ما الفرق بين http و https
النتائج 1 إلى 10 من 15
    م المصري
    م المصري غير متواجد حالياً
    Received: 16
    بعض المواقع تبدأ بـ http كمنتدانا و البعض الاخر يبدأ https كصفحة الدخول علي بريد يااهوو
    اليكم الصورتين
    صورة لصفحه من صفحات الملتقي
    صوره لصفحة الدخول علي بريد يااهوو
    و السؤال الان ,,,, ما الفرق ؟
    م.سعد نجم
    م.سعد نجم غير متواجد حالياً
    الصورة الرمزية م.سعد نجم
    اين الردود يا اخوانى ؟؟؟
    م.رائد الجمّال
    الصورة الرمزية م.رائد الجمّال
    Received: 15
    1. HTTPS (Hypertext Transfer Protocol over Secure Socket Layer, or HTTP over SSL) is a Web protocol developed by Netscape and built into its browser that encrypts and decrypts user page requests as well as the pages that are returned by the Web server. HTTPS is really just the use of Netscape's Secure Socket Layer (SSL) as a sublayer under its regular HTTP application layering. (HTTPS uses port 443 instead of HTTP port 80 in its interactions with the lower layer, TCP/IP.) SSL uses a 40-bit key size for the RC4 stream encryption algorithm, which is considered an adequate degree of encryption for commercial exchange. Suppose you use a Netscape browser to visit a Web site to view their online catalog. When you're ready to order, you will be given a Web page order form with a Uniform Resource Locator (URL) that starts with https://. When you click "Send," to send the page back to the catalog retailer, your browser's HTTPS layer will encrypt it. The acknowledgement you receive from the server will also travel in encrypted form, arrive with an https:// URL, and be decrypted for you by your browser's HTTPS sublayer.
    2. HTTPS and SSL support the use of X.509 digital certificates from the server so that, if necessary, a user can authenticate the sender. SSL is an open, nonproprietary protocol that Netscape has proposed as a standard to the World Wide Consortium (W3C). HTTPS is not to be confused with S-HTTP, a security-enhanced version of HTTP developed and proposed as a standard by EIT.
    [SIGPIC][/SIGPIC]
    اعقل الناس اعذر الناس للناس
    م.رائد الجمّال
    Received: 15
    عادة s تكون لبيان ان الاتصال آمن
    و اي استفسار انا جاهز
    [SIGPIC][/SIGPIC]
    الواثقة بالله
    الواثقة بالله غير متواجد حالياً
    الصورة الرمزية الواثقة بالله
    جزاك الله خيرا اخي الكريم م.رائد ,,,,, وبارك الله فيك ....
    م.محمد الكسواني
    م.محمد الكسواني غير متواجد حالياً
    Received: 16
    جزاكم الله خيرا جميعا
    م المصري
    Received: 16
    شكرا استاذنا الفاضل ,,,, مهندسنا رائد الجمال علي التوضيح
    و كنت قد قرأت شرحا لتوي عن هذا الامر في كتاب يسمي أمن المعلومات للمؤلف خالد محمد خالد ,,, و قد تطابق تماما مع توضيح استاذنا رائد ,,,,
    و قد تركز علي انه هناك بروتوكولان للحماية الامنية لمواقع الدفع الالكتروني و بعض مواقع البريد الالكتروني الهامه ,,,, و البروتوكول الاول ,,,هو https و طبعا ستجد حرف s ظاهرا بجانب العنوان الرئيسي للموقع ,,, و هذا دليلا بأن الموقع مؤمن
    البروتوكول الثاني هو ssl و هو بروتوكول خاص بشركة netscape ,,,, و هو للعلم يدعم ايضا متصفح اكسبلورر ,,,,,,, اذا كيف تعرف ان الموقع محمي ببروتوكول ssl
    الاجابه : عندما تشاهد علامة القفل الاصفر اسفل المتصفح ,,,,, تعرف ان الموقع مؤمن بهذا البرتوكول
    انظرو الصورة ....
    و يا حبذا لو كان الموقع مؤمن بالبروتوكلين ,,,, يصبح التأمين افضل بكثير ,,,,
    شكرا اساتذتي الافاضل ,,,,,,,, و شكر لكل من مر علي الموضوع
    م.رائد الجمّال
    Received: 15
    مشكوور ابو ايوي و بارك الله بك
    [SIGPIC][/SIGPIC]
    mohepsh
    mohepsh غير متواجد حالياً
    جزاكم الله خيرا
    wazer
    wazer غير متواجد حالياً
    جزاكم الله خيرا
