برنامج ... GGU Gabion v2.11 - Calculation of Gabion Walls ... للمهندسيين
النتائج 1 إلى 8 من 8
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    GGU Gabion v2.11
    Windows OS | Size: 4.00 Mb
    برنامج يختص بالهندسة الانشائية فى مجال الحوائط الساندة
    The program system allows comfortable data input. The system is displayed on the screen. Every change in data is shown on the screen, so that optimum control of input data is guaranteed. A variety of graphical presentation possibilities, to a high standard of quality, allow you to present the calculation results according to your wishes.
    The working group 5.9.3 of the FGSV (Forschungsgesellschaft für Straßen und Verkehrswesen - German Research Group for Road and Traffic Systems) has developed a paper for the calculation of gabions. This paper represents the main basis for programming.
    The program was developed in early 1999, in part from previously existing program modules.
    Capabilities
    The GGU-GABION program has the following special capabilities (and maximum values):
    Almost any kind of definition of gabion bodies
    Base inclination of the gabion body
    50 soil layers
    5 benches on the active side
    5 benches on the passive side
    Calculations with active, increased active and at-rest earth pressure
    Active earth pressure coefficients, MOHR / COULOMB and user-defined values
    Passive earth pressure coefficients, MOHR / COULOMB, STRECK / WEIßENBACH, CAQUOT / KERISEl and user-defined values
    Calculation of settlements
    Calculation of external stability
    Verification of inner stability along the lines
    Comfortable interface to the slope stability program GGU-STABILITY for fast investigations of terrain stability
    50 surcharge earth pressure figures
    20 block loads at any depth
    Static calculations of the wall via a two-dimensional rod structure program module on the basis of finite-element methods.
    Definition of up to 10 additional path boundary conditions (torsion, displacement for x and y) at any position.
    Definition of up to 10 additional force boundary conditions (moment, cross force and normal force) at any position.
    DownLoad
    Or
    DownLoad
    Or
    DownLoad
    Original Site
    .... والله ولى التوفيق ...
    AutoHakeem
    AutoHakeem غير متواجد حالياً
    Received: 58
    Given: 84
    أخي الكريم
    لفك الملف نحتاج لكلمة السر
    و شكرا".
    shahrayar_0o0
    shahrayar_0o0 غير متواجد حالياً
    السلام عليكم يا بشموهندس اسلام انا حاولت انزل البرنامج بس لما باجي افك الضغط بيطلب مني كود و انا مش عارف اجيبو منين الصراحة ف ياريت لو تاخد ثواب فيا و تبعتلي الكود
    و جزيل الشكر
    shahrayar_0o0
    يا بشموهندس بعد اذنك بجد انا محتاج الباث وورد عشان افك ضغط البرنامج يا ريت تبعتهولي عشان انا محتاجو و شكرا
    shahrayar_0o0
    انا مش فاهم انتا مش معبرنا لية ؟؟ ولا مش عاوز تساعدنا لية ؟
    انتا شايف اني مثلا مش قد المقام عشان تساعدنا علي العموم شكرا
    باي
    momo_DZ
    momo_DZ غير متواجد حالياً
    merci mon frere
    super_engineer
    super_engineer غير متواجد حالياً
    Given: 9
    where is the passewrod???
    super_engineer
    Given: 9
