برنامج ... MSC Easy5 v2005 R1.4 ... للمهندسيين
النتائج 1 إلى 6 من 6
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    Windows OS | Size: 110 Mb
    برنامج للمحاكه فى التصميم لمهندسى الكهرباء والميكانيكا
    In the aerospace and automotive industries, engineers often assemble products schematically using special iconic blocks that represent systems and subsystems, such as valves, actuators, heat exchangers, and so on. Easy5 is a schematic-based simulation software that allows you to model and simulate dynamic systems containing hydraulic, pneumatic, mechanical, thermal, electrical, and digital subsystems.
    Work with libraries of ready-made parts
    So that you can model and simulate a variety of dynamic systems quickly and easily, Easy5 comes with an extensive library of pre-built components sorted by industry. In Easy5, you model systems using functional blocks (summers, dividers, wave generators, and so on) and pre-defined components that represent physical elements (pumps, gears, engines, and so on). You can also link to entire system designs in computer-aided engineer software.
    Access powerful analysis tools
    Another powerful aspect of Easy5 are its analysis tools, which allow you to do nonlinear simulation, steady-state analysis, control system design, data analysis and plotting. Easy5 generates the source code automatically to support real-time requirements. An open architecture provides links to a broad set of popular computer-aided engineering software and hardware tools.
    DownLoad I
    DownLoad II
    .... والله ولى التوفيق ...
    التركاوي
    التركاوي غير متواجد حالياً
    بارك الله فيك جاري التحميل والتجربة
    mrniceguy2932000
    mrniceguy2932000 غير متواجد حالياً
    بارك الله فيك مجهود رائع
    mond
    mond غير متواجد حالياً
    MSC Easy5
    يا اخي الرابط لا يعمل
    alizuhair
    alizuhair غير متواجد حالياً
    thank youvery much go ahead
    م/محمد لطفي
    م/محمد لطفي غير متواجد حالياً
    الصورة الرمزية م/محمد لطفي
    مشكور اخي علي البرنامج الرائع بس ممكن تشرح لينا طريقه التنصيب له لاني محتاجه بس ياريت لو تشرحها صور ومشكوررررررررر مره تانيه
    لمشاهده احدث المواضيع والمشاركات يمكنكم زياره هذا المنتدي
    www.eng2all.com/vb
