Chapter 6: Turbines, Generators and Power Plants
النتائج 1 إلى 10 من 10
    التوربينى 2010
    التوربينى 2010 غير متواجد حالياً
    As we learned in Chapter 2, electricity flows through wires to light our lamps, run TVs, computers and all other electrical appliances. But where does the electricity come from?
    In this chapter, we'll learn how electricity is generated in a power plant. In the next few chapters, we'll learn about the various resources that are used to make the heat to produce electricity. In Chapter 7, we'll learn how the electricity gets from the power plant to homes, school and businesses.
    Thermal power plants have big boilers that burn a fuel to make heat. A boiler is like a teapot on a stove. When the water boils, the steam comes through a tiny hole on the top of the spout. The moving steam makes a whistle that tells you the water has boiled. In a power plant, the water is brought to a boil inside the boiler, and the steam is then piped to the turbine through very thick pipes.
    In most boilers, wood, coal, oil or natural gas is burned in a firebox to make heat. Running through the fire box and above that hot fire are a series of pipes with water running through them. The heat energy is conducted into the metal pipes, heating the water in the pipes until it boils into steam. Water boils into steam at 212 degrees Fahrenheit or 100 degrees Celsius.
    The top picture on the right is of a small power plant located at Michigan State University. The black area to the left of the power plant is coal, the energy source that is burned to heat the water in the boilers of this plant.
    In the second picture to the right, you'll see the turbine and generator at MSU's power plant. The big pipe on the left side is the steam inlet. On the right side of the turbine is where the steam comes out. The steam is fed under high pressure to the turbine. The turbine spins and its shaft is connected to a turbogenerator that changes the mechanical spinning energy into electricity.
    The third picture on the right is of the turbine fan before it is placed inside the turbine housing. You can see a close-up of the turbine blades on the fourth picture. The turbine has many hundreds of blades that are turned at an angle like the blades of a fan. When the steam hits the blades they spin the turbine's shaft that is attached to the bottom of the blades.
    After the steam goes through the turbine, it usually goes to a cooling tower outside the where the steam cools off. It cools off and becomes water again. When the hot pipes come into contact with cool air, some water vapor in the air is heated and steam is given off above the cooling towers. That's why you see huge white clouds sometimes being given off by the cooling towers. It's not smoke, but is water vapor or steam. This is not the same steam that is used inside the turbine.
    The cooled water then goes back into the boiler where it is heated again and the process repeats over and over.
    Most power plants in California use cleaner-burning natural gas to produce electricity. Others use oil or coal to heat the water. Nuclear power plants use nuclear energy to heat water to make electricity. Still others, called geothermal power plants, use steam or hot water found naturally below the earth's surface without burning a fuel. We'll learn about those energy sources in the next few chapters.
    How the Generator Works
    The turbine is attached by a shaft to the turbogenerator. The generator has a long, coiled wire on its shaft surrounded by a giant magnet. You can see the inside of the generator coil with all its wires in the picture on the right.
    The shaft that comes out of the turbine is connected to the generator. When the turbine turns, the shaft and rotor is turned. As the shaft inside the generator turns, an electric current is produced in the wire. The electric generator is converting mechanical, moving energy into electrical energy.
    The generator is based on the principle of "electromagnetic induction" discovered in 1831 by Michael Faraday, a British scientist. Faraday discovered that if an electric conductor, like a copper wire, is moved through a magnetic field, electric current will flow (or "be induced") in the conductor. So the mechanical energy of the moving wire is converted into the electric energy of the current that flows in the wire.
    The electricity produced by the generator then flows through huge transmission wires that link the power plants to our homes, school and businesses. If you want to learn about transmission lines, go to Chapter 7.
    All power plants have turbines and generators. Some turbines are turned by wind, some by water, some by steam.
    mohamed abouzahra
    mohamed abouzahra غير متواجد حالياً
    الصورة الرمزية mohamed abouzahra
    مشكوووررررررررررررر
    احمد مؤنس
    احمد مؤنس غير متواجد حالياً
    الصورة الرمزية احمد مؤنس
    مشكوووررررررررررررر
    رافد الصالح
    رافد الصالح غير متواجد حالياً
    مشكوووووووووووووووووور
    الفدعاني
    الفدعاني غير متواجد حالياً
    Thanksssssssssssssss
    الفدعاني
    مشكورررررررررررررر
    الفدعاني
    thankssssss
    الفدعاني
    Thanksssssssssssssss alot
    الفدعاني
    thankssssssssssssss
    الشبواني
    الشبواني غير متواجد حالياً
    مشكورررررررررررررر
