Screw Compressors: Three Dimensional Computational Fluid Dynamics and Solid Fluid Int
النتائج 1 إلى 2 من 2
    ahmedlouz
    ahmedlouz غير متواجد حالياً
    Synopsis
    This book - the authors' second book on screw compressors – presents the results of the most up to date methods of three-dimensional modeling of the fluid dymanics and the solid-fluid interaction within these machines, which are still being developed. By including them in the design process, it is possible, not only to predict flow patterns more accurately, and hence improve the design of the critical components, but also to determine how the pressure and temperature distribution within the compressor distorts the rotors and casing and how this, in turn, has an interactive effect on the performance.
    Such calculating facilities are especially valuable for oil free machines, in which temperature changes are much larger and thus make thermal distortion effects more significant. However, it confers advantages in all cases, as improved machine tools enable manufacturing tolerances to be reduced and hence compressors can be built with smaller clearances. Four examples outline the scope of the applied mathematical model for three dimensional calculation of fluid flow and stresses in the solid parts of the screw machine.
    http://rapidshare.com/files/17940173...ompressors.pdf
    Screw Compressors: Mathematical Modelling and Performance Calculation
    The first part of Screw Compressors gives a review of recent developments in screw compressor design. The second part presents a generalized mathematical definition of screw machine rotors and describes some well known lobe shapes in detail. The third part treats the mathematical modelling of the thermodynamics and fluid mechanics of compression and expansion processes. This includes discussion of the issues addressed in order to be able to predict the optimum rotor size and speed and built-in volume ratio and, in the case of oil flooded machines, the injection position and jet diameter. The fourth and fifth parts discuss the principles used and describe the application of the analytical procedures and rotor profiling techniques, presented in the earlier chapters, to the design of a number of twin screw compressors, currently manufactured including the examples of combining expansion and compression in the same machine.
    http://rapidshare.com/files/9595822/...ompressors.rar
    ahmedhamdy
    ahmedhamdy غير متواجد حالياً
    بسم الله الرحمن الرحيم.
    السلام عليكم ورحمة الله وبركاته.
    جزاك الله كل خير على الكتب الممتازة.
    لكن الكتاب التانى بعد تنزيله و لفك ضغطه يحتاج الى باس وورد, أرجوا أمدادنا بها
