برنامج تصميم الاعمده بجميع اشكالها وبمختلف القطاعات والابعاد
النتائج 1 إلى 10 من 42
    hnyshwky
    hnyshwky غير متواجد حالياً
    هذا البرنامج CSiCOL 8.31 يقوم بتصميم وتحليل جميع الاعمده بمجتلف القطاعات سواء كانت reinforced concrete او composite cross-section يقوم البرنامج بحلها
    وهذه هى صوره البرنامج
    وهذه هى المعلومات الكامله عن البرنامج
    CSiCOL is a comprehensive software package used for the analysis and design of columns. The design of columns of any concrete, reinforced concrete, or composite cross-section can be carried out by the program. CSiCOL provides a 'Quick Design Wizard' tool that guides the users step-by-step, through the whole process of column design. This makes the design process simple, organized and efficient. The design can be carried out in accordance with ACI-318-02, ACI-318-99, BS8110 or CSA A-23.3-94 codes.
    CSiCOL is capable of handling an unlimited number of load combinations both for sway and non-sway conditions. The design actions may be specified directly or may be computed by the program using the moment magnification method. The design and analysis take into account the slenderness effects. Sway or non-sway condition checks may also be performed by the program as specified by the selected design code. Moreover, CSiCOL is capable of determining the Effective Length Factor based on the framing and end conditions of the column.
    CSiCOL output includes the capacity interaction surface, load-moment curves, moment-moment curves, moment-curvature curves for various failure criteria, combined axial-flexural elastic stress contours, rebar stresses, cracked section stresses, load point location, capacity vector, neutral axis depth and orientation, etc. Reports may be created as part of the output for the analysis and design process. The reports may be customized by adding information and graphics of your choice.
    CSiCOL provides several predefined parametric shapes, including a variety of solids, hollow, and flanged shapes, in addition to a large collection of Standard Steel Database Shapes, which can be used in composite columns. It is easy to merge, edit and draw Shapes to suit geometry requirements and create complex cross-sections. The program provides tools for the alignment, stacking, and placement of these Shapes. Rebars can be placed anywhere (corner, perimeter, sides, circle, irregular, etc.) in the cross-section using several addition and placement tools. Standard (ASTM, Metric, and Imperial ) as well as user defined rebar sets may be used
    CSiCOL OUTPUT & DISPLAY
    • Dimensioned Cross-Sectional Views with Reinforcing
    • User Defined Material Colors
    • Capacity Interaction Surfaces and Diagrams
    • Load-Moment Curves
    • Moment-Moment Curves
    • Moment-Curvature Curves for Different Axial Loads
    • Plot Stress Contours for Combined Loading
    • Plot Stresses Along Any Arbitrary Line
    • Graphical Displays of the Neutral Axis and Load Point Location
    • Overlay Multiple Data Plots
    • Color-Coded Rebar Stresses
    • Reports of the Analysis and Design Results
    • Send Current Column View or Report to Printer
    • Import Section Data from a Text File
    • Cut & Paste Data to/from Excel Spreadsheets
    • Import/Export Data in AutoCAD DXF
    engineer_85
    engineer_85 غير متواجد حالياً
    جزاك الله خير
    المجاز
    المجاز غير متواجد حالياً
    الله يبارك فيك على هالبرامج الجميله
    adil
    adil غير متواجد حالياً
    الف شكر علي البرنامج
    ياريت لوعندك اي شرح ليه ترسله لنا والف شكر
    mrniceguy2932000
    mrniceguy2932000 غير متواجد حالياً
    جزاك الله خيرا
    حاتم المختار
    حاتم المختار غير متواجد حالياً
    مشكور... برنامج ممتاز جدا وقيم
    Mada2005
    Mada2005 غير متواجد حالياً
    الصورة الرمزية Mada2005
    مشكور أخى كنت بأبحث عنه من زمان
    لكن بيطلب كلمة مرور ؟؟؟؟؟؟؟؟؟
    Saudi Pro
    Saudi Pro غير متواجد حالياً
    ممكن شرح طريقة تحميل البرنامج من هذا الرابط --------------وشكرا
    Life with out Civil engineers – like the night with out moon
    منير
    منير غير متواجد حالياً
    اخي الكريم ... السلام عليكم
    يرجى توضيح كيفية تنزيل البرنامج ، مع الشكر الجزيل لجهودك
    مشاري
    مشاري غير متواجد حالياً
    عضو تحرير المجلة
    اقتباس المشاركة الأصلية كتبت بواسطة منير مشاهدة المشاركة
    نفس الكلاااااااااام:)
