قنبلة البرامج Staad Pro 2007 كاملا وعلى غير الرابيدشير
صفحة 1 من 10 12 3 4 5 ... الأخيرةالأخيرة
النتائج 1 إلى 10 من 99
    الصورة الرمزية ماجد جلميران
    ماجد جلميران
    ماجد جلميران غير متواجد حالياً
    Bentley Staad Pro v2007 | 290 MB
    STAAD Pro is the professional’s choice for steel, concrete, timber, aluminum and cold-formed steel design of low and high-rise buildings, culverts, petrochemical plants, tunnels, bridges, piles and much more!
    A comprehensive and integrated finite element analysis and design solution, including a state-of-the-art user interface, visualization tools, and international design codes. Capable of analyzing any structure exposed to a dynamic response, soil-structure interaction, or wind, earthquake, and moving loads.
    STAAD Pro is the premier FEM analysis and design tool for any type of project including towers, culverts, plants, bridges, stadiums, and marine structures. With an array of advanced analysis capabilities including linear static, response spectra, time history, cable, and pushover and non-linear analyses, STAAD.Pro provides your engineering team with a scalable solution that will meet the demands of your project every time.
    STAAD.Pro will eliminate the countless man-hours required to properly load your structure by automating the forces caused by wind, earthquakes, snow, or vehicles.
    In addition, no matter what material you are using or what country you are designing your structure in, STAAD.Pro can easily accommodate your design and loading requirements, including US, European (including the Eurocodes), Nordic, Indian, and Asian codes; even special codes like AASHTO, ASCE 52, IBC and the US aluminum code can be catered to.
    With an unparalleled quality assurance program, open architecture for customization, and a 25-year track record including such projects as the MCI Stadium in Washington DC, Wimbledon Court No1 in Europe, and the tallest transmission tower in Asia, STAAD.Pro is the perfect workhorse for your design firm.
    Download
    http://www.filefactory.com/file/7d278d/
    http://www.filefactory.com/file/5dc831/
    http://www.filefactory.com/file/97144f/
    لاتنسونا بالدعاء والردود
    ماجد جلميران
    لا توجد حتى كلمة شكر واحدة
    yasser_max
    yasser_max غير متواجد حالياً
    ألف ألف شكر
    جاري التحميل
    hanyacad
    hanyacad غير متواجد حالياً
    شكرا اخي الفاضل علي هذا المجهود الكبير
    الحمد لله تم التحميل
    ولاكن ارجو منك شرح كيفية فك الضغط وحرق الاسطوانه
    لاني قمت بفك ال 3 اجزاء الي 18 جزء وبعد ذلك لا اعرف ماذا افعل
    وبارك الله فيك وجزاء خير الجزاء
    عزام سلامة
    عزام سلامة غير متواجد حالياً
    جزاك الله الف خير و بارك فيك
    ماجد جلميران
    الاخ العزيز handyacad قم بفك ضغط الاجزاء الجديدة تحصل على ملفين بعدها تحتاج الى برنامج Magic Iso maker حيث يقوم البرنامج المذكور بقراءة الملفين وتحويلهما الى CD مباشرة ثم تقوم بينصيب البرنامج بصورة اعتيادية من ال CD للعلم برنامج Magic Iso Maker 4.5 موجود على الموقع التالي
    www.avaxhome.org
    اذا احتجت الى اي مساعدة ابعث لي رسالة خاصة
    عزام سلامة
    لو سمحت أخي ماجد ممكن برنامج Magic Iso Maker
    ماجد جلميران
    تفضل يا اخي رابط برنامج magic iso maker
    http://rapidshare.com/files/1540745/..._v5.3.rar.html
    ماجد جلميران
    شارك ولو بكلمة شكر افضل من انت تكون انانيا
    حسان2
    حسان2 غير متواجد حالياً
    الصورة الرمزية حسان2
    Received: 205
    أخي الكريم
    مشكور على جهودك واهتمامك
    لي سؤال لو سمحت
    حملت الأجزاء الثلاثة, عند فك كل منها تحولت الى محموعة كبيرة من الملفات ضمن مجلد وجميعها متشابهة
    كيف يتم التعامل معها بعد ذلك ببرنامج الماجيك هيسو؟؟ علما ان لدي برنامج الماجيك؟
    وشكرا سلفا لاهتمامك
