solution & drowing a single equation using matlab
النتائج 1 إلى 5 من 5
    haythoom
    haythoom غير متواجد حالياً
    بسم اللة الرحمن الرحيم
    اخوانى الاعزاء
    اسمحوا لى ان اضيف اول مشاركة متواضعة لى فى هدا المنتدى الراءع فعلا و اتمنى يارب انفعكم بكل خير على بركة اللة
    this program are made to solve asingle equation using matlab
    the instruction of the program
    after run the program on matlab by you will see this apear in command window
    'xmin'
    which means that the program ask you to enter the firest point that you want to began drowing your function from it
    for example xmin=-pi & press enter after that
    the program will ask you to enter the last point of your curve of equation 'xmax' for examle xmax=pi after that
    the program will ask you to enter your function y as a function of x
    for example sinx
    &dont forget to press enter after evry time
    now you will see the result curve of your function showing that
    the maxmume & the minmum of your curve
    the peaks olso
    the zeros of the equation
    & you will see olso the roots of your function shown in a massage
    box
    بندر ال سعود
    بندر ال سعود غير متواجد حالياً
    شكرررررررا لك اخي الكريم
    haythoom
    meriem13
    meriem13 غير متواجد حالياً
    développement de fourier de f(x)=abs(sinx)
    khoklland007
    khoklland007 غير متواجد حالياً
    shkrun
    shkrun
    shkrun
    shkrun
