عروض تقديمية مرئيه Video
النتائج 21 إلى 30 من 42
  1. [21]
    Smiley
    Smiley غير متواجد حالياً
    الصورة الرمزية Smiley
    العرض التاسع عشر
  2. [22]
    Smiley
    العرض العشرين
  3. [23]
    Smiley
  4. [24]
  5. [25]
    Smiley
    Manufacturing Videos بروابط مباشرة
    http://www.me.gatech.edu/jonathan.co...mfgvideos.html
    أفــــلام عن كل مايخص المحركات
    http://www.estevancomp.ca/mechanics
    Joining Metals
    Joining
    Resistance welding
    Ultrasonic welding of metal
    Ultrasonic welding of plastic
    Shielded gas arc welding
    Weld pool animation
    Arc welding fume formation
    Plasma welding
    Pulsed gas metal arc welding
    TIG (Tungsten Inert Gas) welding
    Laser welding
    Laser welding of spark plug
    Nb:YAG (Niobium-Yttrium-Aluminum-Garnet) laser welding
    Friction welding
    Friction welding
    Friction stir welding
    Brazing
    Polymers
    Injection molding
    Injection molding
    Injection molding animation
    Injection molding clamp animation
    Lego manufacture
    Collapsible core injection mold
    Expandable cavity injection mold
    Extrusion
    PVC window frame extrusion
    Co-extrusion and Blown film extrusion
    Extrusion blow molding
    Blow molding animation
    Blow molding video
    Transfer molding
    Rotational molding
    Static mixer
    CD
    CD-R burner
    CD-RW burner
    Weldline genesis
    Polaroid sunglasses
    How Polaroid sunglasses work
    Plastic slinky manufacture
    Draft bottle widget
    Draft can widget
    Composites
    Composites manufacturing
    Vacuum bagging
    Pultrusion animation
    Filament winding animation
    McLaren F1 car manufacture
    Powder
    Powder pressing
    Powder pressing animation
    Rapid Prototyping
    Stereolithography
    Stereolithography
    Stereolithography animation
    Selective laser sintering
    Fused deposition modeling
    Layered object modeling
    Speed part
    Rapid injection mold tooling
    Soft tooling
    Integrated Chip Manufacture
    Silicon wafer manufacture
    Microelectronic chip manufacture
    Semiconductor theory
    Semiconductor manufacturing
    What is a clean room?
    History of the Integrated Circuit
    Integrated circuit manufacture game
    US Government National Nanotechnology Initiative
    Digital Light Projector
  6. [26]
    Smiley
    WELDING
    Super Alloy 1
    Videos
    Pot Metal Door Handle Repair (1:46)
    Pot Metal Headlight Trim Repair (2:53)
    Eliminate Warpage in Steel Side Panels (1:09)
    Joining Brass to Aluminum (2:35)
    Joining Copper to Aluminum (1:40)
    Repairing Brass Radiator Tanks (:45)
    Joining Copper Tubing to Aluminum Tubing (1:17)
    How to Fill Pot Metal Pits (:55)
    Air Charge Cooler Repair (:45)
    How to Join 2 Pieces of Broken Pot Metal (1:00)
    Repairing Multiple Aluminum Radiator Holes (3:13)
    How to Fill Gaps in Pot Metal (:50)
    An Aluminum Radiator with a 1/8" Hole in the Tube (:29)
    A Pot Metal '67 GTO Console Piece with a Peg Missing (:40)
    A '67 GTO Console Piece with a 1/8" Tear in the Pot Metal (:29)
    Super Alloy 5
    Videos
    ATV Radiator Repair (2:00)
    Thick to Thin Aluminum Repair (1:36)
    How to Fill Holes in Aluminum (1:10)
    Cast Aluminum Intake Manifold (2:06)
    Aluminum A/C Return Loop Repair (:50)
    Aluminum Transmission Case Repair (3:00)
    Bumper Reinforcement Repair (2:40)
    Vertical Radiator Repair (:34)
    Brazing vs. Soldering (:45)
    Joining Aluminum Plates (1:50)
    Filling Aluminum Gaps (:55)
    Super Alloy 5 Strength (:40)
    Joining Aluminum A/C Fittings (1:20)
    Multiple A/C Line Holes (2:15)
    Aluminum Boat Repair (:55
    )Aluminum A/C Fittings (1:29)
    Aluminum Boat Repair #2 (1:59)
    Repairing Aluminum Puncture Holes (:53)
    SSF-6 Silver Solder
    Videos
    Repairing Stainless to Stainless (1:06)
    Repairing Steel to Steel (2:03)
    Cast Iron Exhaust Manifold Repair (1:40)
    Joining 2 Pieces of Brass (1:25)
    Joining Stainless to Brass (1:00)
    Hydraulic Hose Repair (1:50)
    Bobcat Oil Pan Repair (1:00)
    Copper A/C Condenser Repair (:38)
    Cool Blue Heat Paste
    Videos
    How to Use Cool Blue Heat Paste (1:00)
    Protect Heat Sensitive Surfaces (1:15)
    Fishing Pole Repair (1:45)
    Eliminate Warpage in Auto Body Applications (1:55)
    Cast Iron
    Cummins Exhaust Manifold Repair with 72 & 77 (3:45)
    Ornamental Fireplace Stand Repair (1:46)
    Cast Iron Blower Repair (2:23)
  7. [27]
    Smiley
    Introduction
    Cool Honda advertisement About the Honda advertisement
    Dislocation motion
    Plastic deformation
