Rock Mechanics In Mining Oprojects
النتائج 1 إلى 9 من 9
    الصورة الرمزية alshangiti
    alshangiti
    alshangiti غير متواجد حالياً
    مشرف وإستشاري هندسة المناجم
    Received: 89
    Given: 8
    I will go through rock mechanics in topics and the first is
    RQD
    The RQD is defined as the cumulative length of core pieces longer than 10cm in a run divided by the total length of the core run. The total length of core must include all lost core sections. Any mechanical breaks cause by the drilling process or in extracting the core from the core barrel should be ignored. Core discing due to high stress should not be considered in the RQD calculation but noted separately in core logs. RQD should be measured as soon as possible after drilling.
    Sum of lengths of core sticks > 10 cm long x 100
    Total length of core run
    Table 1. Rock Mass Classification Based on RQD
    RQD
    Rock Quality Classification
    <25%
    Very Poor
    25-50%
    Poor
    50-75%
    Fair
    75-90%
    Good
    90-100%
    Excellent
    youceftli
    youceftli غير متواجد حالياً
    انا طالب ابحث عن هذا الكتاب
    introduction to Rock Mechanics, 2nd Edition,
    Goodman, R.E., John Wiley and Sons
    alshangiti
    Received: 89
    Given: 8
    rock mechanics book
    Introduction to Rock Mechanics, 2nd Edition
    Related Subjects
    div.mailing-list{ margin:0; padding: 10px 8px 10px 80px; width: 147px; height: 44px; line-height: 1.1em; font-size: 12px; background: url('http://media.wiley.com/spa_assets/site/wiley2/cvo/images/backgrounds/mailing-list.gif') no-repeat top left;}Join an Engineering Mailing List. Exclusive offers, news and more.
    Related Titles
    More By This Author
    Engineering Geology: Rock in Engineering Construction
    Soil
    Soil Mechanics for Unsaturated Soils
    by D. G. Fredlund, H. Rahardjo
    The Finite Element Method in the Static and Dynamic Deformation and Consolidation of Porous Media, Second Edition
    by R. W. Lewis, B. A. Schrefler
    Time Effects in Rock Mechanics
    by N. D. Cristescu, U. Hunsche
    Hydraulic Fracture Mechanics
    by Peter Valk&oacute;, Michael J. Economides
    Petroleum Well Construction
    by Michael J. Economides, Larry T. Watters, Shari Dunn-Norman
    function loadLargeCover(coverImagePath,coverImageHeight,cov erImageWidth) { if ($('large-cover-image').childNodes.length > 0) { new Effect.Appear('large-cover',{duration:.3}); } else { var largeImage = document.createElement('img'); largeImage.src = coverImagePath; largeImage.width = coverImageWidth; largeImage.height = coverImageHeight; document.getElementById("large-cover-image").appendChild(largeImage); new Effect.Appear('large-cover',{duration:.3}); }}function closeMe () { new Effect.Fade('large-cover',{duration:.3}); }Click to Close
    Larger Image
    Richard E. Goodman
    ISBN: 978-0-471-81200-5
    Paperback
    576 pages
    November 1988
    £74.50 / €107.20 Add to Cart This price is valid for Saudi Arabia. Change location to view local pricing and availability.
    Evaluation Copy
    Instructors may request an evaluation copy for this title.
    Introduces a new approach to rock mechanics called ``block theory,'' which formalizes procedures for selecting proper shapes and orientations for excavations in hard jointed rock. Applies block theory to rock slopes and underground excavations, and covers the Q theory of rock classification, the empirical criterion of joint shear strength, rock bolting, properties of weak rocks, statistical frequency of jointing, an empirical criterion of rock strength, and design of underground supports. Contains many new problems with worked-out solutions.
    youceftli
    شكرا لكني ابحث عن format pdf لتحميل مباشرة .
