برنامجان ... Elite RHVAC v8.01.217 + Drawing Board v6.01.158 ... للمهندسيين
النتائج 1 إلى 10 من 13
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    Windows OS | Size: 24.01 Mb
    برنامج تصميم معمارى اضافة لخاصية حساب احمال التكييف للمبنى
    # Calculates peak heating and cooling loads in accordance with Manual J.
    # Calculates Duct Sizes, System Losses, and fan static pressure requirement in accordance with Manual D. Lets you enter the entire duct system, or only the path(s) with the highest pressure loss if you prefer.
    # Determines building tonnage and room CFM requirements.
    # Incorporates Manual J Addenda A, B, C, and D!
    # Links to REM/Rate, Architectural Energy Corporation's popular home energy rating tool.
    # Links to REScheck, DOE's energy codes program.
    # Links to the Energy Gauge USA home energy rating program.
    # New! Generates a Building Rotation report that shows you tonnages and room CFM requirements at each rotation.
    # New! Includes a Buiding Rotation Duct Size Preview window that shows you the heating and cooling CFM for each room or duct in the project for each rotation of the building, as well as the maximum duct size of all rotations.
    # Calculates hydronic radiant floor tubing length required.
    # Follows ACCA Manual J, 8th Edition. Rhvac is approved by ACCA.
    # Computes room by room, zone, system & building.
    # Calculates from manually entered data or directly from floor plans created with Drawing Board (sold separately).
    # Rooms and zones can be assigned to 15 systems.
    # Allows 1000 rooms grouped into 10 zones per system using drag and drop zoning techniques.
    # Allows 20 walls, 20 windows, 8 roofs, 6 floors and 6 doors per room.
    # Allows custom construction materials and descriptions.
    # Lets you specify lists of "Favorite" materials so you can select them easier.
    # Remembers your most recent material selections so you can reselect them easily.
    # Looks up HTM & U-values or lets you specify them.
    # Determines Adequate Exposure Diversity status.
    # Links to Ductsize, Energy Audit and PsyChart. The PsyChart program can import Rhvac system data directly into its Air Handler Model window.
    # No copy protection!
    # Displays psychrometric chart.
    # Lets you select equipment from ARI and GAMA databases.
    # Prints exploded color pie charts, bar graphs, and custom sales proposals.
    # Allows decimal feet, feet-inches or metric length and width dimensions.
    # Allows exterior shading (overhangs and offsets).
    # Provides inputs for summer & winter partition temperature differences.
    Special Instructions:
    Follow instructions to load license files for Base and Drawing Board.
    Please! It would be great to unlock 'Manual D Ductsize' and 'Proposal Maker' that are included with this program but must be unlocked from the help menu.
    DownLoad
    .... والله ولى التوفيق ...
    ibrahim younes
    ibrahim younes غير متواجد حالياً
    please can you upload it on another site
    e_kassem1
    e_kassem1 غير متواجد حالياً
    السلام عليكم:
    أرجوا رفعه مرة أخرى لانه تم حذفه
    مهندس/سيف الدين
    مهندس/سيف الدين غير متواجد حالياً
    ارجو رفعه على موقع غير الرابيد شير
    اللهم عليك باليهود المعتدين المستكبرين فإنهم لايعجزونك
    engramy
    engramy غير متواجد حالياً
    الصورة الرمزية engramy
    Received: 12
    البرنامج إتمسح
    katata
    katata غير متواجد حالياً
    برجاء اعادة التحميل
    شكرا
    tarekdia
    tarekdia غير متواجد حالياً
    الصورة الرمزية tarekdia
    يوجد برامج افضل منها برجا التوجه الى الموقع التالى
    http://www.4msa.com/downloadsENG.html
    راي محمد علي
    راي محمد علي غير متواجد حالياً
    الرجاء البرنامج ممسوح ارجو اعادته واكمال الجميل
    راي محمد علي
    يا اخ طارق ارجو بيان كيفية التحميل من ذلك الموقع
    تقى عمر محمود
    تقى عمر محمود غير متواجد حالياً
    مشكور اخى الكريم
