficients Insulation R-Value
    Thermodynamic Properties Wiedemann-Franz Ratio Debye temperatures
    Triple Points Melting points, Heat of fusion Boiling points, Heat of vaporization
    Temperature standard points van der Waals coefficients
    Data for Mechanics
    Densities Young's Modulus
    Compressibilities of Liquids
    Properties of Liquids
    Viscosity
    Data for Optics
    Index of Refraction
    Visual Luminous Efficacy
    1976 CIE Chromaticity Diagram
    RGB Values for Common Colors
    Solar Iradiance Curve
    Data for Astronomy
    Escape velocities Solar composition
    Data for Acoustics
    Equal tempered frequencies Speed of sound
    Data for Modern Physics
    Atomic spectra Ionic Diatomic Molecule Data
    Homonuclear diatomics Heteronuclear diatomics
    Vibrational Frequencies, Diatomic Data for Other Common Molecules Electron Affinities High energy particle populations
    Quarks Leptons
    Mesons Baryons
    Photoelectric work functions K-alpha x-ray energies
    Data for Condensed Matter
    Fermi Energies Electron Densities
    temperatures
    Type I Superconductor parameters
    on periodic table
    Superconductor coherence lengths
    and penetration depths
    Semiconductor band gaps
    Debye temperatures
    The 14 Bravais lattice
    Data for Nuclear Physics
    Nuclear Reactions High energy particle populations
    Chemical Data
    Electron Affinities Standard Electrode Potentials
    Thermodynamic properties for substances and ions
    Freezing point depression and boiling point elevation constants
    Geophysical Data
    Element abundances Mineral hardness
    Geological Time Scale Minerals
    Data for Biology and Biochemistry
    Neurotransmitters
    http://hyperphysics.phy-astr.gsu.edu/hbase/hframe.html
    نامل الائدة والدعاء
    من مواضيع يحي الحربي :
    التعديل الأخير تم بواسطة يحي الحربي ; 2007-08-29 الساعة 04:46 AM
    اللَّهُمَّ أَنْتَ رَبِّي لَا إِلَهَ إِلَّا أَنْتَ
    خَلَقْتَنِي وَأَنَا عَبْدُكَ وَأَنَا عَلَى عَهْدِكَ وَوَعْدِكَ مَا اسْتَطَعْتُ
    أَعُوذُ بِكَ مِنْ شَرِّ مَا صَنَعْتُ
    أَبُوءُ لَكَ بِنِعْمَتِكَ عَلَيَّ وَأَبُوءُ لَكَ بِذَنْبِي
    فَاغْفِرْ لِي فَإِنَّهُ لَا يَغْفِرُ الذُّنُوبَ إِلَّا أَنْتَ
    جاسر
    جاسر غير متواجد حالياً
    المشرف العام
    الصورة الرمزية جاسر
    Received: 14
    موقع ممتااااز
    جزاك الله خير :)
    الحمدلله رب العالمين
    eng_ahmad86
    eng_ahmad86 غير متواجد حالياً
    جزاك الله كل خير
    gamehdi
    gamehdi غير متواجد حالياً
    جزاك الله خير
    سيف العرب
    سلام العالم
    سلام العالم غير متواجد حالياً
    الصورة الرمزية سلام العالم
    جزآكم الله خيراً أخي ، ونفع الله بنا وبكم
    وجزآكم الله خيراً ووفقنا إلي ما يحبه ويرضاه
    أخيكم سلام العالم
    يد في يد نعيد مجد الأمة
    منذ ولدت و أنت تفخر بالاسلام ..... فمتى يفخر الاسلام بك
    الحياة أمل ..... لا تفقد الأمل أبدا ما دمت تؤمن بالله ... الله لن يضيعك
    م / أحمد سويلم
    خطَّاب
    خطَّاب غير متواجد حالياً
    استمر للامام ونحن معك
    Obadi_eng
    Obadi_eng غير متواجد حالياً
    جزاك الله خيراً
    islam2a
    islam2a غير متواجد حالياً
    الموقع مفيد جدا جدا
    شكرا لك
    moha_webas
    moha_webas غير متواجد حالياً
    الف شكر.............
    sali ser
    sali ser غير متواجد حالياً
    الموقع مفيد جدا جدا
    شكرا لك
