أطلب أي معلومات حول لغة البرمجة وستجده بإذن الله
صفحة 8 من 10 الأولىالأولى ... 4 5 6 7 89 10 الأخيرةالأخيرة
النتائج 71 إلى 80 من 99
  1. [71]
    Miss IT
    Miss IT غير متواجد حالياً
    السلام عليكم احبابي اريد برامج او موضوع (system)لمشروع تخرج نستخدم فيه VB
  2. [72]
    narde
    narde غير متواجد حالياً
    بارك الله فيك اخوي وجعله الله في موازين حسناتك
  3. [73]
    mohamedsad
    mohamedsad غير متواجد حالياً
    عندي هوم ورك واب حله بلييز
  4. [74]
    mohamedsad
    Coding logic design and implementation
    (15 Marks Total)
    Your first assignment will require you to develop a record processing system in both ASP
    and PHP, giving you an opportunity to see two web scripting languages in action. You
    will be provided with an input form for both ASP and PHP, from which you must
    develop a logically designed script which validates and processes the incoming data,
    presenting the results to screen. Your use of Functions, Control Structures, Input
    Validation, Conditions, and basic numerical calculations will form the core of each
    ASP/PHP script.
    Task
    Your task is to create an ASP and PHP page that reads in the data from the attached
    forms, validates the data (looking for physical and logical errors), then process the data
    and outputs a summary score and winner information. Your script is required to process
    the input of a single game of football, including all players in each team and the goals and
    points scored by each player.
    The following screenshot shows some of the fields in the input form;
    The first field records the players full name, while the second and third fields records any
    goals and/or points kicked by that player.
    Your job is to write each of your scripts according to the following business logic;
    All goals and points for each player for Team 1 and then Team 2 are to be added up,
    producing a final score for each team (represented as Goals, Points and Total Score). For
    example, if 10 goals and 6 points are kicked by a given team, then the result will be
    displayed as 10 6 (66). Obviously, one goal is worth 6 points and one point is just 1
    point.
    The minimum validation you need to perform includes;
    None of the input fields (rows with data) have blank fields
    All Goals and Points must be entered as numerical values only
    A players name cannot be entered more than once
    The same team cannot be selected more than once (for Team 1 and then again for
    Team 2)
    All errors need to be clearly displayed on screen, including which line and which
    field for which team produced the error.
    Quality assignments will include the use of functions or procedures in order to
    modularize code, and code commenting should be used to internally explain different
    parts of the code.
    Students are not to change the original forms as provided – as well as coding up the
    required scripts for this assignment, part of the task is to code ‘around’ what are pretty
    basic forms that have no client-side validation at all.
    In terms of output, your assignment must show;
    The total score for each team and the breakdown of goals and points
    i.e.
    West Coast Eagles 11 8 (74) Def Fremantle 4 11 (35).
    Top Five goal kickers for each team (including player name and number of goals
    kicked)
    The overall winning margin
    You must also include a flow diagram and pseudocode file that represent the logic of
    your final assignment.
  5. [75]
    محمد ناجي العراقي
    محمد ناجي العراقي غير متواجد حالياً
    Question مشروع التخرج
    [QUOTE=حاج إبراهيم;501134]إذا كنت في نعمة فارعها فإن المعاصي تزيل النعم
    الحمد لله الذي هدانا لهذا وما كنا لنهتدي لولا أن هدانا الله رب العالمين
    من هذا المنطلق أردت أن تكون بيننا رابطة خير و محبة في الله و لفعل الخيرات
    لذلك فأي انشغالات تريبكم بعد اليوم لا ويجود لها خاصة في لغات البرمجة
    Php
    Java
    C++
    C
    Delphi
    Vb
    Asp
    Oracl
    Sql
    Matlab
    أطلبوا عبرا الرد السريع وستكون هناك إجابات بحول الله ومعونته
    أدعوا لي بالتوفيق[/QUOTE
    السلام عليكم اني طالب مرحلة رابع حاسبات ورايد مساعدة بمشروع التخرج الي يخص error concelament in digital image ومحتاج بي برمجة بلغة ماتلاب عن تقسيم ال image الى بلوكات 8*8 وشلون أمثلها بال discrete cosine transform بالtwo dimension واعمللها بعدين quantization و,scalling وdata embeding.ممكن الرد محتاجه ضروري[email protected]
  6. [76]
    محمد ناجي العراقي
    هذه المشاركة ذات صلة بملتقى المهندسين العرب : http://www.arab-eng.org/vb/showthrea...#ixzz1cZmnPL6y
  7. [77]
    Boldski
    Boldski غير متواجد حالياً
    إذا سمحت حاج إبراهيم, هل عندك خبرة في الـ(data mining) بلغة الجافا بأستخدام الـ KmeansCulstring method or Neural Networks ؟
  8. [78]
    hssalamah
    hssalamah غير متواجد حالياً
    شكرا جزيلا لكن حتى هذه اللحظة لم اجد اي مبرمج يتحدث عن طريقة استخدام برنامج بورلاند سي بلس بلس عشرات الكتب لم أجد فيها ذكر حتى لاسم البرنامج
    حبذا شرح مثال بسيط بشكل عملي على أحد برامج الترجمة
  9. [79]
    a.alshiekhly
    a.alshiekhly غير متواجد حالياً
    اخي العزيز انا خريج هندسة حاسبات و لحد الان ليس لدي اي خبره عمليه
    احاول ان اتعلم الاوراكل لكن لا اعلم من اين أبدا و ماهو البرنامج الذي سأعمل عليه
    و مشكور
  10. [80]
    esraa fathi
    esraa fathi غير متواجد حالياً
    ساعدوني ارجوكم
    كيف احسب طاقة الصوره الرقميه
