ملف صغير يتكلم عن موضوع الDurability of Concrete
النتائج 1 إلى 10 من 12
    عصام رزق محمد
    عصام رزق محمد غير متواجد حالياً
    Received: 13
    ارجو ان ينال اعجابكم.
    41
    41.1 Introduction
    41.2 Permeation Properties
    41.3 Reinforcement Corrosion
    Carbonation • Effects of Chloride • Propagation Stage of
    Corrosion • Control Strategy
    41.4 Alkali-Aggregate Reaction
    Control Strategy
    41.5 Sulfate Attack
    Physical Attack • External Sulfate • Internal Sulfate • Control
    Strategy
    41.6 Acid Attack
    Action On Sewers
    41.7 Seawater
    41.8 Physical Attrition of Concrete
    41.9 Frost Action
    41.10 Action of Heat and Fire
    41.11 Design for Durability
    Service Life • Exposure Environment • Concrete Quality •
    Cover Thickness
    41.1 Introduction
    Concrete is a composite with properties that change with time. During service, the quality of concrete
    provided by initial curing can be improved by subsequent wetting as in the cases of foundations or waterretaining
    structures. However, concrete can also deteriorate with time due to physical and chemical
    attacks. Structures are often removed when they become unsafe or uneconomical.
    Lack of durability has become a major concern in construction for the past 20 to 30 years. In some
    developed countries, it is not uncommon to find large amount of resources, such as 30 to 50% of total
    infrastructure budget, applied to repair and maintenance of existing structures. As a result, many government
    and private developers are looking into lifecycle costs rather than first cost of construction.
    Durability of concrete depends on many factors including its physical and chemical properties, the
    service environment and design life. As such, durability is not a fundamental property. One concrete
    that performs satisfactory in a severe environment may deteriorate prematurely in another situation
    where it is consider as moderate. This is mainly due to the differences in the failure mechanism from
    various exposure conditions. Physical properties of concrete are often discussed in term of permeation,
    the movement of aggressive agents into and out of concrete. Chemical properties refer to the quantity
    and type of hydration products, mainly calcium silicate hydrate, calcium aluminate hydrate, and calcium
    hydroxide of the set cement. Reactions of penetrating agents with these hydrates produce products that
    can be inert, highly soluble, or expansive. It is the nature of these reaction products that control the
    severity of chemical attack. Physical damage to concrete can occur due to expansion or contraction under
    D.W.S. Ho
    National University of Singapore
    م/السيد الشيخ
    م/السيد الشيخ غير متواجد حالياً
    الصورة الرمزية م/السيد الشيخ
    Received: 122
    Given: 53
    جزاك الله خيرا
    ميتركس العراق
    ميتركس العراق غير متواجد حالياً
    مشكور خي وبارك الله بيك
    عصام رزق محمد
    Received: 13
    هل يعرف احد ما هي الاختبارات التي يتم عملها للخرسانة لمعرفة الdurability ?
    من لا يشكر الناس.......................لا يشكر الله
    عصام رزق محمد
    Received: 13
    احد هذة الاختبارات لمعرفة الdurability للخرسانة هو
    ال Pentration Test
    mohy_y2003
    mohy_y2003 غير متواجد حالياً
    الصورة الرمزية mohy_y2003
    Received: 350
    Given: 439
    مشكور جدا يا باشمهندس عصام وجزاك الله خرا
    eng_frg
    eng_frg غير متواجد حالياً
    جزاك ربى الجنان وابعد عنكم كل شيطان
    عصام رزق محمد
    Received: 13
    Durability tests
    7.1 Corrosion of reinforcement and prestressing steel
    7.1.1 Electromagnetic cover measurement
    7.1.2 Half-cell potential measurement
    7.1.3 Resistivity measurements
    7.1.4 Perturbative measurement of corrosion rate
    7.1.5 Other electrical techniques
    7.2 Moisture measurement
    7.2.1 Simple methods
    7.2.2 Neutron moisture gauges
    7.2.3 Electrical methods
    7.2.4 Microwave absorption
    7.3 Absorption and permeability tests
    7.3.1 Initial surface absorption test
    Copyright 1996 Chapman & Hall
    7.3.2 Figg air and water permeability tests
    7.3.3 Combined ISAT and Figg methods
    7.3.4 Hansen gas permeability test
    7.3.5 ‘Autoclam’ permeability system
    7.3.6 Flow tests
    7.3.7 BS absorption test
    7.3.8 DIN 1048 absorption test
    7.3.9 ‘Sorptivity’ test
    7.3.10Capillary rise test
    7.3.11Vacuum test
    7.4 Tests for alkali-aggregate reaction
    7.5 Tests for freeze-thaw resistance
    7.6 Abrasion resistance testing
    عصام رزق محمد
    Received: 13
    المتانة( تحمل الخرسانة مع الزمن ) Durabilty
    هى تحمل الخرسانة للظروف التي صممت من اجلها مع مرور الزمن دون حدوث تلف او تفتت بها.
    او بمعني اخر هى مقاومة الخرسانة للتدهور سواء الناتج من عوامل داخلية (التفاعلات الكيميائية – التغيرات الحجمية - ... الخ))
    عوامل خارجية (ظروف التشغيل – التحميل – العوامل الجوية .
    ابو تهانى
    ابو تهانى غير متواجد حالياً
    الصورة الرمزية ابو تهانى
    الموضوع شيق جدا وهو أحد اهتماماتى وكجزء اساسى من برنامجى للماجستير ، وسأعود بمشاركة قوية فى هذا الموضوع ان شاء الله.
