الى الاخوه والاخوات اعضاء هذا المنتدى المتميز
لدي مقابلة عمل مع شركه مرموقه وهذه المقابله هي الأولى لي بعد تخرجي
استطعت جمع بعض الاسئله الشائعه اللتي يتم سؤالها من قبل هذه الشركه اثناء المقابله وهي على النحو التالي:
  1. An example of when you : Set yourself a demanding goal and overcome obstacles to achieve it.
  2. An example of when you : As a leader of a group of people, set direction for them, gained their commitment and led them to achieve outstanding results.
  3. An example of when you : Had to think through a complex problem, which involved analyzing data, developing options and implemented a solution. (outside academic work where possible).
  4. An example of when you : Developed effective work relationships with people from differing backgrounds, or having differing views, to accomplish an important result.
  5. An example of when you : Generated a new idea or better way of doing someting that led to improved results.
  6. An example of when you : organized your thoughts on a matter of importance to you effectively communicated these to other and obtain their agreement
وشكرا لمساعدتكم مقدما
