الخيوط الجراحية
النتائج 1 إلى 10 من 23
    غيث طارق
    غيث طارق غير متواجد حالياً
    الخيوط الجراحية
    تحية طيبة
    لم يتطرق احد من قبل الى موضوع الخيوط الجراحية المستخدمة في خياطة الجروح والاعضاء
    انواعها ,اشكالها قياساتها
    فهل نجد من يمكنه رفد الموضوع بتفاصيل فنية من ذوي الاختصاص
    نحن بانتظار المشاركات
    غيث طارق
    هذه مقدمة صغيرة عن الموضوع ونود ان يشاركونا الاخوة والاخوات بالاضافة للموضوع لمساتهم الفنية لتكتمل الصورة عن الموضوع.
    Surgical Suture
    Sutures, or stitches, are materials used to close a wound. They are used in an attempt to improve and speed healing. Pulling the edges of a wound together and stitching help in healing process. Sutures are used to close cuts from injuries or surgery. They are commonly used on the skin, internal tissues, organs, and blood vessels.
    Suture material
    Different types of materials can be used to close a wound depending upon the style of wound, location and depth in the body. The material can be special glue, staples, animal protein or thread like materials. Usually , the suture material comprises
    • Polyester
    • Silk
    • Nylon
    • Stainless steel wire
    Suture technology
    • Braided
    • Plain
    • Monofilament
    Types of sutures
    These sutures can further be
    • Absorbable suture: The absorbable ones get dissolved in the body on their own and do not require removal.
    • Non absorbable suture: The non absorbable ones have to be removed after specified time. The type of suture is decided again by the location of the wound.
    The internal layers are stitched by absorbable sutures and the upper or the skin may be stitched by the non absorbable sutures. Local or general anesthesia has to be given to the patient as per the requirement before suturing.
    Features
    • The body of suture is smooth.
    • The body of the suture does not cause any capillary and repelling reaction.
    • Due to the softness of the suture, it will not tear at tissue.
    • It is easy to knot and the knot tied is firm.
    • The breaking strength of suture and knot are strong.
    • The sewing is made firm, which is best for the healing of the patient without ductility.
    Depending on the different human organs and operating location, different kinds and sizes of suture needles are chosen. The common features are that the body is smooth, the point type is sharp, and is painless to the human.
    Nonabsorbable Sutures Features
    All nonabsorbable sutures are manufactured keeping in mind several fundamental characteristics, such as follows:
    • Uniform diameter
    • Uniform size
    • Sterility
    • Pliability for ease of handling
    • Knot security
    • Uniform tensile strength
    • Freedom from irritants or impurities
    مهدي الزعيم
    مهدي الزعيم غير متواجد حالياً
    الصورة الرمزية مهدي الزعيم
    مجهود طيب
    مرحبا بك يا أخي
    حقيقة الموضوع جميل وجدير بالدراسة، ولكن كما تفضلت قليلون هم من تطرقوا الى مثل هذه المواضيع .. على العموم المرفق التالي يتحدث عن الخيوط والأبر المستعملة في العمليات الجراحية وكذلك عن عملية التئام الجروح.
    مع الشكر
    شكرى محمد نورى
    Received: 62
    السلام عليكم .
    تحياتي وتقديري .
    جزاكما الله خير جزاء .
    وننتظر المزيد والجديد .
    البغدادي
    عرب حر
    عرب حر غير متواجد حالياً
    الصورة الرمزية عرب حر
    Smile suture
    Asalamo alaykom wa rahmatou allahi wa barakatouhou ana chaksiyan a3mal ala sina3t al kyout ajirahia (suture
    kama akoumou bi majmouat abhath ala kasais suture,
    if you have any question I can anserws you and I would like to speak with you .
    In addition if you need some information or document I can send you exemple if I have it.
    tdm
    tdm غير متواجد حالياً
    الصورة الرمزية tdm
    مشكووووووووووور على الموضوع
    tdm
    الصورة الرمزية tdm
    عرب حر
    Question suture
    hal youjado ahad motakasses fi hada majel
    المسلم84
    المسلم84 غير متواجد حالياً
    الصورة الرمزية المسلم84
    Received: 18
    Given: 24
    جزاكم الله خيرا
    لا تنسونا من صالح دعائكم
    سبحان الله وبحمده....سبحان الله العظيم
    غيث طارق
    مشكور اخي العزيز وجهد مميز فعلا
    وانشاء الله المزيد من العطاء
