برنامج ... Megatech MegaCAD 3D v2007 ... للمهندسيين
النتائج 1 إلى 2 من 2
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    Windows OS | Size: 165 Mb
    برنامج هندسى جديد على الساحة الهندسية وهو قائم بنفس اعمال الارش كاد والاتوكاد الثلاثى الابعاد وهو مستخدم من قبل مهندسى العمارة
    MegaCAD 3D is the ideal synthesis of an innovative solid and surface modelling system and a full-feature 2D drafting program. If you are developing your model in 3D or if you are drawing a 2D design, each step will automatically be transferred from one dimension into the other one.
    In MegaCAD 3D, the user has a powerful solid modeling system. In addition, any designs can be wholly or partly implemented in the surface modeler. Because they share a common data structure, the two forms of model can be combined. This makes it possible, for example, to trim a solid object with a complex free-form surface, to give the solid a new shape. Conversely, the surface of a solid body can be isolated as a separate surface.
    mrniceguy2932000
    mrniceguy2932000 غير متواجد حالياً
    بارك الله فيك اخي محمد للامام دوما