    Tensile test / Screw dislocation
    Component deformation
    Types of heat transfer
    Heat transfer in a rod
    Disk brake
    Fluid flow past a cylinder
    Pencil manufacture
    Ball bearing crystal model
    Casting
    Metal pouring
    Induction melting of metal
    Mold filling movie
    Investment casting
    Lost foam filling movie
    Casting filling animation
    Horizontal centrifugal casting
    Vertical centrifugal casting
    Filling of spiral test mold
    Hot chamber die casting
    Cold chamber die casting
    Squeeze casting
    Directional solidification
    Dendrite growth
    Blast furnace animation
    Continuous casting - (1) melting and solidification operations
    Continuous casting - (2) rolling operations
    Deformation Processing
    Open die forging
    Closed die forging
    Hammer forging
    Forging machine animation
    Wrench forging animation
    Upsetting (heading)
    Heat treating
    Rolling
    Rolling
    Rolling
    Drawing
    Slinky manufacture
    Sheet Metal Forming
    V-die bending simulation
    Air bending simulation
    Wiping die simulation
    Wiping die springback simulation
    Wiping die springback movie
    Dies
    Types of dies
    Types of presses
    Plasma punch press
    U-joint animation
    Tube bending
    Tube bending
    Stamping FEM
    Hydroforming
    Hydroforming of sphere FEM
    Hydroforming of joint FEM
    Hydroforming of shaft FEM
    Machining
    Orthogonal cutting
    Card model of shear plane
    Chatter
    Shear strain animation 1
    Shear strain animation 2
    Hitch ball turning
    Microturning
    Chip formation
    Machining temperature animation
    Tool materials
    Tool geometry
    Milling
    Micromilling
    Hole drilling
    Tapping
    Grinding wheels
    Grinding
    Introduction to machining : Introduces turning, milling and drilling operations
    Wedge shape tool: Shows how all cutting tools have the basic wedge shape
    Cutting action, basic tool geometry and shear plane: Shows the necessity of clearance and rake angles, and the presence of shear plane in machining
    Rake angle and effect on power: Demonstrates how power required for machining varies with the rake angle and why very high rakes are not desirable
    Cutting tool geometry: Shows all the required angles in a cutting tool
    Drilling tool geometry: Shows important angles in a drill bit
    Non-traditional processing
    Water jet cutting
    Water jet cutting movies
    Electrical discharge machining
    Wire electrical discharge machining
    Plasma punch
    Photo etching
  8. [28]
    Smiley
    موقع أكثر من رائع لشرح ميكانيكا السيارات ..
    دورة الوقود - الزيت - الهواء - نظام الفرامل - المحرك الرباعي الأشواط
    بالصور والفيديو - قابل للتحميل
    http://abbysenior.com/mechanics/
    مثال : على تحميل الفيديو : -
    إحدى الصفحات
    http://abbysenior.com/mechanics/lubricat.htm
    وهذا رابط لموقع آخر لشرح ميكانيكا السيارات ..
    وهو يحتوي على 32 ملف فيديو للتحميل مجانا
    http://www.cdxglobal.com/resources/video.html
    ملاحظات : -
    - بعض الملفات مشابه للملفات في الموقع الأول ..
    إلا أنها أقل وضوحا حيث عمل على تقليل حجمها من خلال تقليل درجة الوضوح ..
    لذا فهي مناسبه لمن لا يملكون سرعة تحميل عالية ..
    - يبلغ الحجم الكلي للملفات في الموقع الثاني 137 ميجابايت فقط
    منقول لتعميم الفائده
  9. [29]
    Smiley
    عروض تقديمية عن الهندسة الانشائية
    الحقوق محفوظة للأستاذ الدكتور/ نبيل سيد محمود حسن
    كلية الهندسة - جامعة المنصورة - جمهورية مصر العربيه
    رئيس مجلس قسم الهندسة الإنشائية
    Introdution
    http://www.mans.edu.eg/pcvs/6123/01_Introdution.ppt
    Parts of steel bridge
    http://www.mans.edu.eg/pcvs/6123/02_...eel_bridge.ppt
    Loads on bridge
    http://www.mans.edu.eg/pcvs/6123/03_loads_on_bridge.ppt
    Allowable Stresse
    http://www.mans.edu.eg/pcvs/6123/04_...le_stresse.ppt
    Fatigue
    http://www.mans.edu.eg/pcvs/6123/05_fatigue.ppt
    Plate girder
    http://www.mans.edu.eg/pcvs/6123/06_plate_girder.ppt
    Lenth of Flange
    http://www.mans.edu.eg/pcvs/6123/07_lenth_of_flange.ppt
    Coneciton of lage web
    http://www.mans.edu.eg/pcvs/6123/08_...f_lage_web.ppt
    Web Stiffner
    http://www.mans.edu.eg/pcvs/6123/09_web_stiffner.ppt
    Web Splice
    http://www.mans.edu.eg/pcvs/6123/10_web_splice.ppt
    Flange Splice
    http://www.mans.edu.eg/pcvs/6123/11_flange_splice.ppt
    Maximum Deflection
    http://www.mans.edu.eg/pcvs/6123/12_...deflection.ppt
    Bearing
    http://www.mans.edu.eg/pcvs/6123/13_bearing.ppt
    Road way bridge
    http://www.mans.edu.eg/pcvs/6123/14_road_way_bridge.ppt
  10. [30]
    Smiley
