مشكلة غريبة في توزيع ال load على pumps
النتائج 1 إلى 5 من 5
    simply
    simply غير متواجد حالياً
    اسمحولي ان اكتب المشكلة باللغة الانجليزيه لانها الاسهل في الشرح
    we have three pumps ( A , B and C ) which have common suction and discharge. there are always 2 pumps online and the other pump is on standby. the fluid is light hydrocarbons
    when the Pumps "A" and "B" are On line the pump "A" will take 65% of the load while Pump "B" will take only 35%
    when the Pump "B" and "C" are on line . the two pumps will have an equal load of around 50% each
    when the pumps "A" and "C" are on line the pump "C" will take 65% of the load while pump "A" will take 35%
    the load percentages are rounded,
    what could be the problem because the pumps where working fine and the load was equal before?
    مشكورين على المساعده
    Eng.Foam
    Eng.Foam غير متواجد حالياً
    Dear Sir,
    Can you supply me any of photos for these pumps? And plz let the pic show all of the suction header and the discharge pipe, and that will make it easy to understand the process
    Reaction
    Reaction غير متواجد حالياً
    Dear
    As per your explanation, the problem seems in Pump A which may has bigger capacity rather that other pumps. You can check the current supply for all pump and compare it for all, this is what I have for this issue
    Regards
    لا اله الا الله
    منص**
    منص** غير متواجد حالياً
    شكرا
    شكراشكرا
    شكراشكراشكرا
    شكراشكراشكراشكرا
    شكراشكراشكراشكراشكرا
    شكراشكراشكراشكرا
    شكراشكراشكرا
    شكراشكرا
    شكرا
    مهندس علي العبيدي
    مهندس علي العبيدي غير متواجد حالياً
    طبعا اني رايئي مثل رأي الاخ reaction
    لان اكيد الخلل بالpupmp A يعني الكاباسيتي ماله اكثر من البقيه
