شرح تفصيلي عن جهاز(cbc) باللغة العربية
صفحة 2 من 6 الأولىالأولى 1 23 4 5 6 الأخيرةالأخيرة
النتائج 11 إلى 20 من 59
    kingfuture
    kingfuture غير متواجد حالياً
    مشكور وبارك الله فيك
    kingfuture
    mtc.eng
    mtc.eng غير متواجد حالياً
    شكرا جزيلا اخي العزيز وبارك الله فيك
    eng_ahmed2005
    eng_ahmed2005 غير متواجد حالياً
    كل عام وانت بخير ورمضان كريم
    ولو اTrouble Shootingى حد عنى اى استفسار عن او ممكن يبعتلى
    وانشاء الله ربنا يوفقنا الى المساعدة
    tigersking007
    tigersking007 غير متواجد حالياً
    الصورة الرمزية tigersking007
    مشكور اخى بارك الله فيك
    eng_ahmed2005
    فكرة عمل Auto Hematology Analyzer
    Measurement Principles
    􀂄 RBC/PLT measurement
    RBCs/PLTs are counted and sized by the Coulter method, as Figure shows.
    is based on the measurement of changes in electrical resistance produced by a particle,
    which in this case is a blood cell, suspended in a conductive diluent as it passes through an
    aperture of known dimensions. An electrode is submerged in the liquid on both sides of the
    aperture to create an electrical pathway. As each particle passes through the aperture, a
    transitory change in the resistance between the electrodes is produced. This change
    produces a measurable electrical pulse. The number of pulses generated signals the number
    of particles that passed through the aperture. The amplitude of each pulse is proportional to
    the volume of each particle. Each pulse is amplified and compared to the internal reference
    voltage channels, which only accepts the pulses of a certain amplitude. If the pulse generated
    is above the RBC/PLT lower threshold, it is counted as a RBC/PLT.
    Volumetric Metering
    An accurate cell count cannot be obtained unless the precise volume of diluted sample that
    passes through the aperture during the count cycle is known. This analyzer uses a volumetric
    metering unit to control the count cycle and to ensure that a precise volume of sample is
    analyzed for the measurement.
    The metering unit controlling the RBC/PLT count cycle consists of a metering tube with two
    optical sensors mounted on it, . This tube ensures that a precise amount
    of diluted sample is measured during each count cycle. The exact amount is determined by
    the distance between the two optical sensors. The rinse is used to create a meniscus in the
    metering tube. The count cycle starts when the meniscus reaches the upper sensor and
    stops when the meniscus reaches the lower sensor. The amount of time required for the
    meniscus to travel from the upper sensor to the lower sensor is called the RBC Count Time
    and is measured in seconds. At the end of the count cycle, the measured count time is
    compared to the pre-defined reference count time ( for details). If the former
    is less than or greater than the latter by 2 seconds or more, the analyzer will report RBC
    bubbles or RBC clog error. Seeing the error message, refer to Chapter 11 Troubleshooting
    Your Analyzer for solutions.
    المحاليل التى يعمل بها جهاز عد الدم
    1-Diluent
    2-Lyse
    3-Rinse
    parameters
    White Blood Cell or leukocyte WBC
    Lymphocyte Lymph#
    Mid-sized cel l Mid#
    Granulocyte Gran#
    Lymphocyte percentage Lymph%
    Mid-sized cell percentage Mid%
    Granulocyte percentage Gran%
    Red Blood Cell or erythrocyte RBC
    Hemoglobin Concentration HGB
    Mean Corpuscular (erythrocyte) Volume MCV
    Mean Cell (erythrocyte) Hemoglobin MCH
    Mean Cell (erythrocyte) Hemoglobin Concentration MCHC
    Red Blood Cell (erythrocyte) Distribution Width
    Coefficient of Variation
    RDW-CV
    Standard Deviation
    RDW-SD
    Hematocrit HCT
    Platelet PLT
    Mean Platelet Volume MPV
    Platelet Distribution Width PDW
    Plateletcrit PCT
    وانشاء الله سوف نتكلم عن صيانة الجهاز واى استفسار
    ahmadhelmy
    ahmadhelmy غير متواجد حالياً
    جزاكم الله خير
    يويو_سف
    يويو_سف غير متواجد حالياً
    اخي الفاضل نسيم الخلد
    اشكر لك هذا التميز والمجهود الكبير
    ولكن اخي الكريم هل هناك امكانية بالحصول على نفس المعلومات ولكن باللغة الانجليزية؟
    حسين منير
    حسين منير غير متواجد حالياً
    الله يكرمكم
    حسين منير
    الله يكرمكم
