مرجع هام لمهندسى الميكانيكـا Process Equipment Design
النتائج 1 إلى 2 من 2
    أهل الحديث
    أهل الحديث غير متواجد حالياً
    Received: 205
    Given: 261
    Equipment Design
    By Lloyd E. Brownell,&nbspEdwin H. Young,
    * Publisher: Wiley-Interscience
    * Number Of Pages: 420
    * Publication Date: 1959-01-15
    * ISBN / ASIN: 0471113190
    $336.70
    Process Equipment Design" focuses on the mechanical design of vessels used in the chemical processing industry.
    By addressing an area where chemical engineers are typically weak, this book will be an extremely useful reference for engineers with a "less than structured" mechanical support team and for those you do have good mechanical support at work, this book will help you understand the mechanical limitations of the equipment that you
    specify
    The book is divided into the following main sections:
    Factors Influencing the Design of Vessels
    Criteria in Vessel Design
    Design of Shells for Flat-Bottomed Cylindrical Vessels
    Design of Bottoms and Roofs for Flat-Bottomed Cylindrical Vessels
    Proportioning and Head Selection for Cylindrical Vessels with Formed Closures
    Stress Considerations in the Selection of Flat-Plate and Conical Closures for Cylindrical Vessels
    Stress Considerations in the Selection of Elliptical, Torispherical, and Hemispherical Dished Closure for Cylindrical Vessels
    Design of Cylindrical Vessels with Formed Closures Operating under External Pressure
    Design of Tall Vertical Vessels
    Design of Supports for Vertical Vessels
    Design of Horizontal Vessels with Saddle Supports
    Design of Flanges
    Design of Pressure Vessels to Code Specifications
    High-Pressure Monobloc Vessels
    Multilayer Vessels
    References
    Appendix A: Design Conventions
    Appendix B: Welding Conventions
    Appendix C: Pricing of Steel Plates
    Appendix D: Allowable Stresses
    Appendix E: Typical Tank Sizes and Capacities
    Appendix F: Shell Accessories
    Appendix G: Properties of Selected Rolled Structural Members
    Appendix H: Values of Constant C of Eq. 13.27
    Appendix I: Charts for Determining Shell Thickness of Cylindrical and Spherical Vessels under External Pressure
    Appendix J: Properties of Various Sections and Beam Formulas
    Appendix K: Properties of Pipe
    Appendix L: Strength of Materials
    Layout: The book is organized is way that takes the reader through the learning process step by step. We particularily liked how the authors sectioned the book based on the type of vessel being designed. The use of equations followed by easy-to-use charts was very nice to see
    2 part RAR
    Mihd
    Mihd
    رائد الطيار
    رائد الطيار غير متواجد حالياً
    شكرا كثيرا اخي
