موضوع فوق الممتاز عن القدرة و المقاومة وكيفية حساب Propeller Pitch للسفن
النتائج 1 إلى 8 من 8
    الصورة الرمزية Eng-Maher
    Eng-Maher
    Eng-Maher غير متواجد حالياً
    مشرف قسم الهندسة البحرية.
    Received: 103
    Given: 408
    ملخص-------------------------------- ..:
    ملخص الكتاب :
    1. Be able to define effective horsepower (EHP) physically and mathematically.
    2. Be able to state the relative between velocity with total resistance and velocity with effective horsepower.
    3. Be able to write an equation for total hull resistance as a sum of viscous resistance, wave making resistance and correlation resistance. Be able to physically explain each of these resistive terms.
    4. Be able to draw and explain the flow of water around a moving ship showing laminar flow region, turbulent flow region, and separated flow region.
    5. Be able to draw the transverse and longitudinal wave patterns when a displacement ship moves through the water.
    6. Be able to define the Reynolds number with a mathematical formula. Be able to explain each parameter in the Reynolds equation with units.
    7. Be qualitatively familiar with the following minor sources of ship resistance: a. Steering Resistance b. Air and Wind Resistance c. Added Resistance due to Waves d. Increased Resistance in Shallow Water
    8. Read and interpret a ship resistance curve including humps and hollows.
    9. Be able to state the importance of naval architecture modeling of the resistance on the ship's hull.
    10. Be able to define geometric and dynamic similarity.
    11. Be able to write the relationships for geometric scale factor in terms of length ratios, speed ratios, wetted surface area ratios or volume ratios.
    12. Be able to describe the law of comparison (Froude’s law of corresponding speeds) physically and mathematically and state its importance in model testing
    وهذا هو الرابط :
    http://www.usna.edu/NAOE/courses/en200/ch07.pdf
    elbarmoh
    elbarmoh غير متواجد حالياً
    شكرااخى وادعو الى الله ان يقويك وينير بصيرتك الف شكر
    elbarmoh
    Eng-Maher
    Received: 103
    Given: 408
    مشكككككككككككور اخى الفاضل
    الحمد لله
    هندسة بحرية
    هندسة بحرية غير متواجد حالياً
    مشكور اخي وأحسنت ، ولكن اللينك غير صحيح ويعطي Forbidden
    ارجوا وضع لينك جديد
    albahri
    albahri غير متواجد حالياً
    مشششششششششششششكور
    عبدالله نعيم
    عبدالله نعيم غير متواجد حالياً
    شكرا اخي.............
    لكن الرابط غير صحيح
    هندسة الشواطيء
    هندسة الشواطيء غير متواجد حالياً
    والله معلومات قيمة جزاكم الله فينا كل خير
