Server Error in '/' Application.
The 'FONT' start tag on line 1 does not match the end tag of 'span'. Line 1, position 329.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Xml.XmlException: The 'FONT' start tag on line 1 does not match the end tag of 'span'. Line 1, position 329.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[XmlException: The 'FONT' start tag on line 1 does not match the end tag of 'span'. Line 1, position 329.]
System.Xml.XmlTextReaderImpl.Throw(Exception e) +87
System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) +77
System.Xml.XmlTextReaderImpl.ThrowTagMismatch(Node Data startTag) +211
System.Xml.XmlTextReaderImpl.ParseEndElement() +1900056
System.Xml.XmlTextReaderImpl.ParseElement*******() +424
System.Xml.XmlTextReaderImpl.Read() +26
System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace) +557
System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc) +50
System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace) +162
System.Xml.XmlDocument.Load(XmlReader reader) +96
System.Xml.XmlDocument.LoadXml(String xml) +194
elmasry.article1.Page_Load(Object sender, EventArgs e) +9321
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +47
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1061
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.42
