اقوى برنامج لحل مسائل Finite Element حصريا على الملتقى
صفحة 1 من 10 12 3 4 5 ... الأخيرةالأخيرة
النتائج 1 إلى 10 من 98
    الصورة الرمزية ماجد جلميران
    ماجد جلميران
    ماجد جلميران غير متواجد حالياً
    MSC Marc 2007 R1 | 795 MB
    Finite element analysis (FEA) is a critical part of the virtual design process. But because most FEA programs are linear, they can only study parts that deform a small amount, certainly not enough to deformation to exceed the linear elastic range of the materials.
    But Marc has no such limitations. A nonlinear FEA program, Marc enables you to assess the structural integrity and performance of parts undergoing large permanent deformations as a result of thermal or structural load. The types of deformations the program can study include geometric nonlinearities (metals bending) and material nonlinearities (elastomers and metals that yield under structural or thermal loading). You can also use Marc to simulate deformable, part-to-part or part-to-self contact under varying conditions that include the effects of friction—critical for analyzing nonlinear behavior in tool-and-die set-up, spring coil clash, or a windshield wiper system.
    And whether you are designing with glass, rubber, steel, or concrete, Marc offers an extensive library of metallic and non-metallic material models, along with a library of 175 elements for structural, thermal, and fluid analysis.
    Combine with pre- and post-processors
    You can drive all Marc products through the common GUI offered by Patran or Marc Mentat, two pre- and post processors that work with Marc. Mentat also provides the unique ability to process large problems in parallel using the domain decomposition technique. Loading conditions can originate from physical tests or virtual tests using Adams. MSC Software AFEA is a bundled version of Patran and Marc.
    Download
    http://www.filefactory.com/file/7c2336/
    http://www.filefactory.com/file/d1ea29/
    http://www.filefactory.com/file/4b4882/
    http://www.filefactory.com/file/0eccf4/
    http://www.filefactory.com/file/d1a645/
    http://www.filefactory.com/file/e072c8/
    http://www.filefactory.com/file/b5204e/
    http://www.filefactory.com/file/b901e7/
    لاتنسونا بالدعاء والردود
    ماجد جلميران
    برنامج بهذه القيمة ولا يوجد ولا رد ؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟؟
    حسن حنو
    حسن حنو غير متواجد حالياً
    مشكورررررررررررررر يا اخي على البرنامج
    mohajir
    mohajir غير متواجد حالياً
    Question مناقشة ثم
    اقتباس المشاركة الأصلية كتبت بواسطة ماجد جلميران مشاهدة المشاركة
    سلمات جليمران
    شكراً على البرنامج والمجهود الرائع ، لكن لو سمحت لي اعتقد ان المادة نفسها Finite صعبة ومحتاجة فهم اولاً قبل تطبيقها على البرامج ، ولذلك اخترح عليك اخي الحبيب طرح موضوع عن المادة لمنقشتها وبالتالي جمع قدر وافر عنها من المعلومات لفائدة الجميع وبما انك المبادر ارجو ان تطرح المضوع بنفسك. وح نستفيد منك انشا الله ومن جميع المشاركين.
    خير الناس انفعهم للناس
    سرمد الواسطي
    سرمد الواسطي غير متواجد حالياً
    الاخ ماجد ، طبعا شكرا جزيلا على البرنامج الرائع !
    اسمح لي ان انوه لك ان هذا الصنف من البرامج الهندسية (التحليلات) ، و بالاخص هذا البرنامج و برامج اخرى شبيهه ، لا يمكن تقديرها الا من قبل شخص له خبرة و دراية باساليب التحليل يطريقة الـ Finite Element Analysis.
    احمد1970
    احمد1970 غير متواجد حالياً
    اخى العزيز بارك الله فيك
    ربما يكون السبب الرئيسى فى قلة الردود هو عدم معرفتهم بالبرنامج وماالذى يستطيع فعله البرنامج
    فارجوك اخى الكريم ان تعطينا نبدة باللغة العربية عن اهداف هذا البرنامج وشكرا
    alasd
    alasd غير متواجد حالياً
    الصورة الرمزية alasd
    Angry مصر
    يا أخى انا لما جيت أفك الضغط ظهرت لى رسالة من winrar تقول أن هناك ملفات ناقصة ولكنه أكمل الفك وعند تسطيب البرنامج لم يكمل وذكر لى هذا الملف الناقص وأنا اشتغلت على برنامج cosmos و ALGOR ولكنهما أصغر فى الحجم من هذا البرنامج أرجو المساعدة فى الحصول عليه شكرا
    ماجد جلميران
    اخي العزيز البرنامج كامل استخدم احدث اصدار من ال winrar بالنسبة الى البرامج التي ذكرتها هي برامج اكاديمية وليسه احترافية كما في البرنامج Msc Mark
    alasd
    مصر
    والله ياأخ ماجد استخدمت wrar351 ومافى فائدة
    ماجد جلميران
    اخي الغالي مادام فك ضغط الملفات يتم بصورة كامله فمعنى ذلك انه لايوجد خلل في البرنامج من ناحية نقص الملفات عموما فقد قمت بتنصيب البرنامج بصورة كاملة ولم اواجه اي مشكلة تحياتي لك
