Elite Software Rhvac v8.01.221
النتائج 1 إلى 10 من 61
    eng_rovan
    eng_rovan غير متواجد حالياً
    احدث نسخة من البرنامج الشهير لحساب احمال التكييف مع برنامج رسم متكامل ( البرنامج كامل مع الكراك ) وتتميز هذه النسخة بالبساطة في استخدامها وطرق ادخال البيانات الخاصة لحساب الاحمال مما يسهل علي المستخدم التعامل مع البرنامج بشكل اسهل .
    واليكم شرح امكانيات وخصائص البرنامج بالغة الانجليزية من علي موقع الشركة ...
    Rhvac quickly and accurately calculates peak heating and cooling loads for residential and small commercial buildings in accordance with the eighth edition of the ACCA Manual J. The Heat Transfer Multipliers (HTM values) for all the walls, windows, doors, and roofs listed in Manual J are stored and automatically looked up by the program as needed. Although HTM values are taken from Manual J directly, the user does have the option of entering his own U-Value for each wall, roof, or glass section so that a modified HTM value is used. Design weather data for over 1500 cities is built-in to the program. In addition, the user can revise the existing weather data and add additional weather data as desired. Zoning cfm adjustments are automatically handled by the program as needed. Other outstanding features include exterior glass shading, ventilation air, miscellaneous latent loads, default room data, automatic rotation of the entire building, hydronic heat calculations and much more.
    Besides calculating peak heating and cooling loads, Rhvac can also calculate the length of tubing needed for hydronic radiant floors. It also calculates your duct sizes in accordance with Manual D, as well as the static pressure loss of your duct system, showing you the static pressure requirement of your system fan. Duct sizing options include all types of duct materials, height and width restrictions, velocity limits, and more. Additionally, Rhvac creates sales proposals and selects hvac equipment. For equipment selection, Rhvac is provided with a database derived from ARI and GAMA of thousands of equipment models from over 80 hvac manufacturers. Standard air conditioners, heat pumps, furnaces, boilers, and ground source heat pumps are among the types of equipment Rhvac can select. The sales proposal feature of Rhvac prints key features of the proposed equipment and work to be performed. Also included are standard terms and conditions of the proposal. Rhvac shares data with Elite Software\'s Energy Audit operating cost analysis program, Ductsize, Quick Quote, and Drawing Board program. Rhvac can be used stand alone or in conjunction with any of these programs.
    Features
    .: Calculates peak heating and cooling loads in accordance with Manual J.
    .: Calculates Duct Sizes, System Losses, and fan static pressure requirement in accordance with Manual D. Lets you enter the entire duct system, or only the path(s) with the highest pressure loss if you prefer.
    .: Determines building tonnage and room CFM requirements.
    .: Incorporates Manual J Addenda A, B, C, and D!
    .: Links to REM/Rate, Architectural Energy Corporation\'s popular home energy rating tool.
    .: Links to REScheck, DOE\'s energy codes program.
    .: Links to the Energy Gauge USA home energy rating program.
    .: New! Generates a Building Rotation report that shows you tonnages and room CFM requirements at each rotation.
    .: New! Includes a Buiding Rotation Duct Size Preview window that shows you the heating and cooling CFM for each room or duct in the project for each rotation of the building, as well as the maximum duct size of all rotations.
    .: Calculates hydronic radiant floor tubing length required.
    .: Follows ACCA Manual J, 8th Edition. Rhvac is approved by ACCA.
    .: Computes room by room, zone, system & building.
    .: Calculates from manually entered data or directly from floor plans created with Drawing Board (sold separately).
    .: Rooms and zones can be assigned to 15 systems.
    .: Allows 1000 rooms grouped into 10 zones per system using drag and drop zoning techniques.
    .: Allows 20 walls, 20 windows, 8 roofs, 6 floors and 6 doors per room.
    .: Allows custom construction materials and descriptions.
    .: Lets you specify lists of \"Favorite\" materials so you can select them easier.
    .: Remembers your most recent material selections so you can reselect them easily.
    .: Looks up HTM & U-values or lets you specify them.
    .: Determines Adequate Exposure Diversity status.
    .: Links to Ductsize, Energy Audit and PsyChart. The PsyChart program can import Rhvac system data directly into its Air Handler Model window.
    .: No copy protection!
    .: Displays psychrometric chart.
    .: Lets you select equipment from ARI and GAMA databases.
    .: Prints exploded color pie charts, bar graphs, and custom sales proposals.
    .: Allows decimal feet, feet-inches or metric length and width dimensions.
    .: Allows exterior shading (overhangs and offsets).
    .: Provides inputs for summer & winter partition temperature differences.
    واليكم لينك التحميل ...
    البرنامج مش محتاج باسوورد لفك الضغط .
    اسال الله ان ينفعنا وينفع المسلمين جميعا ...
    مع خالص شكري لكل الاخوه الذين سعو لطرح النسخ السابقة من هذا البرنامج .
    RAMI GHANEM
    RAMI GHANEM غير متواجد حالياً
    الصورة الرمزية RAMI GHANEM
    thank you very much
    الصانع
    الصانع غير متواجد حالياً
    Given: 6
    جزاك الله خيراً ،،،
    وفقك الله ،،،
    جـــــــــــــار التحميل ،،،،،
    لبيك يا اقصى
    لبيك يا اقصى غير متواجد حالياً
    اخي مشكور كتير بس يا ريت اذا عندك دروس تعليميه للبرنامج tutorials او شرح او انك ممكن انك تشرح البرنامج بالعربي او اهم النقاط في البرنامج والك مره تانيه الف شكر
    تحياتي من العراق الشقيق
    diab_awad
    diab_awad غير متواجد حالياً
    الصورة الرمزية diab_awad
    للأسف الرابط أنتهي هل ممكن ترفعة مرة ثانية وياريت تجرب zshare
    eng_rovan
    الاخ الفاضل ( لبيك يا اقصي ) باذن الله تعالي انا بحضر في شرح البرنامج واول ما انتهي سوف اضيفه ان شاء الله قريبا .
    eng_rovan
    اخي الفاضل diab_awad لا يمكن ان ينتهي هذا الرابط لانه مرفوع بـ Premium account لذلك ان كانت تواجهك مصاعب في التحميل من rapidshare يا ريت تخبرني وانا سوف ارفعه لك علي اي سيرفر انتا عايزه
    amr fathy
    amr fathy غير متواجد حالياً
    Received: 19
    Given: 7
    جزاك الله خيراً
    saman
    saman غير متواجد حالياً
    يا أخى ربنا يديك على قد نيتك روح إنت إبن حلال
    سلام جاسم
    سلام جاسم غير متواجد حالياً
    اخي لو ممكن تكمل جميلك وترفع على موقع أخر لان هذا الموقع منهك للجهد والوقت ومع الشكر
