Finite Element Analysis: Theory and Application with ANSYS - S. Moaveni
النتائج 1 إلى 4 من 4
    ahmedlouz
    ahmedlouz غير متواجد حالياً
    Author: Saeed Moaveni | Publisher: Prentice Hall | ISBN 0-13-785098-0 | Ed. 1999 | djvu, 527 pages | language: english | 8 MB
    While many good textbooks cover the theory of finite element modeling, this is the only text available that incorporates ANSYS as an integral part of its *******. This book presents the theory of finite element method, explores its application as a design/modelling tool, and explains in detail how to use the ANSYS intelligently and effectively. It shows how to use ANSYS step-by-step to model a physical problem. Each chapter first discusses the relevant basic theory and then demonstrates it using simple problems with hand-calculations. Examples that are solved using ANSYS follow. Various sources of error that can contribute to wrong results are discussed. The design optimization and parametric programming is also included. This book is directed to students and practitioners using ANSYS. (D H Hodges). [/center]
    *******s
    1. Introduction.
    2. Matrix Algebra.
    3. Trusses.
    4. Axial Members, Beams, and Frames.
    5. One-Dimensional Elements.
    6. Analysis of One-Dimensional Problems.
    7. Two-Dimensional Elements.
    8. More ANSYS.
    9. Analysis of Two-Dimensional Heat Transfer Problems.
    10. Analysis of Two-Dimensional Solid Mechanics Problems.
    11. Dynamic Problems.
    12. Analysis of Fluid Mechanic Problems.
    13. Three-Dimensional Elements.
    14. Design and Material Selection.
    15. Design Optimization.
    Appendix A: Mechanical Properties of Some Materials.
    Appendix B: Thermophysical Properties of Some Materials.
    Appendix C: Properties of Common Area Shapes.
    Appendix D: Properties of Structural Steel Shapes.
    Appendix E: Conversion Factors.
    Index.
    http://rapidshare.com/files/39721017/M_FEAT_xyp.rar
    وسام95
    وسام95 غير متواجد حالياً
    شكرا على هذا الكتاب القيم و بارك الله فيك و أحسن اليك
    مصطفى الربايعه
    مصطفى الربايعه غير متواجد حالياً
    ششششششششششششكرررررررررررررررراااااااااا
    Dr.M.mahmood
    Dr.M.mahmood غير متواجد حالياً
    الرابط لا يعمل ارجو اعادة التثبيت مع الشكر الجزيل
