turbines ///التوربينات
النتائج 11 إلى 20 من 30
    حسن هادي
    حسن هادي غير متواجد حالياً
    الصورة الرمزية حسن هادي
    HOT WATER TURBINES
    Have
    a hot/warm water application that requires a high degree of accuracy with
    low maintenance features? Then Carlon has a family of meters for you. Our hot
    water turbine meters are available in sizes from 3/4
    to 6, with larger sizes available
    upon request. Carlon turbine meters provide an amazing +/- 1% accuracy at flow
    rates from 1 GPM all the way up to
    1,870 GPM and 235 psi. Our hot water turbine
    meters will handle temperatures up to 2
    50 °F. Our turbine meters are all available in
    totalizing and electric contact configurations so that you can run your other process
    equipment (Carlon valves, timers, controllers and chemical pumps) directly from our
    turbine meter.
    1710 EATON DRIVE • GRAND HAVEN, MICHIGAN 49417
    PHONE (616) 842-0420 FAX(616) 842-1265
    E-MAIL
    [email protected].COM • WWW.CARLONMETER.COM
    SPECIFICATIONS
    Meter Connections:
    Carlon supplies necessary connections with all turbine meter orders.
    Pressure ratings:
    Do not exceed 235 psi
    Temperature Tolerance:
    Protect the meter from freezing and from temperatures in excess of 250 °F
    Accuracy:
    +/- 1.0% when operating between minimum and maximum flow range
    Current Considerations:
    Specific to EC models only. Maximum switching voltage is 48v AC/DC.
    Maximum current .2 amps, 3 watts.
    Larger Sizes:
    Available upon request.
    Installation Instructions:
    A. For all types of hot water turbine meters:
    1. Flush the line thoroughly after all plumbing changes to prevent contaminates from entering the turbine.
    2. 2-
    6 inch meters can be mounted horizontal or vertically with inlet port facing the water supply line.
    B. For EC type hot water turbine meters:
    1. Connect the terminals on the pulse head to the meter input on the controlling device.
    2. Connect your controlling device to the water treatment equipment (pumps, valves, etc.).
    Note GPC setting to determine frequency of operation.
    3. This meter is not designed for outdoor installation.
    Warranty:
    Carlon warrants its products to be free of defect in material and workmanship for a period of twelve months
    from the date of purchase. Contact us to obtain a copy of our complete statement of warranty.
    Helpful Hints:
    1. Install a Carlon slow-closing valve downstream of your water meter.
    This will eliminate possible meter damage from water hammer in your system.
    2. Install a Carlon strainer upstream of your water meter to protect the meter and any
    other in-line process equipment from becoming jammed by particulate matter in your system.
    3. Carlon turbine meters have an epoxy coated cast iron main
    case.
    Sizes of ¾
    , 1,and 1 ½are multi-jet type meters with bronze main case.
    ¾, 1, & 1½ inch meters are recommended to be mounted horizontal.
    DIMENSIONS
    METER SELECTION CHART
    METE
    R TOTALIZING ELECTRIC CONTACT FLOW NOMINAL
    SIZE MO
    DEL CONTACT SETTIINGS CAPACITY FLOW
    ¾
    H075T H075EC 1/10/100 GPC 1-20 GPM 11 GPM
    H100T H100EC 1/10/100 GPC 2-50 GPM 27 GPM
    1 ½
    H150T H150EC 10/100 GPC 3-85 GPM 44 GPM
    H200T H200EC 10/100 GPC 3-132 GPM 66 GPM
    3
    H300T H300EC 100/1000 GPC 14-198 GPM 141 GPM
    4
    H400T H400EC 100/1000 GPC 26-790 GPM 263 GPM
    H600T H600EC 100/1000 GPC 45-1870 GPM 1005 GPM
    Additional Information: If you require additional information, visit us online at www.carlonmeter.com
    METER
    SIZ
    E MODEL LENGTH HEIGHT WIDTH WEIGHT
    ¾
    H075T/H075EC 7 1/2" 6" 3 3/44 1/2 lbs.
    H100T/H100EC 10 1/4" 7 1/44" 7 lbs.
    1 ½
    H150T/H150EC 11 7/8" 8 1/8" 5 1/211 1/2 lbs.
    H200T/H200EC 7 7/8" 8 1/2" 6 1/225 lbs.
    3
    H300T/H300EC 8 7/8" 9 1/4" 7 7/828 lbs.
    4
    H400T/H400EC 9 7/8" 12 1/4" 8 5/844 lbs.
    H600T/H600EC 11 7/8" 14 1/4" 11 1/472 lbs.
    Nominal Flow: The size of meter selected should be based upon nominal flow, GPC, as opposed to pipe size. For example,
    if it is determined that nominal flow is 500 GPM, a 4" meter should be selected. Head loss = 1.5 psi at nominal flow.
    Specify contact settings for EC models. For example, if you require a 2" meter with 100 GPC setting, order a H200EC-100.
    Call our factory for available settings in cubic feet and metric applications.
    dohengineer
    dohengineer غير متواجد حالياً
    Given: 3
    موضوع متميز . شكرا على هذا الموضوع.
    محمد العايدى
    محمد العايدى غير متواجد حالياً
    موضوع مفيد جدا يحتاج مجهود كبير .....شكرا ونرجو المزيد
    eaaaazizo
    eaaaazizo غير متواجد حالياً
    شكرا جزيلا يا باشمهندس على هذا المجهود الرائع والله المعين و الموفق
    ولكن انا لي استفسار صغير بعد اذنك ؟
    هل انت معيد بكلية الهندسة ؟
    ابو اواب
    ابو اواب غير متواجد حالياً
    الصورة الرمزية ابو اواب
    شكــــــــــــــــــــــــــــــــــــــــــــــــ ــــــرا
    حسن هادي
    شكرا جزيلا على مروركم وان شاء الله نقدم المزيد
    سنان عبد الغفار
    سنان عبد الغفار غير متواجد حالياً
    شكرا شكرا شكرا شكرا وليس لي شأء اقدمه لك غير هذه الكلمة
    شكرى محمد نورى
    Received: 62
    الاخ العزيز حسن هادي .
    تحية طيبة .
    اطلالة اخرى من روائع مهندس حسن .
    كم انت رائع وغيور ومبدع .
    والى الأمام .
    البغدادي
    حسن هادي
    اقتباس المشاركة الأصلية كتبت بواسطة سنان عبد الغفار مشاهدة المشاركة
    حياك الله اخي يا طيب
    حسن هادي
    تحية طيبة .
    والى الأمام .
    البغدادي
    اطلالتك الاروع وافكارك الانوع *وتحياتي لك يا مهندسنا المشرف الاستاذ شكري