    introduction to Rock Mechanics, 2nd Edition, Goodman, R.E., John Wiley and Sons[/QUOTE]
    AHMADALRJOUB
    AHMADALRJOUB غير متواجد حالياً
    مشكور جداُ 000022
    عبد النافع
    عبد النافع غير متواجد حالياً
    الصورة الرمزية عبد النافع
    Arrow
    1. الكتب رائعة بس ياريت كتاب فى هندسة المناجم
    TOOT
    TOOT غير متواجد حالياً
    السلام عليكم ورحمة الله وبركاته ابحث علي دورات في كيفية اخز البيانات لل rock mass classification في الحقل اما فيدوهات او كتابه
    alshangiti
    Received: 89
    Given: 8
    The first major Rock mass classification system in geotechnical engineering was proposed about 60 years ago for tunnelling with steel supports. Later classification systems were developed for non-steel support underground excavation, slope and foundation engineering
    Design methods
    Considering the three main design approaches for excavation in rock – analytical, observational and empirical – the most predominant design approach is the empirical design method. Indeed, on many underground or surface construction and mining projects, rock mass classifications have been providing the only systematic design aid in an otherwise haphazard "trial-and-error" procedure
    Objectives
    Rock mass classifications were developed to create some order out of the chaos in site investigation procedures. They were not intended to replace analytical studies, field observations, measurements or engineering judgement.
    The objectives of rock mass classifications are to:
    1. Identify the most significant parameters influencing the behaviour of a rock mass.
    2. Divide a particular rock mass formulation into groups of similar behaviour – rock mass classes of varying quality.
    3. Provide a basis of understanding the characteristics of each rock mass class
    4. Relate the experience of rock conditions at one site to the conditions and experience encountered at others
    5. Derive quantitative data and guidelines for engineering design
    6. Provide common basis for communication between engineers and geologists
    Benefits
    The main benefits of rock mass classifications:
    1. Improving the quality of site investigations by calling for the minimum input data as classification parameters.
    2. Providing quantitative information for design purposes.
    3. Enabling better engineering judgement and more effective communication on a project
    List of rock mass classifications
    Rock quality designation
    rock-quality designation (RQD) Rough measure of the degree of jointing or fracture in a rock mass, measured as a percentage of the drill core in lengths of 10 cm or more. High-quality rock has an RQD of more than 75%, low quality of less than 50%. Rock quality designation (RQD) has several definitions. The most widely used definition was developed in 1964 by D. U. Deere. It is the borehole core recovery percentage incorporating only pieces of solid core that are longer than 100 mm in length measured along the centerline of the core. In this respect pieces of core that are not hard and sound should not be counted though they are 100 mm in length. RQD was originally introduced for use with core diameters of 54.7 mm (NX-size core). RQD has considerable value in estimating support of rock tunnels. RQD forms a basic element in some of the most used rock mass classification systems: Rock Mass Rating system (RMR) and Q-system
    RQD is defined as the quotient:
    % = Sum of length of core sticks longer than 100 mm measured along the center line of the core = Total length of core run[ Classification table
    From the RQD index the rock mass can be classified as follows:
    RQDRock mass quality<25%very poor25-50%poor50-75%fair75-90%good90-100%excellent
    المهندس / يحيى بن محمد الشنقيطى
    alshangiti
    Received: 89
    Given: 8
    Rock mass rating system
    The Rock Mass Rating (RMR) system is a geomechanical classification system for rocks, developed by Z. T. Bieniawski between 1972 and 1973.
    [ Definition
    The following six parameters are used to classify a rock mass using the RMR system
    1. Uniaxial compressive strength of rock material
    2. Rock Quality Designation (RQD)
    3. Spacing of discontinuities
    4. Condition of discontinuities
    5. Groundwater conditions
    6. Orientation of discontinuities
    Each of the six parameters is assigned a value corresponding to the characteristics of the rock. These values are derived from field surveys. The sum of the six parameters is the "RMR value", which lies between 0 and 100.
    Below is the classification table for the RMR system.
    RMRRock quality0 - 20Very poor21 - 40Poor41 - 60Fair61 - 80Good81 - 100Very good
    [ Applications
    Rock Mass Rating has found wide application in various types of engineering projects such as tunnels, slopes, foundations, and mines. It is also adaptable for knowledge-based expert systems
    Q-system
    For the linguistics formalism, see Q-systems.The Q-system of rock mass classification was developed in Norway in 1974 by Nick Barton, Lien, R., and Lunde, J at NGI (Norwegian Geotechnical Institute). The system was developed on the basis of an analysis of 212 tunnel case histories from Scandinavia. It is a quantitative classification system and is an engineering system facilitating the design of tunnel supports. The Q-system uses six different parameters to assess the rock mass quality. The parameters are:
    • Rock Quality Designation RQD
    • Joint set number Jn
    • Roughness of the most unfavorable joint or discontinuity Jr
    • Degree of alteration of filling along the weakest joint Ja
    • Water inflow Jw
    • Stress Reduction Factor SRF
    The Q-factor can then be calculated as:
