مكتبة كتب ومراجع هندسة السيارات
صفحة 5 من 10 الأولىالأولى 1 2 3 4 56 7 8 9 ... الأخيرةالأخيرة
النتائج 41 إلى 50 من 99
  1. [41]
    م/محمد لطفي
    م/محمد لطفي غير متواجد حالياً
    الصورة الرمزية م/محمد لطفي
    الكتاب ال 12
    Publisher: McGraw-Hill Science/Engineering/Math
    Number Of Pages: 930
    Publication Date: 1988-04-01
    Sales Rank: 245558
    ISBN / ASIN: 007028637X
    EAN: 9780070286375
    Binding: Hardcover
    Manufacturer: McGraw-Hill Science/Engineering/Math
    Studio: McGraw-Hill Science/Engineering/Math
    Average Rating: 5
    Total Reviews: 4
    This text, by a leading authority in the field, presents a fundamental and factual development of the science and engineering underlying the design of combustion engines and turbines. An extensive illustration program supports the concepts and theories discussed.
    Table Of *******s
    1 Engine Types and Their Operations
    2 Engine Design and Operating Parameters
    3 Thermochemistry of Fuel-Air Mixtures
    4 Properties of Working Fluids
    5 Ideal Models of Engine Cycles
    6 Gas Exchange Processes
    7 SI Engine Fuel Metering and Manifold Phenomena
    8 Charge Motion within the Cylinder
    9 Combustion in Ignition Engines
    10 Combustion in Compression Ignition Engines
    11 Pollutant Formation and Control
    12 Engine Heat Transfer
    13 Engine Friction and Lubrication
    14 Modeling Real Engine Flow and Combustion Processes
    15 Engine Operating Characteristics
    Appendixes
    من هنا
    http://mihd.net/dp9sny
    لمشاهده احدث المواضيع والمشاركات يمكنكم زياره هذا المنتدي
    www.eng2all.com/vb
  2. [42]
    م/محمد لطفي
    الكتاب ال 14
    Stirling and hot air engines
    ISBN:186126688 | 250 pages | 2005 | Publisher: Crowood Press, Limited
    Great guide for building and designing your own thermal engines.
    من هنا
    http://mihd.net/f1v6q0
    85 ميجا
    www.eng2all.com/vb
  3. [43]
    م/محمد لطفي
    الكتاب ال 15
    Diesel Engine Reference Book (Second Edition)
    Lavishly Illustrated / 714 pages / 55.2 MB / PDF OCR'd
    Chapter 1 The theory of compression ignition engines
    Chapter 2 The theory of turbocharging
    Chapter 3 Compound and other engine systems
    Chapter 4 Diesel combustion and fuels
    Chapter 5 Thermal loading
    Chapter 6 Thermodynamic mathematical modelling
    Chapter 7 Computational fluid dynamics
    Chapter 8 Modern control in diesel engine management
    Chapter 9 Inlet and exhaust systems
    Chapter 11 Fuel injection systems
    Chapter 12 Lubrication and lubricating oils
    Chapter 13 Bearings and bearing metals
    Chapter 14 Pistons, rings and liners
    Chapter 15 Auxiliaries
    Governors and Governor Gear
    Starting Gear and Starting Aids
    Heat Exchangers
    Chapter 16 Aircooled engines
    Chapter 17 Crankcase explosions
    Chapter 18 Exhaust smoke, measurement and regulation
    Chapter 19 Exhaust emissions
    Chapter 20 Engine noise
    Chapter 21 Larger engine noise and vibration control
    Chapter 22 Passenger car engines
    Chapter 23 Trucks and buses
    Chapter 24 Locomotives
    Chapter 25 Dual fuel engines
    Chapter 26 Marine engine applications
    Chapter 27 Condition monitoring
    سا احاول رفع وصلات افضل ان شاء الله
    من هنا
    http://depositfiles.com/files/366814
    http://depositfiles.com/files/366816
    www.eng2all.com/vb
  4. [44]
    م/محمد لطفي
    Talking
    الكتاب ال 17
    Mixture Formation in Internal Combustion Engines (Heat and Mass Transfer)
    Summary:The book covers the various approaches to modelling, measuring and optimising the mixture formation process in internal combustion engines. Due to their complexity and importance in predicting the temporal and spatial distribution of liquid and gaseous fuel inside the cylinder, special emphasis is put on the detailed description of multi-dimensional CFD-models regarding the flow conditions inside the injection nozzle, the primary and secondary spray break-up, evaporation, turbulent dispersion, collision, wall impingement and ignition. Example calculations are compared with semi-empirical relations and corresponding experimental data - represented in diagrams as well as in images resulting from modern optical measurement techniques - in order to discuss the capabilities of today’s simulation models as well as their shortcomings. Moreover, today’s and future requirements concerning the development of injection systems capable of optimising the combustion process in terms of reduced fuel consumption and emissions are discussed. The reader will also be provided with an overview of the most important optical measurement techniques for the investigation of mixture formation in internal combustion engines.
    من هنا
    http://mihd.net/a7wuiz
    www.eng2all.com/vb
  5. [45]
    م/محمد لطفي
    الكتاب ال 16
    من هنا
    http://www.4shared.com/file/22761513...ified=b0105bfc
    www.eng2all.com/vb
  6. [46]
    mohamed abouzahra
    mohamed abouzahra غير متواجد حالياً
    الصورة الرمزية mohamed abouzahra
    مشكورر جدا م / محمد
    على مجهودك الرائع معى
    بارك الله فيك
    ان الله فى عون العبد ما دام العبد فى عون اخيه
    كل ما هو جديد فقط
  7. [47]
    م/محمد لطفي
    www.eng2all.com/vb
  8. [48]
    mostafa_sa3eed
    mostafa_sa3eed غير متواجد حالياً
    جزاكم الله كل خير على افادتكم لنا بهذه الكتب الرائعة ...
    و اسال الله ان يجعلها فى ميزان حسناتكم ان شاء الله
    بارك الله فيكم
  9. [49]
    فهد الغرافه
    فهد الغرافه غير متواجد حالياً
    بصراحه هذي اول مشاركه لي بالمنتدى وبصراحه اكثر هذا اكثر منتدى يعجبني من اول مادخلت عالم الانترنت
    مشكورين على المكتبه الحلوه والمواضيع الشيقه
  10. [50]
    م/محمد لطفي
    www.eng2all.com/vb
