برنامج ... UGS Femap v9.3 ISO ... للمهندسيين
النتائج 1 إلى 4 من 4
    Mu7ammad
    Mu7ammad غير متواجد حالياً
    Received: 8
    UGS Femap v9.3 ISO
    Windows OS | Size: 775 Mb
    برنمج يختص بالجودة والكفائة للمنتجات الهندسيةا
    Femap is the world’s leading Windows-based engineering simulation tool for finite element analysis (FEA). Engineers worldwide use Femap to model and simulate everything from simple solid components to entire spacecraft assemblies throughout a broad range of engineering disciplines. From simple linear static analysis right through to advanced solutions based computational fluid dynamics, engineers and analysts use Femap to virtually simulate a complete range of product behavior to reduce costly prototypes and physical testing and before committing to expensive product development plans. This ensures higher product quality, lower development costs, decreased testing overheads and reduced product development time.
    Femap is based on an advanced set of open technologies that enable it to work simply and easily within customer engineering simulation environments. Femap is primarily based on Parasolid, which ensures direct access to some 35% of the world’s digital product definition data. In addition, a number of state-of-the-art geometric extensions ensure that Femap is able to work with geometry from virtually any source, directly and seamlessly. Femap also works with an unusually broad range of finite element solver solutions. This makes Femap a very logical and flexible solution that is simply tailored for even the most demanding customer needs.
    ماجد جلميران
    ماجد جلميران غير متواجد حالياً
    الصورة الرمزية ماجد جلميران
    مشكوووووووور اخي على البرنامج الرائع وجاري التحميل
    اذا امكن هل البرنامج يحتوي كراك
    ماجد جلميران
    Angry
    اخي اعزيز بعد اكمال تنزيل البرنامج وفتح الكبس لايوجد ملف تنفيذي لتنصيب البرنامج فقط ملفات بيانات ارجو منك شرح طريقة تنصيب البرنامج
    mrniceguy2932000
    mrniceguy2932000 غير متواجد حالياً
    بارك الله فيك اخي الكريم
