احدث نظام اشعال فى السيارات ( Dis )
النتائج 1 إلى 10 من 23
    الصورة الرمزية mohamed abouzahra
    mohamed abouzahra
    mohamed abouzahra غير متواجد حالياً
    ان شاء الله ساقوم بوضع شرح بسيط لهذا النظام .
    Distributorless Ignition Systems (DIS
    Distributorless ignition systems (DIS</B>) have been around for almost a decade now, and have eliminated much of the maintenance that used to be associated with the ignition system. No distributor means there is no distributor cap or rotor to replace, and no troublesome vacuum or mechanical advance mechanisms to cause timing problems. Consequently, DIS ignition systems are pretty reliable.
    Even so, that does not mean they are trouble-free. Failures can and do occur for a variety of reasons. So knowing how to identify and diagnose common DIS problems can save you a lot of guesswork the next time you encounter an engine that cranks but refuses to start, or one that runs but is missing or misfiring on one or more cylinders.
    If an engine cranks but will not start, is it fuel, ignition or compression? Ignition is usually the easiest of the three to check because on most engines, all you have to do is pull off a plug wire and check for spark when the engine is cranked. On coil-over-plug DIS systems, there are no plug wires so you have to remove a coil and use a plug wire or adapter to check for a spark.
    If there is no spark in one cylinder, try another. No spark in any cylinder would most likely indicate a failed DIS module or crankshaft position sensor. Many engines that are equipped with electronic fuel injection also use the crankshaft position sensor signal to trigger the fuel injectors. So, if there is no spark and no injector activity, the problem is likely in the crank position sensor. No spark in only one cylinder or two cylinders that share a coil would tell you a coil has probably failed.
    غسان التكريتي
    غسان التكريتي غير متواجد حالياً
    شكرا جزيلا يا اخي وبارك الله فيك
    شكرى محمد نورى
    Received: 62
    تحياتي محمد ابو زهرة .
    عطاء دائم ومثمر ومتجدد .
    الله يخليك لينا .
    البغدادي
    mohamed abouzahra
    اقتباس المشاركة الأصلية كتبت بواسطة غسان التكريتي مشاهدة المشاركة
    شكرا اخى الحبيب
    ان الله فى عون العبد ما دام العبد فى عون اخيه
    كل ما هو جديد فقط
    mohamed abouzahra
    الله يخليك لينا .
    البغدادي
    شكرا استاذى ووالدى العزيز م / شكرى
    الله يبارك فيك خير من اختير مشرفا
    كل ما هو جديد فقط
    م/محمد لطفي
    م/محمد لطفي غير متواجد حالياً
    الصورة الرمزية م/محمد لطفي
    لمشاهده احدث المواضيع والمشاركات يمكنكم زياره هذا المنتدي
    www.eng2all.com/vb
    احمد مؤنس
    احمد مؤنس غير متواجد حالياً
    الصورة الرمزية احمد مؤنس
    شكرا اخى الحبيب
    أبوفراس
    أبوفراس غير متواجد حالياً
    يديك العافية
    بوحصة
    بوحصة غير متواجد حالياً
    الصورة الرمزية بوحصة
    الله يعطيك العافية
    ولا يحرم الأجر
    أبي عبدالله خالد
    أبي عبدالله خالد غير متواجد حالياً
    جزاك الله كل خير
